333_half_evil
Client won't connect..
The client takes a while to connect to a server, then flushes DNS, the just restarts.. any ideas on a fix? i've tried different ports and that does not seem to help
Log-
I 2017.05.02 10:52:19 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 10.0.15063.0, Mono/.Net Framework: v4.0.30319
. 2017.05.02 10:52:19 - Reading options from C:\Users\HalfEvil\AppData\Local\AirVPN\AirVPN.xml
. 2017.05.02 10:52:20 - Data path: C:\Users/HalfEvil\AppData\Local\AirVPN
. 2017.05.02 10:52:20 - Application path: C:\Program Files\AirVPN
. 2017.05.02 10:52:20 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.05.02 10:52:20 - Command line arguments (1): path="home"
. 2017.05.02 10:52:20 - Operating System: Microsoft Windows NT 10.0.15063.0
I 2017.05.02 10:52:20 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.05.02 10:52:20 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.05.02 10:52:20 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.05.02 10:52:20 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.05.02 10:52:20 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.05.02 10:52:20 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2017.05.02 10:52:20 - Activation of Network Lock - Windows Filtering Platform
! 2017.05.02 10:52:20 - Ready
. 2017.05.02 10:52:20 - Updating systems & servers data ...
. 2017.05.02 10:52:21 - Systems & servers data update completed
I 2017.05.02 10:52:21 - Session starting.
. 2017.05.02 10:52:21 - IPv6 disabled with packet filtering.
I 2017.05.02 10:52:23 - Checking authorization ...
! 2017.05.02 10:52:24 - Connecting to Enif (Canada, Toronto, Ontario)
. 2017.05.02 10:52:24 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.02 10:52:24 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.05.02 10:52:24 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.02 10:52:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.02 10:52:24 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:52:24 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:52:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.242:80
. 2017.05.02 10:52:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.05.02 10:52:24 - OpenVPN > UDP link local: (not bound)
. 2017.05.02 10:52:24 - OpenVPN > UDP link remote: [AF_INET]104.254.90.242:80
. 2017.05.02 10:52:24 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.242:80, sid=685bef75 0094f1d9
. 2017.05.02 10:52:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.05.02 10:52:24 - OpenVPN > Validating certificate key usage
. 2017.05.02 10:52:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.05.02 10:52:24 - OpenVPN > VERIFY KU OK
. 2017.05.02 10:52:24 - OpenVPN > Validating certificate extended key usage
. 2017.05.02 10:52:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.05.02 10:52:24 - OpenVPN > VERIFY EKU OK
. 2017.05.02 10:52:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.05.02 10:52:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.05.02 10:52:24 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.242:80
. 2017.05.02 10:52:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.05.02 10:52:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.227 255.255.0.0'
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.05.02 10:52:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.05.02 10:52:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.02 10:52:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:52:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.02 10:52:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:52:25 - OpenVPN > interactive service msg_channel=0
. 2017.05.02 10:52:25 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=8 HWADDR=e0:3f:49:7a:af:e7
. 2017.05.02 10:52:25 - OpenVPN > open_tun
. 2017.05.02 10:52:25 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{38372446-12C5-4B31-9683-49DF24F1D2FE}.tap
. 2017.05.02 10:52:25 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.05.02 10:52:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.227/255.255.0.0 [sUCCEEDED]
. 2017.05.02 10:52:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.227/255.255.0.0 on interface {38372446-12C5-4B31-9683-49DF24F1D2FE} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.05.02 10:52:25 - OpenVPN > Successful ARP Flush on interface [5] {38372446-12C5-4B31-9683-49DF24F1D2FE}
. 2017.05.02 10:52:25 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.05.02 10:52:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:31 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:35 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:36 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:37 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:38 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:39 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:40 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:41 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:42 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:43 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:44 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:45 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:47 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:48 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:49 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:50 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:51 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:52 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:53 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:54 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:55 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:56 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:58 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:52:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:52:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2017.05.02 10:52:59 - Eddie Windows Interface Hack executed (Ethernet 2)
. 2017.05.02 10:53:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
. 2017.05.02 10:53:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.242 MASK 255.255.255.255 192.168.0.1
. 2017.05.02 10:53:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=15 and dwForwardType=4
. 2017.05.02 10:53:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.05.02 10:53:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.05.02 10:53:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=14 and dwForwardType=4
. 2017.05.02 10:53:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.05.02 10:53:00 - OpenVPN > SYSTEM ROUTING TABLE
. 2017.05.02 10:53:00 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=8 t=4 pr=3 a=3920 h=0 m=16/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.6.0.1 p=0 i=5 t=4 pr=3 a=0 h=0 m=14/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 10.6.0.0 255.255.0.0 10.6.1.160 p=0 i=5 t=3 pr=2 a=104 h=0 m=270/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 10.6.1.160 255.255.255.255 10.6.1.160 p=0 i=5 t=3 pr=2 a=104 h=0 m=270/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 10.6.255.255 255.255.255.255 10.6.1.160 p=0 i=5 t=3 pr=2 a=104 h=0 m=270/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 104.254.90.242 255.255.255.255 192.168.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=15/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=382342 h=0 m=331/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=382342 h=0 m=331/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=382342 h=0 m=331/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.6.0.1 p=0 i=5 t=4 pr=3 a=0 h=0 m=14/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.102.105 p=0 i=4 t=3 pr=2 a=50015 h=0 m=281/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 169.254.102.105 255.255.255.255 169.254.102.105 p=0 i=4 t=3 pr=2 a=50015 h=0 m=281/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.102.105 p=0 i=4 t=3 pr=2 a=50015 h=0 m=281/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.2 p=0 i=8 t=3 pr=2 a=3920 h=0 m=271/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 192.168.0.2 255.255.255.255 192.168.0.2 p=0 i=8 t=3 pr=2 a=3920 h=0 m=271/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.2 p=0 i=8 t=3 pr=2 a=3920 h=0 m=271/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=382342 h=0 m=331/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.2 p=0 i=8 t=3 pr=2 a=382328 h=0 m=271/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.102.105 p=0 i=4 t=3 pr=2 a=50025 h=0 m=281/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 224.0.0.0 240.0.0.0 10.6.1.160 p=0 i=5 t=3 pr=2 a=3924 h=0 m=270/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=382342 h=0 m=331/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.2 p=0 i=8 t=3 pr=2 a=382328 h=0 m=271/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.102.105 p=0 i=4 t=3 pr=2 a=50025 h=0 m=281/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > 255.255.255.255 255.255.255.255 10.6.1.160 p=0 i=5 t=3 pr=2 a=3924 h=0 m=270/0/0/0/0
. 2017.05.02 10:53:00 - OpenVPN > SYSTEM ADAPTER LIST
. 2017.05.02 10:53:00 - OpenVPN > Intel® Ethernet Connection I217-V
. 2017.05.02 10:53:00 - OpenVPN >   Index = 8
. 2017.05.02 10:53:00 - OpenVPN >   GUID = {342271DB-A110-43E2-887B-3F58B32C3A84}
. 2017.05.02 10:53:00 - OpenVPN >   IP = 192.168.0.2/255.255.255.0
. 2017.05.02 10:53:00 - OpenVPN >   MAC = e0:3f:49:7a:af:e7
. 2017.05.02 10:53:00 - OpenVPN >   GATEWAY = 192.168.0.1/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN >   DHCP SERV = 192.168.0.1/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 02 10:51:21 2017
. 2017.05.02 10:53:00 - OpenVPN >   DHCP LEASE EXPIRES  = Tue May 02 11:51:21 2017
. 2017.05.02 10:53:00 - OpenVPN >   DNS SERV = 68.105.28.11/255.255.255.255 68.105.29.11/255.255.255.255 68.105.28.12/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN > TAP-Windows Adapter V9
. 2017.05.02 10:53:00 - OpenVPN >   Index = 5
. 2017.05.02 10:53:00 - OpenVPN >   GUID = {38372446-12C5-4B31-9683-49DF24F1D2FE}
. 2017.05.02 10:53:00 - OpenVPN >   IP = 10.6.1.160/255.255.0.0
. 2017.05.02 10:53:00 - OpenVPN >   MAC = 00:ff:38:37:24:46
. 2017.05.02 10:53:00 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 02 10:53:00 2017
. 2017.05.02 10:53:00 - OpenVPN >   DHCP LEASE EXPIRES  = Tue May 02 10:53:00 2017
. 2017.05.02 10:53:00 - OpenVPN >   DNS SERV = 10.6.0.1/255.255.255.255
. 2017.05.02 10:53:00 - OpenVPN > VirtualBox Host-Only Ethernet Adapter
. 2017.05.02 10:53:00 - OpenVPN >   Index = 4
. 2017.05.02 10:53:00 - OpenVPN >   GUID = {196DB58D-CDCD-4DEC-95C9-9565144F0EB3}
. 2017.05.02 10:53:00 - OpenVPN >   IP = 169.254.102.105/255.255.0.0
. 2017.05.02 10:53:00 - OpenVPN >   MAC = 0a:00:27:00:00:04
. 2017.05.02 10:53:00 - OpenVPN > Qualcomm Atheros AR938x Wireless Network Adapter
. 2017.05.02 10:53:00 - OpenVPN >   Index = 6
. 2017.05.02 10:53:00 - OpenVPN >   GUID = {24DA5C1F-8AA0-44B0-9898-96BAEE93E28A}
. 2017.05.02 10:53:00 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2017.05.02 10:53:00 - OpenVPN >   MAC = 18:d6:c7:2b:01:cb
. 2017.05.02 10:53:00 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter
. 2017.05.02 10:53:00 - OpenVPN >   Index = 13
. 2017.05.02 10:53:00 - OpenVPN >   GUID = {7C6A8A1A-1A3B-4B3F-B306-A752BAB57AAC}
. 2017.05.02 10:53:00 - OpenVPN >   MAC = 1a:d6:c7:2b:01:cb
. 2017.05.02 10:53:00 - Starting Management Interface
. 2017.05.02 10:53:00 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2017.05.02 10:53:00 - Disconnecting
. 2017.05.02 10:53:00 - Management - Send 'signal SIGTERM'
. 2017.05.02 10:53:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.05.02 10:53:00 - DNS leak protection with packet filtering enabled.
. 2017.05.02 10:53:00 - DNS of a network adapter forced (Intel® Ethernet Connection I217-V, from automatic (68.105.28.11,68.105.29.11,68.105.28.12) to 10.6.0.1)
. 2017.05.02 10:53:00 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.6.0.1) to 10.6.0.1)
. 2017.05.02 10:53:00 - Flushing DNS
. 2017.05.02 10:53:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.05.02 10:53:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.05.02 10:53:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.05.02 10:53:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 104.254.90.242 MASK 255.255.255.255 192.168.0.1
. 2017.05.02 10:53:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.05.02 10:53:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.05.02 10:53:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.05.02 10:53:05 - OpenVPN > Closing TUN/TAP interface
. 2017.05.02 10:53:05 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.05.02 10:53:05 - Connection terminated.
. 2017.05.02 10:53:05 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection I217-V, to automatic)
. 2017.05.02 10:53:05 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.05.02 10:53:05 - DNS leak protection with packet filtering disabled.
I 2017.05.02 10:53:08 - Checking authorization ...
! 2017.05.02 10:53:08 - Connecting to Dheneb (Canada, Toronto, Ontario)
. 2017.05.02 10:53:08 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.05.02 10:53:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2017.05.02 10:53:08 - OpenVPN > library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
. 2017.05.02 10:53:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.05.02 10:53:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:53:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:53:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.21.149.44:80
. 2017.05.02 10:53:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2017.05.02 10:53:08 - OpenVPN > UDP link local: (not bound)
. 2017.05.02 10:53:08 - OpenVPN > UDP link remote: [AF_INET]199.21.149.44:80
. 2017.05.02 10:53:09 - OpenVPN > TLS: Initial packet from [AF_INET]199.21.149.44:80, sid=1515f5c4 c38dbe94
. 2017.05.02 10:53:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.05.02 10:53:09 - OpenVPN > Validating certificate key usage
. 2017.05.02 10:53:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.05.02 10:53:09 - OpenVPN > VERIFY KU OK
. 2017.05.02 10:53:09 - OpenVPN > Validating certificate extended key usage
. 2017.05.02 10:53:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.05.02 10:53:09 - OpenVPN > VERIFY EKU OK
. 2017.05.02 10:53:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.05.02 10:53:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.05.02 10:53:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.21.149.44:80
. 2017.05.02 10:53:10 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.05.02 10:53:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.69 255.255.0.0'
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.05.02 10:53:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.05.02 10:53:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.02 10:53:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:53:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.05.02 10:53:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.05.02 10:53:10 - OpenVPN > interactive service msg_channel=0
. 2017.05.02 10:53:10 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=8 HWADDR=e0:3f:49:7a:af:e7
. 2017.05.02 10:53:10 - OpenVPN > open_tun
. 2017.05.02 10:53:10 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{38372446-12C5-4B31-9683-49DF24F1D2FE}.tap
. 2017.05.02 10:53:10 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.05.02 10:53:10 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.69/255.255.0.0 [sUCCEEDED]
. 2017.05.02 10:53:10 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.69/255.255.0.0 on interface {38372446-12C5-4B31-9683-49DF24F1D2FE} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.05.02 10:53:10 - OpenVPN > Successful ARP Flush on interface [5] {38372446-12C5-4B31-9683-49DF24F1D2FE}
. 2017.05.02 10:53:10 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
! 2017.05.02 10:53:14 - Disconnecting
. 2017.05.02 10:53:14 - Connection terminated.
I 2017.05.02 10:53:15 - Cancel requested.
. 2017.05.02 10:53:15 - IPv6 restored with packet filtering.
. 2017.05.02 10:53:15 - Flushing DNS
! 2017.05.02 10:53:18 - Session terminated.
I think i found a temporary solution to my problem... i disabled Avast! firewall before i connected, then re-enabled it after i connected to Eddie. Idk why i've just now been having problems with it.. maybe it was because of the Windows update? I never had a problem with it before then.
