greenclaydog
Network Lock breaks sharing VPN over WiFi
So, i have attempted to use just about any hotspot software i can get my hands on, however it would seem the Network Lock prevents all hotspot software from communicating with their clients. The only way i can get it to work is if i turn off Network Lock.
I don't think my logs will be of any use here but since they are practically obligatory here they are
I 2017.01.06 19:01:22 - Eddie client version: 2.11.10 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727
. 2017.01.06 19:01:22 - Reading options from C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN\AirVPN.xml
. 2017.01.06 19:01:24 - Data path: C:\Users\M3CHWARRI0R935\AppData\Local\AirVPN
. 2017.01.06 19:01:24 - Application path: C:\Program Files\AirVPN
. 2017.01.06 19:01:24 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.01.06 19:01:24 - Command line arguments (1): path="home"
. 2017.01.06 19:01:24 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2017.01.06 19:01:28 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.01.06 19:01:28 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.01.06 19:01:28 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.01.06 19:01:28 - SSL - Version: stunnel 5.37 (C:\Program Files\AirVPN\stunnel.exe)
! 2017.01.06 19:01:31 - Activation of Network Lock - Windows Filtering Platform
. 2017.01.06 19:01:31 - Updating systems & servers data ...
I 2017.01.06 19:01:31 - Session starting.
. 2017.01.06 19:01:31 - IPv6 disabled with packet filtering.
I 2017.01.06 19:01:31 - Checking authorization ...
W 2017.01.06 19:01:31 - Authorization check failed, continue anyway ({1])
. 2017.01.06 19:01:31 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Unable to connect to the remote server)
! 2017.01.06 19:01:32 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:01:32 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:01:32 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:01:32 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:01:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:01:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:01:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:01:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:01:33 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:01:33 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:01:33 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:01:40 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=97ada8f2 4561ce32
. 2017.01.06 19:01:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:01:40 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:01:40 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:01:40 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:01:40 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:01:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:01:40 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:01:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:01:41 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:01:41 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:01:42 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:01:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:01:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:01:42 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:01:42 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:01:42 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:01:42 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:01:42 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:01:42 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:01:42 - OpenVPN > open_tun
. 2017.01.06 19:01:42 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:01:42 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:01:42 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:01:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:01:42 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:01:42 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:01:48 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:01:48 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:01:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:01:48 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:01:48 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:01:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:01:48 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:01:48 - Starting Management Interface
. 2017.01.06 19:01:48 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:01:48 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:01:49 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:01:49 - Flushing DNS
I 2017.01.06 19:01:56 - Checking DNS
! 2017.01.06 19:01:58 - Connected.
. 2017.01.06 19:01:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:01:58 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.01.06 19:08:03 - Disconnecting
. 2017.01.06 19:08:03 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:08:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:08:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:08:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:08:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:08:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:08:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:08:08 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:08:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:08:08 - Connection terminated.
. 2017.01.06 19:08:08 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:08:08 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:08:08 - IPv6 restored with packet filtering.
. 2017.01.06 19:08:08 - Flushing DNS
! 2017.01.06 19:08:15 - Session terminated.
I 2017.01.06 19:08:15 - Session starting.
. 2017.01.06 19:08:15 - IPv6 disabled with packet filtering.
I 2017.01.06 19:08:15 - Checking authorization ...
! 2017.01.06 19:08:16 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:08:41 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:08:41 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:08:41 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:08:41 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:08:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:08:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:08:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:08:41 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:08:41 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:08:41 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:08:41 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=09605be1 ae5a18de
. 2017.01.06 19:08:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:08:42 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:08:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:08:42 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:08:42 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:08:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:08:42 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:08:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:08:42 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:08:42 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:08:42 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:08:42 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:08:42 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:08:42 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:08:42 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:08:42 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:08:42 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:08:42 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:08:42 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:08:42 - OpenVPN > open_tun
. 2017.01.06 19:08:42 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:08:42 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:08:42 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:08:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:08:42 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:08:42 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:08:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:08:42 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:08:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:08:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:08:42 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:08:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:08:42 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:08:42 - Starting Management Interface
. 2017.01.06 19:08:42 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:08:42 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:08:42 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:08:42 - Flushing DNS
I 2017.01.06 19:08:48 - Checking DNS
! 2017.01.06 19:08:49 - Connected.
. 2017.01.06 19:08:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:08:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.01.06 19:10:48 - Disconnecting
. 2017.01.06 19:10:48 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:10:48 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:10:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:10:53 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:10:53 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:10:53 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:10:53 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:10:53 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:10:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:10:53 - Connection terminated.
. 2017.01.06 19:10:53 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:10:53 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:10:53 - IPv6 restored with packet filtering.
. 2017.01.06 19:10:53 - Flushing DNS
! 2017.01.06 19:11:00 - Session terminated.
! 2017.01.06 19:11:04 - Deactivation of Network Lock
I 2017.01.06 19:11:07 - Session starting.
. 2017.01.06 19:11:07 - IPv6 disabled with packet filtering.
I 2017.01.06 19:11:07 - Checking authorization ...
! 2017.01.06 19:11:08 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:11:08 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:11:08 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:11:08 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:11:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:11:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:11:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:11:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:11:08 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:11:08 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:11:08 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:11:08 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=c332fc76 5b394259
. 2017.01.06 19:11:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:11:08 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:11:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:11:08 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:11:08 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:11:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:11:08 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:11:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:11:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:11:09 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:11:09 - OpenVPN > Key [AF_INET]185.156.175.58:80 [0] not initialized (yet), dropping packet.
. 2017.01.06 19:11:11 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:11:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:11:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:11:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:11:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:11:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:11:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:11:11 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:11:11 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:11:11 - OpenVPN > open_tun
. 2017.01.06 19:11:11 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:11:11 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:11:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:11:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:11:11 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:11:11 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:11:16 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:11:16 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:11:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:11:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:11:16 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:11:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:11:16 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:11:16 - Starting Management Interface
. 2017.01.06 19:11:16 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:11:16 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:11:16 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:11:17 - Flushing DNS
I 2017.01.06 19:11:23 - Checking DNS
! 2017.01.06 19:11:24 - Connected.
. 2017.01.06 19:11:24 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:11:24 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 19:12:26 - Updating systems & servers data ...
. 2017.01.06 19:12:28 - Systems & servers data update completed
! 2017.01.06 19:14:46 - Disconnecting
. 2017.01.06 19:14:46 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:14:46 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:14:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:14:51 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:14:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:14:51 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:14:51 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:14:51 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:14:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:14:51 - Connection terminated.
. 2017.01.06 19:14:52 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:14:52 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:14:52 - IPv6 restored with packet filtering.
. 2017.01.06 19:14:52 - Flushing DNS
! 2017.01.06 19:14:58 - Session terminated.
! 2017.01.06 19:14:58 - Activation of Network Lock - Windows Filtering Platform
I 2017.01.06 19:15:03 - Session starting.
. 2017.01.06 19:15:03 - IPv6 disabled with packet filtering.
I 2017.01.06 19:15:03 - Checking authorization ...
! 2017.01.06 19:15:04 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:15:04 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:15:04 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:15:04 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:15:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:15:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:15:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:15:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:15:04 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:15:04 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:15:04 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:15:04 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=4ebfc2d3 104b8b78
. 2017.01.06 19:15:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:15:04 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:15:04 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:15:04 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:15:04 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:15:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:15:04 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:15:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:15:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:15:05 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:15:06 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:15:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:15:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:15:06 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:15:06 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:15:06 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:15:06 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:15:06 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:15:06 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:15:06 - OpenVPN > open_tun
. 2017.01.06 19:15:07 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:15:07 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:15:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:15:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:15:07 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:15:07 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:15:11 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:15:11 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:15:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:15:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:15:11 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:15:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:15:11 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:15:11 - Starting Management Interface
. 2017.01.06 19:15:11 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:15:11 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:15:11 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:15:12 - Flushing DNS
I 2017.01.06 19:15:18 - Checking DNS
! 2017.01.06 19:15:19 - Connected.
. 2017.01.06 19:15:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 19:15:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2017.01.06 19:17:09 - Disconnecting
. 2017.01.06 19:17:09 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:17:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:17:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:17:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:17:14 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:17:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:17:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:17:14 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:17:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:17:14 - Connection terminated.
. 2017.01.06 19:17:14 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:17:14 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:17:14 - IPv6 restored with packet filtering.
. 2017.01.06 19:17:15 - Flushing DNS
! 2017.01.06 19:17:21 - Session terminated.
! 2017.01.06 19:17:23 - Deactivation of Network Lock
! 2017.01.06 19:17:25 - Activation of Network Lock - Windows Firewall
I 2017.01.06 19:17:32 - Session starting.
. 2017.01.06 19:17:32 - IPv6 disabled with packet filtering.
I 2017.01.06 19:17:32 - Checking authorization ...
! 2017.01.06 19:17:33 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:17:33 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:17:33 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:17:33 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:17:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:17:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:17:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:17:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:17:33 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:17:33 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:17:33 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:17:33 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=552e02c2 84d26f81
. 2017.01.06 19:17:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:17:34 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:17:34 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:17:34 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:17:34 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:17:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:17:34 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:17:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:17:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:17:34 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:17:34 - OpenVPN > Key [AF_INET]185.156.175.58:80 [0] not initialized (yet), dropping packet.
. 2017.01.06 19:17:35 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:17:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:17:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:17:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:17:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:17:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:17:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:17:36 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:17:36 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:17:36 - OpenVPN > open_tun
. 2017.01.06 19:17:36 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:17:36 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:17:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:17:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:17:36 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:17:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:17:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:17:41 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:17:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:17:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:17:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:17:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:17:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:17:41 - Starting Management Interface
. 2017.01.06 19:17:41 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:17:41 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:17:41 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:17:42 - Flushing DNS
I 2017.01.06 19:17:49 - Checking DNS
! 2017.01.06 19:17:50 - Connected.
. 2017.01.06 19:17:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:17:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.01.06 19:19:11 - Disconnecting
. 2017.01.06 19:19:11 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:19:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:19:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:19:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:19:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:19:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:19:16 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:19:16 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:19:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:19:16 - Connection terminated.
. 2017.01.06 19:19:16 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:19:16 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:19:16 - IPv6 restored with packet filtering.
. 2017.01.06 19:19:17 - Flushing DNS
! 2017.01.06 19:19:23 - Session terminated.
! 2017.01.06 19:19:23 - Deactivation of Network Lock
I 2017.01.06 19:19:30 - Session starting.
. 2017.01.06 19:19:30 - IPv6 disabled with packet filtering.
I 2017.01.06 19:19:30 - Checking authorization ...
! 2017.01.06 19:19:30 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:19:31 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:19:31 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:19:31 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:19:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:19:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:19:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:19:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:19:31 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:19:31 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:19:31 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:19:31 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=7ea0d3cc f7c03b55
. 2017.01.06 19:19:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:19:31 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:19:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:19:31 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:19:31 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:19:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:19:31 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:19:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:19:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:19:31 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:19:33 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:19:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:19:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:19:33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:19:33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:19:33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:19:33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:19:33 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:19:33 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:19:33 - OpenVPN > open_tun
. 2017.01.06 19:19:33 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:19:33 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:19:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:19:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:19:33 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:19:33 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:19:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:19:38 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:19:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:19:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:19:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:19:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:19:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:19:38 - Starting Management Interface
. 2017.01.06 19:19:38 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:19:38 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:19:38 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:19:39 - Flushing DNS
I 2017.01.06 19:19:45 - Checking DNS
! 2017.01.06 19:19:46 - Connected.
. 2017.01.06 19:19:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:19:47 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2017.01.06 19:20:39 - Disconnecting
. 2017.01.06 19:20:39 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:20:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:20:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:20:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:20:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:20:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:20:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:20:44 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:20:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:20:44 - Connection terminated.
. 2017.01.06 19:20:45 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:20:45 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:20:45 - IPv6 restored with packet filtering.
. 2017.01.06 19:20:45 - Flushing DNS
! 2017.01.06 19:20:52 - Session terminated.
! 2017.01.06 19:20:52 - Activation of Network Lock - Windows Firewall
I 2017.01.06 19:20:57 - Session starting.
. 2017.01.06 19:20:57 - IPv6 disabled with packet filtering.
I 2017.01.06 19:20:57 - Checking authorization ...
! 2017.01.06 19:20:58 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:20:58 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:20:58 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:20:58 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:20:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:20:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:20:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:20:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:20:58 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:20:58 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:20:58 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:20:58 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=15cddf86 39f7c2b3
. 2017.01.06 19:20:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:20:58 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:20:58 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:20:58 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:20:58 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:20:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:20:58 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:20:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:20:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:20:59 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:21:00 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:21:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:21:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:21:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:21:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:21:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:21:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:21:00 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:21:00 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:21:00 - OpenVPN > open_tun
. 2017.01.06 19:21:01 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:21:01 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:21:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:21:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:21:01 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:21:01 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:21:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:21:05 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:21:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:21:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:21:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:21:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:21:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:21:05 - Starting Management Interface
. 2017.01.06 19:21:05 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:21:05 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:21:05 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:21:06 - Flushing DNS
I 2017.01.06 19:21:13 - Checking DNS
! 2017.01.06 19:21:13 - Connected.
. 2017.01.06 19:21:13 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:21:13 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 19:23:13 - Updating systems & servers data ...
. 2017.01.06 19:23:15 - Systems & servers data update completed
! 2017.01.06 19:24:43 - Disconnecting
. 2017.01.06 19:24:43 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:24:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:24:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:24:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:24:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:24:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:24:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:24:48 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:24:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:24:48 - Connection terminated.
. 2017.01.06 19:24:48 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:24:48 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:24:48 - IPv6 restored with packet filtering.
. 2017.01.06 19:24:48 - Flushing DNS
! 2017.01.06 19:24:55 - Session terminated.
I 2017.01.06 19:24:55 - Session starting.
. 2017.01.06 19:24:55 - IPv6 disabled with packet filtering.
I 2017.01.06 19:24:55 - Checking authorization ...
! 2017.01.06 19:24:56 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:24:56 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:24:56 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:24:56 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:24:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:24:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:24:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:24:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:24:56 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:24:56 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:24:56 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:24:56 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=30695779 652d0309
. 2017.01.06 19:24:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:24:59 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:24:59 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:24:59 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:24:59 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:24:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:24:59 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:24:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:24:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:24:59 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:25:00 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:25:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:25:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:25:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:25:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:25:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:25:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:25:00 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:25:00 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:25:00 - OpenVPN > open_tun
. 2017.01.06 19:25:01 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:25:01 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:25:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:25:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:25:01 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:25:01 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:25:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:25:05 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:25:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:25:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:25:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:25:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:25:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:25:05 - Starting Management Interface
. 2017.01.06 19:25:05 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:25:05 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:25:05 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:25:06 - Flushing DNS
I 2017.01.06 19:25:13 - Checking DNS
! 2017.01.06 19:25:14 - Connected.
. 2017.01.06 19:25:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:25:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 19:34:10 - Updating systems & servers data ...
. 2017.01.06 19:34:11 - Systems & servers data update completed
. 2017.01.06 19:44:42 - Updating systems & servers data ...
. 2017.01.06 19:44:44 - Systems & servers data update completed
! 2017.01.06 19:53:40 - Disconnecting
. 2017.01.06 19:53:40 - Management - Send 'signal SIGTERM'
. 2017.01.06 19:53:40 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.01.06 19:53:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.06 19:53:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:53:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.01.06 19:53:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:53:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:53:45 - OpenVPN > Closing TUN/TAP interface
. 2017.01.06 19:53:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.01.06 19:53:45 - Connection terminated.
. 2017.01.06 19:53:45 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR938x Wireless Network Adapter, to 75.114.81.1,75.114.81.2)
. 2017.01.06 19:53:45 - DNS leak protection with packet filtering disabled.
. 2017.01.06 19:53:45 - IPv6 restored with packet filtering.
. 2017.01.06 19:53:46 - Flushing DNS
! 2017.01.06 19:53:52 - Session terminated.
I 2017.01.06 19:53:55 - Session starting.
. 2017.01.06 19:53:56 - IPv6 disabled with packet filtering.
I 2017.01.06 19:53:56 - Checking authorization ...
! 2017.01.06 19:53:56 - Connecting to Sirrah (Switzerland, Zurich)
. 2017.01.06 19:53:56 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan  5 2017
. 2017.01.06 19:53:56 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.01.06 19:53:56 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 19:53:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.06 19:53:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:53:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:53:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.156.175.58:80
. 2017.01.06 19:53:57 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.01.06 19:53:57 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 19:53:57 - OpenVPN > UDP link remote: [AF_INET]185.156.175.58:80
. 2017.01.06 19:53:57 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.175.58:80, sid=1a676dc1 0cade5da
. 2017.01.06 19:53:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 19:53:57 - OpenVPN > Validating certificate key usage
. 2017.01.06 19:53:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 19:53:57 - OpenVPN > VERIFY KU OK
. 2017.01.06 19:53:57 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 19:53:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 19:53:57 - OpenVPN > VERIFY EKU OK
. 2017.01.06 19:53:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sirrah, emailAddress=info@airvpn.org
. 2017.01.06 19:53:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 19:53:57 - OpenVPN > [sirrah] Peer Connection Initiated with [AF_INET]185.156.175.58:80
. 2017.01.06 19:53:58 - OpenVPN > Key [AF_INET]185.156.175.58:80 [0] not initialized (yet), dropping packet.
. 2017.01.06 19:53:58 - OpenVPN > SENT CONTROL [sirrah]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 19:53:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.6.0.1,comp-lzo no,route-gateway 10.6.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.6.0.5 255.255.0.0'
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 19:53:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 19:53:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:53:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:53:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 19:53:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 19:53:58 - OpenVPN > interactive service msg_channel=0
. 2017.01.06 19:53:58 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=11 HWADDR=84:16:f9:b9:03:13
. 2017.01.06 19:53:58 - OpenVPN > open_tun
. 2017.01.06 19:53:59 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{A9572F90-A8CE-4C5E-A1F6-473B52AC037D}.tap
. 2017.01.06 19:53:59 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.01.06 19:53:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.6.0.0/10.6.0.5/255.255.0.0 [sUCCEEDED]
. 2017.01.06 19:53:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.6.0.5/255.255.0.0 on interface {A9572F90-A8CE-4C5E-A1F6-473B52AC037D} [DHCP-serv: 10.6.255.254, lease-time: 31536000]
. 2017.01.06 19:53:59 - OpenVPN > Successful ARP Flush on interface [12] {A9572F90-A8CE-4C5E-A1F6-473B52AC037D}
. 2017.01.06 19:53:59 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 19:54:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.01.06 19:54:03 - OpenVPN > C:\Windows\system32\route.exe ADD 185.156.175.58 MASK 255.255.255.255 192.168.0.1
. 2017.01.06 19:54:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2017.01.06 19:54:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.01.06 19:54:03 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:54:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.01.06 19:54:03 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.6.0.1
. 2017.01.06 19:54:03 - Starting Management Interface
. 2017.01.06 19:54:03 - OpenVPN > Initialization Sequence Completed
. 2017.01.06 19:54:03 - DNS leak protection with packet filtering enabled.
. 2017.01.06 19:54:03 - DNS of a network adapter forced (Qualcomm Atheros AR938x Wireless Network Adapter, from manual (75.114.81.1,75.114.81.2) to 10.6.0.1)
. 2017.01.06 19:54:04 - Flushing DNS
I 2017.01.06 19:54:11 - Checking DNS
! 2017.01.06 19:54:12 - Connected.
. 2017.01.06 19:54:12 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.01.06 19:54:12 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.01.06 19:54:44 - Updating systems & servers data ...
. 2017.01.06 19:54:46 - Systems & servers data update completed
I do not know how the network lock functions and why it would cause a problem here, but i know some people here do. I will also submit a ticket in case no one has a clue either.
Side note: Could a setting in Eddie be causing this instead?
