vajravrtti
Error connecting through Kubuntu Network Monitor
I'm trying to connect to AirVPN through Network Manager in a Kubuntu 14.04 system, but I always get a “VPN plugin failed: 1” error message.
Even with the DEBUG option I couldn't find what is wrong.
<info> Starting VPN service 'openvpn'...
<info> VPN service 'openvpn' started (org.freedesktop.NetworkManager.openvpn), PID 2831
<info> VPN service 'openvpn' appeared; activating connections
<debug> [1486927751.762701] [nm-vpn-connection.c:1413] get_secrets(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/AirVPN_America_UDP-443) requesting VPN secrets pass #1
<debug> [1486927751.762775] [nm-agent-manager.c:1104] nm_agent_manager_get_secrets(): Secrets requested for connection /org/freedesktop/NetworkManager/Settings/1 (vpn)
<debug> [1486927751.762792] [nm-settings-connection.c:864] nm_settings_connection_get_secrets(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/vpn:2) secrets requested flags 0x80000004 hint '(null)'
<debug> [1486927751.763244] [nm-agent-manager.c:1019] get_start(): (0xf0b190/vpn) system settings secrets sufficient
<debug> [1486927751.763286] [nm-settings-connection.c:721] agent_secrets_done_cb(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/vpn:2) existing secrets returned
<debug> [1486927751.763308] [nm-settings-connection.c:727] agent_secrets_done_cb(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/vpn:2) secrets request completed
<debug> [1486927751.763776] [nm-settings-connection.c:767] agent_secrets_done_cb(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/vpn:2) new agent secrets processed
<debug> [1486927751.763789] [nm-vpn-connection.c:1379] get_secrets_cb(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/AirVPN_America_UDP-443) asking service if additional secrets are required
<debug> [1486927751.785041] [nm-vpn-connection.c:1349] plugin_need_secrets_cb(): (e605e7df-8936-4d9e-8099-17f69d0fe6dc/AirVPN_America_UDP-443) service indicated no additional secrets required
<info> VPN plugin state changed: starting (3)
<info> VPN connection 'AirVPN_America_UDP-443' (Connect) reply received.
<warn> VPN plugin failed: 1
<info> VPN plugin state changed: stopped (6)
<info> VPN plugin state change reason: 0
<debug> [1486927751.788185] [nm-dns-manager.c:1016] nm_dns_manager_begin_updates(): (vpn_connection_deactivated): queueing DNS updates (1)
<debug> [1486927751.788192] [nm-dns-manager.c:1016] nm_dns_manager_begin_updates(): (update_routing_and_dns): queueing DNS updates (2)
<info> Policy set 'Wired connection' (eth0) as default for IPv4 routing and DNS.
<debug> [1486927751.788260] [nm-dns-manager.c:1034] nm_dns_manager_end_updates(): (nm_dns_manager_end_updates): DNS configuration did not change
<debug> [1486927751.788266] [nm-dns-manager.c:1038] nm_dns_manager_end_updates(): (update_routing_and_dns): no DNS changes to commit (1)
<debug> [1486927751.788272] [nm-dns-manager.c:1034] nm_dns_manager_end_updates(): (nm_dns_manager_end_updates): DNS configuration did not change
<debug> [1486927751.788276] [nm-dns-manager.c:1038] nm_dns_manager_end_updates(): (vpn_connection_deactivated): no DNS changes to commit (0)
<debug> [1486927751.788282] [nm-policy.c:1111] process_secondaries(): Secondary connection 'AirVPN_America_UDP-443' FAILED; active path '/org/freedesktop/NetworkManager/ActiveConnection/2'
<warn> error disconnecting VPN: Could not process the request because no VPN connection was active.
<info> VPN service 'openvpn' disappeared
<debug> [1486927758.860257] [nm-vpn-service.c:274] ensure_killed(): waiting for VPN service pid 2831 to exit
<debug> [1486927758.860274] [nm-vpn-service.c:276] ensure_killed(): VPN service pid 2831 cleaned up
Seems to work on Kubuntu 16.10. Keys and certificates need to be included in the ovpn file though, otherwise the connection fails.
