Not connected, Your IP: 216.73.216.161
necromaxim
Can't connect to AirVPN - OSx Sierra 10.12.4
I've updated my Mac to OSx 10.12.4 and now I can't connect to AirVPN. It keeps disconnecting and retrying.
Here's the log file:
I 2017.04.01 09:36:23 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.12.4 / x64
. 2017.04.01 09:36:23 - Reading options from /Users/ricardoferreira/.airvpn/AirVPN.xml
. 2017.04.01 09:36:23 - Data Path: /Users/ricardoferreira/.airvpn
. 2017.04.01 09:36:23 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2017.04.01 09:36:23 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2017.04.01 09:36:23 - Command line arguments (0):
. 2017.04.01 09:36:23 - Updating systems & servers data ...
. 2017.04.01 09:36:23 - Operating System: Unix 16.5.0.0 - Darwin Ricardos-iMac-2.home 16.5.0 Darwin Kernel Version 16.5.0: Fri Mar  3 16:52:33 PST 2017; root:xnu-3789.51.2~3/RELEASE_X86_64 x86_64
I 2017.04.01 09:36:23 - OpenVPN Driver - Expected
I 2017.04.01 09:36:23 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2017.04.01 09:36:23 - SSH - Version: OpenSSH_7.4p1, LibreSSL 2.5.0 (/usr/bin/ssh)
I 2017.04.01 09:36:23 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
I 2017.04.01 09:36:23 - Session starting.
I 2017.04.01 09:36:23 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2017.04.01 09:36:23 - IPv6 disabled on network adapter (Ethernet)
I 2017.04.01 09:36:23 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.04.01 09:36:24 - Systems & servers data update completed
I 2017.04.01 09:36:24 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2017.04.01 09:36:24 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2017.04.01 09:36:24 - Checking authorization ...
! 2017.04.01 09:36:24 - Connecting to Sheliak (Netherlands, Alblasserdam)
. 2017.04.01 09:36:24 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2017.04.01 09:36:24 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2017.04.01 09:36:24 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2017.04.01 09:36:24 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.04.01 09:36:24 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:36:24 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:36:24 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2017.04.01 09:36:24 - OpenVPN > UDPv4 link local: [undef]
. 2017.04.01 09:36:24 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.113:443
. 2017.04.01 09:36:24 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.113:443, sid=f9c1b4e6 c1447b3f
. 2017.04.01 09:36:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.01 09:36:24 - OpenVPN > Validating certificate key usage
. 2017.04.01 09:36:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.01 09:36:24 - OpenVPN > VERIFY KU OK
. 2017.04.01 09:36:24 - OpenVPN > Validating certificate extended key usage
. 2017.04.01 09:36:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.01 09:36:24 - OpenVPN > VERIFY EKU OK
. 2017.04.01 09:36:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.01 09:36:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:36:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:36:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:36:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:36:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.01 09:36:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.113:443
. 2017.04.01 09:36:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.01 09:36:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.111.249 255.255.0.0'
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.01 09:36:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.01 09:36:32 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.04.01 09:36:32 - OpenVPN > Opened utun device utun2
. 2017.04.01 09:36:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.04.01 09:36:32 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.04.01 09:36:32 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.04.01 09:36:32 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.04.01 09:36:32 - OpenVPN > /sbin/ifconfig utun2 10.4.111.249 10.4.111.249 netmask 255.255.0.0 mtu 1500 up
. 2017.04.01 09:36:32 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.111.249 255.255.0.0
. 2017.04.01 09:36:32 - OpenVPN > route: writing to routing socket: File exists
. 2017.04.01 09:36:32 - OpenVPN > add net 10.4.0.0: gateway 10.4.111.249: File exists
. 2017.04.01 09:36:32 - OpenVPN > /sbin/route add -net 213.152.162.113 192.168.1.1 255.255.255.255
. 2017.04.01 09:36:32 - OpenVPN > add net 213.152.162.113: gateway 192.168.1.1
. 2017.04.01 09:36:32 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:36:32 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:36:32 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:36:32 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:36:32 - Starting Management Interface
. 2017.04.01 09:36:32 - OpenVPN > Initialization Sequence Completed
I 2017.04.01 09:36:32 - DNS of a network adapter forced (Bluetooth DUN)
I 2017.04.01 09:36:32 - DNS of a network adapter forced (Ethernet)
I 2017.04.01 09:36:33 - DNS of a network adapter forced (Wi-Fi)
I 2017.04.01 09:36:33 - DNS of a network adapter forced (Bluetooth PAN)
I 2017.04.01 09:36:33 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2017.04.01 09:36:33 - Flushing DNS
I 2017.04.01 09:36:33 - Checking route
W 2017.04.01 09:37:23 - The request timed out
! 2017.04.01 09:37:23 - Disconnecting
. 2017.04.01 09:37:23 - Management - Send 'signal SIGTERM'
. 2017.04.01 09:37:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.04.01 09:37:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.01 09:37:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.04.01 09:37:28 - OpenVPN > /sbin/route delete -net 213.152.162.113 192.168.1.1 255.255.255.255
. 2017.04.01 09:37:28 - OpenVPN > delete net 213.152.162.113: gateway 192.168.1.1
. 2017.04.01 09:37:28 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:37:28 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:37:28 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:37:28 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:37:28 - OpenVPN > Closing TUN/TAP interface
. 2017.04.01 09:37:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.04.01 09:37:28 - Connection terminated.
I 2017.04.01 09:37:28 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2017.04.01 09:37:29 - DNS of a network adapter restored to original settings (Ethernet)
I 2017.04.01 09:37:29 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2017.04.01 09:37:29 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2017.04.01 09:37:29 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2017.04.01 09:37:30 - Cancel requested.
I 2017.04.01 09:37:30 - IPv6 restored on network adapter (Bluetooth DUN)
I 2017.04.01 09:37:30 - IPv6 restored on network adapter (Ethernet)
I 2017.04.01 09:37:30 - IPv6 restored on network adapter (Wi-Fi)
I 2017.04.01 09:37:30 - IPv6 restored on network adapter (Bluetooth PAN)
I 2017.04.01 09:37:30 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2017.04.01 09:37:30 - Session terminated.
! 2017.04.01 09:42:07 - Activation of Network Lock - OS X - PF
. 2017.04.01 09:42:08 - OS X - PF rules updated, reloading
I 2017.04.01 09:42:15 - Session starting.
I 2017.04.01 09:42:16 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2017.04.01 09:42:16 - IPv6 disabled on network adapter (Ethernet)
I 2017.04.01 09:42:16 - IPv6 disabled on network adapter (Wi-Fi)
I 2017.04.01 09:42:16 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2017.04.01 09:42:16 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2017.04.01 09:42:16 - Checking authorization ...
! 2017.04.01 09:42:16 - Connecting to Brachium (Spain, Valencia)
. 2017.04.01 09:42:16 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2017.04.01 09:42:16 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2017.04.01 09:42:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2017.04.01 09:42:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.04.01 09:42:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:42:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:42:16 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2017.04.01 09:42:16 - OpenVPN > UDPv4 link local: [undef]
. 2017.04.01 09:42:16 - OpenVPN > UDPv4 link remote: [AF_INET]95.215.62.91:443
. 2017.04.01 09:42:16 - OpenVPN > TLS: Initial packet from [AF_INET]95.215.62.91:443, sid=53e94c58 033ba9c8
. 2017.04.01 09:42:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.01 09:42:17 - OpenVPN > Validating certificate key usage
. 2017.04.01 09:42:17 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.01 09:42:17 - OpenVPN > VERIFY KU OK
. 2017.04.01 09:42:17 - OpenVPN > Validating certificate extended key usage
. 2017.04.01 09:42:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.01 09:42:17 - OpenVPN > VERIFY EKU OK
. 2017.04.01 09:42:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.01 09:42:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:42:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:42:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:42:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:42:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.01 09:42:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.215.62.91:443
. 2017.04.01 09:42:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.01 09:42:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.10 255.255.0.0'
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.01 09:42:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.01 09:42:19 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.04.01 09:42:19 - OpenVPN > Opened utun device utun2
. 2017.04.01 09:42:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.04.01 09:42:19 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.04.01 09:42:19 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.04.01 09:42:19 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.04.01 09:42:19 - OpenVPN > /sbin/ifconfig utun2 10.4.26.10 10.4.26.10 netmask 255.255.0.0 mtu 1500 up
. 2017.04.01 09:42:19 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.26.10 255.255.0.0
. 2017.04.01 09:42:19 - OpenVPN > route: writing to routing socket: File exists
. 2017.04.01 09:42:19 - OpenVPN > add net 10.4.0.0: gateway 10.4.26.10: File exists
. 2017.04.01 09:42:19 - OpenVPN > /sbin/route add -net 95.215.62.91 192.168.1.1 255.255.255.255
. 2017.04.01 09:42:19 - OpenVPN > add net 95.215.62.91: gateway 192.168.1.1
. 2017.04.01 09:42:19 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:42:19 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:42:19 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:42:19 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:42:19 - Starting Management Interface
. 2017.04.01 09:42:19 - OpenVPN > Initialization Sequence Completed
I 2017.04.01 09:42:20 - DNS of a network adapter forced (Bluetooth DUN)
I 2017.04.01 09:42:20 - DNS of a network adapter forced (Ethernet)
I 2017.04.01 09:42:20 - DNS of a network adapter forced (Wi-Fi)
I 2017.04.01 09:42:20 - DNS of a network adapter forced (Bluetooth PAN)
I 2017.04.01 09:42:20 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2017.04.01 09:42:20 - Flushing DNS
. 2017.04.01 09:42:20 - OS X - PF rules updated, reloading
I 2017.04.01 09:42:20 - Checking route
W 2017.04.01 09:43:10 - The request timed out
! 2017.04.01 09:43:10 - Disconnecting
. 2017.04.01 09:43:10 - Management - Send 'signal SIGTERM'
. 2017.04.01 09:43:10 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.01 09:43:10 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.04.01 09:43:10 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.04.01 09:43:15 - OpenVPN > /sbin/route delete -net 95.215.62.91 192.168.1.1 255.255.255.255
. 2017.04.01 09:43:15 - OpenVPN > delete net 95.215.62.91: gateway 192.168.1.1
. 2017.04.01 09:43:15 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:43:15 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:43:15 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:43:15 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:43:15 - OpenVPN > Closing TUN/TAP interface
. 2017.04.01 09:43:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.04.01 09:43:15 - Connection terminated.
I 2017.04.01 09:43:15 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2017.04.01 09:43:15 - DNS of a network adapter restored to original settings (Ethernet)
I 2017.04.01 09:43:15 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2017.04.01 09:43:15 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2017.04.01 09:43:15 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2017.04.01 09:43:18 - Checking authorization ...
! 2017.04.01 09:43:18 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2017.04.01 09:43:18 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2017.04.01 09:43:18 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2017.04.01 09:43:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2017.04.01 09:43:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.04.01 09:43:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:43:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:43:18 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2017.04.01 09:43:18 - OpenVPN > UDPv4 link local: [undef]
. 2017.04.01 09:43:18 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443
. 2017.04.01 09:43:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=ce1acc5a 7f7a0d5d
. 2017.04.01 09:43:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.04.01 09:43:19 - OpenVPN > Validating certificate key usage
. 2017.04.01 09:43:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.04.01 09:43:19 - OpenVPN > VERIFY KU OK
. 2017.04.01 09:43:19 - OpenVPN > Validating certificate extended key usage
. 2017.04.01 09:43:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.04.01 09:43:19 - OpenVPN > VERIFY EKU OK
. 2017.04.01 09:43:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.04.01 09:43:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:43:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:43:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.04.01 09:43:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.04.01 09:43:22 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.04.01 09:43:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443
. 2017.04.01 09:43:24 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.04.01 09:43:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.106.197 255.255.0.0'
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.04.01 09:43:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.04.01 09:43:24 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.04.01 09:43:24 - OpenVPN > Opened utun device utun2
. 2017.04.01 09:43:24 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.04.01 09:43:24 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.04.01 09:43:24 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.04.01 09:43:24 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.04.01 09:43:24 - OpenVPN > /sbin/ifconfig utun2 10.4.106.197 10.4.106.197 netmask 255.255.0.0 mtu 1500 up
. 2017.04.01 09:43:24 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.106.197 255.255.0.0
. 2017.04.01 09:43:24 - OpenVPN > route: writing to routing socket: File exists
. 2017.04.01 09:43:24 - OpenVPN > add net 10.4.0.0: gateway 10.4.106.197: File exists
. 2017.04.01 09:43:24 - OpenVPN > /sbin/route add -net 213.152.161.116 192.168.1.1 255.255.255.255
. 2017.04.01 09:43:24 - OpenVPN > add net 213.152.161.116: gateway 192.168.1.1
. 2017.04.01 09:43:24 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:43:24 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:43:24 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:43:24 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:43:24 - Starting Management Interface
. 2017.04.01 09:43:24 - OpenVPN > Initialization Sequence Completed
I 2017.04.01 09:43:24 - DNS of a network adapter forced (Bluetooth DUN)
I 2017.04.01 09:43:24 - DNS of a network adapter forced (Ethernet)
I 2017.04.01 09:43:24 - DNS of a network adapter forced (Wi-Fi)
I 2017.04.01 09:43:24 - DNS of a network adapter forced (Bluetooth PAN)
I 2017.04.01 09:43:24 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2017.04.01 09:43:24 - Flushing DNS
I 2017.04.01 09:43:25 - Checking route
W 2017.04.01 09:44:15 - The request timed out
! 2017.04.01 09:44:15 - Disconnecting
. 2017.04.01 09:44:15 - Management - Send 'signal SIGTERM'
. 2017.04.01 09:44:15 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.04.01 09:44:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.04.01 09:44:15 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.04.01 09:44:20 - OpenVPN > /sbin/route delete -net 213.152.161.116 192.168.1.1 255.255.255.255
. 2017.04.01 09:44:20 - OpenVPN > delete net 213.152.161.116: gateway 192.168.1.1
. 2017.04.01 09:44:20 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:44:20 - OpenVPN > delete net 0.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:44:20 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.04.01 09:44:20 - OpenVPN > delete net 128.0.0.0: gateway 10.4.0.1
. 2017.04.01 09:44:20 - OpenVPN > Closing TUN/TAP interface
. 2017.04.01 09:44:20 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.04.01 09:44:20 - Connection terminated.
I 2017.04.01 09:44:20 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2017.04.01 09:44:20 - DNS of a network adapter restored to original settings (Ethernet)
I 2017.04.01 09:44:20 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2017.04.01 09:44:20 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2017.04.01 09:44:20 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2017.04.01 09:44:21 - Cancel requested.
I 2017.04.01 09:44:21 - IPv6 restored on network adapter (Bluetooth DUN)
I 2017.04.01 09:44:21 - IPv6 restored on network adapter (Ethernet)
I 2017.04.01 09:44:21 - IPv6 restored on network adapter (Wi-Fi)
I 2017.04.01 09:44:21 - IPv6 restored on network adapter (Bluetooth PAN)
I 2017.04.01 09:44:21 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2017.04.01 09:44:21 - Session terminated.
! 2017.04.01 09:44:23 - Deactivation of Network Lock
Can anybody help me?
Thank you
Hallo and welcome,
Try the latest Eddie version 2.12.4 here: https://airvpn.org/macosx/
I have nothing to hide, but that's nobody's business!
Our society is run by insane people for insane objectives. I think we're being run by maniacs for maniacal ends and I think I'm liable to be put away as insane for expressing that. That's what's insane about it.
John Lennon
The further a society drift from truth the more it will hate those that speak it.
George Orwell
