rustintimberlake
Problems with UK sites
UPDATE: after about 20 hours the UK sites are working again. Very odd.
UPDATE 2: seems to be happening again. Only happens over vpn too.
UPDATE 3: opened a ticket with support. Thinking if I should factory reset pfSense and redo 'pfSense_fan' tutorial, but that's a bit drastic. We'll see after support's response.
Starting from today there's been problems try to reach .co.uk sites and a few .com sites. But mostly .co.uk sites.
I have a pfsense firewall setup as per pfSense_fan's instructions and was working great but from today I cannot connect to any sites with .co.uk domain.
I have tried a different Netherland server but it's still the same problem.
Anyone else noticed this?
Jan 4 16:05:50 	openvpn 	12912 	OpenVPN 2.3.11 i386-portbld-freebsd10.3 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Jul 19 2016
Jan 4 16:05:50 	openvpn 	12912 	library versions: OpenSSL 1.0.1s-freebsd 1 Mar 2016, LZO 2.09
Jan 4 16:05:50 	openvpn 	13839 	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1.sock
Jan 4 16:05:50 	openvpn 	13839 	mlockall call succeeded
Jan 4 16:05:50 	openvpn 	13839 	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jan 4 16:05:50 	openvpn 	13839 	Control Channel Authentication: using '/var/etc/openvpn/client1.tls-auth' as a OpenVPN static key file
Jan 4 16:05:50 	openvpn 	13839 	Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 4 16:05:50 	openvpn 	13839 	Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 4 16:05:50 	openvpn 	13839 	Socket Buffers: R=[42080->42080] S=[57344->57344]
Jan 4 16:05:50 	openvpn 	13839 	UDPv4 link local (bound): [AF_INET]192.168.0.11
Jan 4 16:05:50 	openvpn 	13839 	UDPv4 link remote: [AF_INET]213.152.161.180:443
Jan 4 16:05:50 	openvpn 	13839 	TLS: Initial packet from [AF_INET]213.152.161.180:443, sid=d9309ea5 826050a5
Jan 4 16:05:51 	openvpn 	13839 	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Jan 4 16:05:51 	openvpn 	13839 	VERIFY OK: nsCertType=SERVER
Jan 4 16:05:51 	openvpn 	13839 	Validating certificate key usage
Jan 4 16:05:51 	openvpn 	13839 	++ Certificate has key usage 00a0, expects 00a0
Jan 4 16:05:51 	openvpn 	13839 	VERIFY KU OK
Jan 4 16:05:51 	openvpn 	13839 	Validating certificate extended key usage
Jan 4 16:05:51 	openvpn 	13839 	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jan 4 16:05:51 	openvpn 	13839 	VERIFY EKU OK
Jan 4 16:05:51 	openvpn 	13839 	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Jan 4 16:05:54 	openvpn 	13839 	Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Jan 4 16:05:54 	openvpn 	13839 	Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 4 16:05:54 	openvpn 	13839 	Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Jan 4 16:05:54 	openvpn 	13839 	Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jan 4 16:05:54 	openvpn 	13839 	Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Jan 4 16:05:54 	openvpn 	13839 	[server] Peer Connection Initiated with [AF_INET]213.152.161.180:443
Jan 4 16:05:57 	openvpn 	13839 	SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Jan 4 16:05:57 	openvpn 	13839 	PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.8 255.255.0.0'
Jan 4 16:05:57 	openvpn 	13839 	Options error: option 'redirect-gateway' cannot be used in this context ([PUSH-OPTIONS])
Jan 4 16:05:57 	openvpn 	13839 	Options error: option 'dhcp-option' cannot be used in this context ([PUSH-OPTIONS])
Jan 4 16:05:57 	openvpn 	13839 	OPTIONS IMPORT: timers and/or timeouts modified
Jan 4 16:05:57 	openvpn 	13839 	OPTIONS IMPORT: LZO parms modified
Jan 4 16:05:57 	openvpn 	13839 	OPTIONS IMPORT: --ifconfig/up options modified
Jan 4 16:05:57 	openvpn 	13839 	OPTIONS IMPORT: route-related options modified
Jan 4 16:05:57 	openvpn 	13839 	TUN/TAP device ovpnc1 exists previously, keep at program end
Jan 4 16:05:57 	openvpn 	13839 	TUN/TAP device /dev/tun1 opened
Jan 4 16:05:57 	openvpn 	13839 	ioctl(TUNSIFMODE): Device busy: Device busy (errno=16)
Jan 4 16:05:57 	openvpn 	13839 	do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Jan 4 16:05:57 	openvpn 	13839 	/sbin/ifconfig ovpnc1 10.4.0.8 10.4.0.1 mtu 1500 netmask 255.255.0.0 up
Jan 4 16:05:57 	openvpn 	13839 	/sbin/route add -net 10.4.0.0 10.4.0.8 255.255.0.0
Jan 4 16:05:57 	openvpn 	13839 	/usr/local/sbin/ovpn-linkup ovpnc1 1500 1558 10.4.0.8 255.255.0.0 init
Jan 4 16:05:57 	openvpn 	13839 	Initialization Sequence Completed
