Not connected, Your IP: 216.73.216.169
goftari
Using AirVPN with iPhone
Download and install an OpenVPN client (GuizmOVPN) for iPhone; Here's how:
1 - Open Cydia and go to the "Manage" tab and click on "Sources"
Posted Image
2 - Click on "Edit" then "Add"
Posted Image
3 - Enter the url : http://cydia.guizmovpn.com and click on "Add source"
Posted Image
4 - Click on "Done" then click on the newly added source ("cydia.guizmovpn.com")
Posted Image
5 - Select "com.guizmo.openvpn"
Posted Image
6 - Click on "Install" and "Confirm".
Posted Image
After few seconds, you should see a new icon on your springboard called "GuizmOVPN"...
Once installed, transfer configuration to your device using the web server:
1 - On the device, run OpenVPN, go in the "Settings" tab and activate the web server
Posted Image
2 - Now, go back to your computer, open your favorite browser and go to your web server address.
Posted Image
3 - Click on "Choisissez un fichier" or any translation of that depending on your language,
and select the zip file containing your generated AirVPN configuration
Posted Image
4 - Click on "Submit", if all goes well, you should now see your certificate in the list. You will be able to remove it by clicking on the trash icon.
Posted Image
5 - Go back to your device, in the "General" tab. You now see the configuration you just uploaded. Select it.
http://www.guizmovpn.com/images/5_select_configuration.jpg
You can open or close the tunnel by using the "Connect" switch.
The log can be displayed in the "Log" tab.
Hi! I am having problems to intall cydia.guizmovppn, I did it but this message when I was adding the source:
NetDB: Open nodename nor servname provided, or not known
then this one showed:
HTTP/1.1 404 Not found
Failed to fetch http://cydia.hackulo.us/./Realease.gpg
Failed to fetch
http://cydia.xsellize.com/ ./Packages.gz HTTP/1.1 404 Not found
Can you help plz
FYI: There is now an official OpenVPN app on the App Store, no need for Jailbreaks anymore.
