joemama666
For guys having troubles with slow speeds on 2:11:15
Hey all
So i was one of the guys having problems with slow speeds after the update to 2.11.15.. No matter what i couldnt get above 1MB dl...Vs the 6MB(40 Mb) speeds i had before.. Did a reinstall of 2.11.15 and older versions--messed with settings--nothing helped..  Then saw a little message under the download link saying to have the latest .net version.. Got me to thinking so i went in and updated windows.. One of the updates was to the latest v of .net... decided to redo a fresh install of 2.11.15.. rebooted and boom... my speeds are back above 6MB and its very stable..so if your having a slowdown after the update to 2.11.15 try your updates and redo a fresh install of eddie and maybe youll have some success.. Hope this helps
add info
window 7 64bit ult
eddie 2.11.15
