routeninja
IRC or XMPP channel?
I am trying to see if AVPN has a lounge or something? I found some old posts about possibly doing it on Freenode, then XMPP, then something else? Did anything ever materialise from that?
if yer on irssi:
airvpn xmpp used as example.../load xmpp/load otr/set timestamps off/set use_msgs_window off/set autocreate_query_level none/set autolog off/set window_history off/xmppconnect sumfuknic@xmpp.airvpn.orgenter pass/join lounge@conference.xmpp.airvpn.org/clear/n/q userz_nik/otr init userz_nikto gen key.../otr genkey sumfuknic@xmpp.airvpn.orgto set secret question.../otr authq [who farted ?] u_didto auth with secret answer/otr auth sharedanswer/otr trust/otr finish/wcleave channel/partshow prints:/otr info check stuff/otr contextsirssi_scriptz--->>>show loaded scripts:/scriptload a script:/script load xyz.plunload a script:/script unload xyz.plrun script once:/script exec xyz.pl
had help from another member here with that myself
so credz to the anon
