1337oxide
Does network lock disable routes?
So I have two virtual machines.
One of the virtual machines has the VPN on all the time with a route (outside of VPN) to the second one. This allows me to directly connect to the box only from that machine which has a static IP.
I can then only log into the first machine via the second. This is working currently but I would like to know if activating the network lock will disable the routing ?
Cheers.
Depends which IP addresses you use. The rules are not really related to routing and are enforced before that.
You can tick the "Allow lan/private" checkbox in 2.11.5 and if you use private IPs, you will still be able to connect.
