Not connected, Your IP: 216.73.216.90
ipleak.net displaying different country to eddie's connection ?
Hi, Have upgraded to latest Eddie 2.11.15 windows 7 x64, and I'm getting weird results from ipleak.net, it's telling me I'm in the UK when Eddie is saying I'm in the Netherlands. Even have the UK blocked in the countries list, as don't want to connect to them with the government being the way they are regards privacy etc. Seems strange to me and has never happened before, is anyone here able to give an explanation as to why this might be, and is it anything to be worried about, do I need to make any alterations to Eddie's settings, or anywhere else on my system. Have included screenshots (a pictures worth!) to help illustrate what I'm on about...
Thanks Mines
The server is still in the Netherlands, the geoip databases just have it marked incorrectly. You should have nothing to worry about, but if it would make you feel more comfortable then you can always use a different server.
Sent from my Pixel using Tapatalk
Thanks for the reassurance, was thinking I'd been infiltrated...... which sounds painful
