yungdrilla2005
Linux Airvpn client not working - cant connect
Im a complete noob to this, but I can't connect at all, hope somebody can look through the logs and help
Thankyou
I 2017.02.13 15:21:57 - Eddie client version: 2.11.15 / linux_x64, System: Linux, Name: Ubuntu 14.04.5 LTS \n \l, Mono/.Net Framework: v4.0.30319
. 2017.02.13 15:21:57 - Reading options from /home/yungdrilla2005/.airvpn/AirVPN.xml
. 2017.02.13 15:22:00 - Data path: /home/yungdrilla2005/.airvpn
. 2017.02.13 15:22:00 - Application path: /usr/lib/AirVPN
. 2017.02.13 15:22:00 - Executable path: /usr/lib/AirVPN/AirVPN.exe
. 2017.02.13 15:22:00 - Command line arguments (1): path="/home/yungdrilla2005/.airvpn"
. 2017.02.13 15:22:00 - Operating System: Unix 3.10.18.0 - Linux localhost 3.10.18 #1 SMP Fri Jan 6 23:47:23 PST 2017 x86_64 x86_64 x86_64 GNU/Linux
I 2017.02.13 15:22:00 - OpenVPN Driver - Found, /dev/net/tun
I 2017.02.13 15:22:00 - OpenVPN - Version: 2.3.2 -  (/usr/sbin/openvpn)
I 2017.02.13 15:22:00 - SSH - Version: OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.8, OpenSSL 1.0.1f 6 Jan 2014 (/usr/bin/ssh)
I 2017.02.13 15:22:00 - SSL - Version: stunnel 4.53 (/usr/bin/stunnel4)
! 2017.02.13 15:22:00 - Ready
. 2017.02.13 15:22:00 - Updating systems & servers data ...
. 2017.02.13 15:22:05 - Systems & servers data update completed
I 2017.02.13 15:23:40 - Session starting.
. 2017.02.13 15:23:40 - Unable to understand if IPv6 is active.
I 2017.02.13 15:23:40 - Checking authorization ...
! 2017.02.13 15:23:41 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2017.02.13 15:23:41 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [IPv6] built on Dec  1 2014
. 2017.02.13 15:23:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.13 15:23:41 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.02.13 15:23:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:23:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:23:41 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.02.13 15:23:41 - OpenVPN > UDPv4 link local: [undef]
. 2017.02.13 15:23:41 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2017.02.13 15:23:41 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=3ba57e4a 6e459d08
. 2017.02.13 15:23:41 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.13 15:23:41 - OpenVPN > Validating certificate key usage
. 2017.02.13 15:23:41 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.13 15:23:41 - OpenVPN > VERIFY KU OK
. 2017.02.13 15:23:41 - OpenVPN > Validating certificate extended key usage
. 2017.02.13 15:23:41 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.13 15:23:41 - OpenVPN > VERIFY EKU OK
. 2017.02.13 15:23:41 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.13 15:23:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.13 15:23:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:23:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.13 15:23:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:23:46 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.02.13 15:23:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2017.02.13 15:23:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.02.13 15:23:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.68.177 255.255.0.0'
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.02.13 15:23:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.02.13 15:23:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=10:4a:7d:24:c8:27
. 2017.02.13 15:23:49 - OpenVPN > TUN/TAP device tun0 opened
. 2017.02.13 15:23:49 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.02.13 15:23:49 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.02.13 15:23:49 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.02.13 15:23:49 - OpenVPN > /sbin/ip addr add dev tun0 10.4.68.177/16 broadcast 10.4.255.255
! 2017.02.13 15:23:53 - Disconnecting
. 2017.02.13 15:23:53 - Connection terminated.
I 2017.02.13 15:23:53 - Cancel requested.
! 2017.02.13 15:23:53 - Session terminated.
I 2017.02.13 15:24:01 - Session starting.
. 2017.02.13 15:24:02 - Unable to understand if IPv6 is active.
I 2017.02.13 15:24:02 - Checking authorization ...
! 2017.02.13 15:24:02 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2017.02.13 15:24:02 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [IPv6] built on Dec  1 2014
. 2017.02.13 15:24:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.13 15:24:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.02.13 15:24:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:02 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.02.13 15:24:02 - OpenVPN > UDPv4 link local: [undef]
. 2017.02.13 15:24:02 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.4:443
. 2017.02.13 15:24:02 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.4:443, sid=64b32013 0c51dec5
. 2017.02.13 15:24:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.13 15:24:02 - OpenVPN > Validating certificate key usage
. 2017.02.13 15:24:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.13 15:24:02 - OpenVPN > VERIFY KU OK
. 2017.02.13 15:24:02 - OpenVPN > Validating certificate extended key usage
. 2017.02.13 15:24:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.13 15:24:02 - OpenVPN > VERIFY EKU OK
. 2017.02.13 15:24:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.02.13 15:24:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.13 15:24:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.02.13 15:24:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:03 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2017.02.13 15:24:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.107.4:443
. 2017.02.13 15:24:05 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.02.13 15:24:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.68.177 255.255.0.0'
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.02.13 15:24:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.02.13 15:24:05 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=10:4a:7d:24:c8:27
. 2017.02.13 15:24:05 - OpenVPN > Cannot find device "tun0"
! 2017.02.13 15:24:05 - Disconnecting
. 2017.02.13 15:24:05 - Connection terminated.
. 2017.02.13 15:24:05 - OpenVPN > TUN/TAP device tun0 opened
. 2017.02.13 15:24:05 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.02.13 15:24:05 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2017.02.13 15:24:05 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2017.02.13 15:24:05 - OpenVPN > Linux ip link set failed: external program exited with error status: 1
. 2017.02.13 15:24:05 - OpenVPN > Exiting due to fatal error
I 2017.02.13 15:24:09 - Checking authorization ...
! 2017.02.13 15:24:09 - Connecting to Alphard (Netherlands, Alblasserdam)
. 2017.02.13 15:24:09 - OpenVPN > OpenVPN 2.3.2 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [IPv6] built on Dec  1 2014
. 2017.02.13 15:24:09 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.02.13 15:24:09 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2017.02.13 15:24:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.02.13 15:24:09 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2017.02.13 15:24:09 - OpenVPN > UDPv4 link local: [undef]
. 2017.02.13 15:24:09 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.107.9:443
. 2017.02.13 15:24:09 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.9:443, sid=7385f62d 32133f76
. 2017.02.13 15:24:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.02.13 15:24:09 - OpenVPN > Validating certificate key usage
. 2017.02.13 15:24:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.02.13 15:24:09 - OpenVPN > VERIFY KU OK
. 2017.02.13 15:24:09 - OpenVPN > Validating certificate extended key usage
. 2017.02.13 15:24:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.02.13 15:24:09 - OpenVPN > VERIFY EKU OK
. 2017.02.13 15:24:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
! 2017.02.13 15:24:09 - Disconnecting
. 2017.02.13 15:24:10 - Connection terminated.
I 2017.02.13 15:24:10 - Cancel requested.
! 2017.02.13 15:24:10 - Session terminated.
