Oksana Luda
Help with AirVPN Client on Solus Os Linux
Hi AirVPN
Im a user at Solus OS Linux
Website: https://solus-project.com/
Im trying to use the Airvpn client on Solus Os but no success, any chance of fixing this and provide a tarball file.
I did file a package request but was denied due that there is no valid release tarball or zip file for the source.
Check here https://dev.solus-project.com/T492
Solus
Solus Operating System is an Linux Distribution built from scratch that's using a new desktop environment called Budgie Desktop,
Open Source: https://github.com/solus-project
You can try using the portable version. This is the only thing the developer said which makes sense.
Without a valid release tarball or zip file for the source, this will not be packaged. It's not enough for the source to just be on git.
This is a hilarious statement. I'm not sure I would like to use a distribution from such a developer, though. Who knows when something
else is going to be broken or will require patching. Many drivers and other sources are on git and it's seems like not enough for him to get things done.
Feedback from the Awesome owner of Solus, Can this be done please..
They only have to create a git tag and we can take it from there. This is such a fundamental part of software development and release practices.
You create an immutable point in history, and we package that specific, tested, version. We can ship git versions of packages, and in quite
a few places we do, but this demonstrated disdain for versioning and proper releases makes it, at present, very unattractive.
Once they throw a git tag up on GitHub (all of 2 commands in a terminal) we can reassess this.
Yeah, it'd be great since no portable version seems working on my system, both Mono and normal release, as well as Stable and 2.11b5. Here's the error I get from the Portable version, beta, (no mono):
I 2016.10.28 15:18:05 - Eddie client version: 2.11.5 / linux_x64, System: Linux, Name: [[ Solus Operating System ]]
. 2016.10.28 15:18:05 - Reading options from /home/[...]/eddie-ui_2.11_linux_x64_portable/AirVPN.xml
. 2016.10.28 15:18:05 - Profile options not found, using defaults.
. 2016.10.28 15:18:06 - Data Path: /home/[...]/eddie-ui_2.11_linux_x64_portable
. 2016.10.28 15:18:06 - App Path: /home[...]/eddie-ui_2.11_linux_x64_portable
. 2016.10.28 15:18:06 - Executable Path: /home[...]/eddie-ui_2.11_linux_x64_portable/airvpn
. 2016.10.28 15:18:06 - Command line arguments (0):
. 2016.10.28 15:18:06 - Operating System: Unix 4.8.4.0 - Linux [...] 4.8.4 #1 SMP Sat Oct 22 20:39:16 UTC 2016 x86_64 GNU/Linux
I 2016.10.28 15:18:06 - OpenVPN Driver - Found, /dev/net/tun
I 2016.10.28 15:18:06 - OpenVPN - Version: OpenVPN 2.3.12 (/home/[...]/eddie-ui_2.11_linux_x64_portable/openvpn)
I 2016.10.28 15:18:06 - SSH - Version: OpenSSH_7.3p1, OpenSSL 1.0.2j  26 Sep 2016 (/usr/bin/ssh)
I 2016.10.28 15:18:06 - SSL - Version: stunnel 5.32 (/home/[...]/eddie-ui_2.11_linux_x64_portable/stunnel)
! 2016.10.28 15:18:06 - Ready
. 2016.10.28 15:18:06 - Updating systems & servers data ...
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'Mono.Unix.Native.Syscall' threw an exception. ---> System.DllNotFoundException: /usr/lib64/libMonoPosixHelper.so
  at (wrapper managed-to-native) Mono.Unix.Native.Syscall:get_at_fdcwd ()
  at Mono.Unix.Native.Syscall..cctor () [0x0000a] in <34b68016c17845bba60316001d489522>:0
   --- End of inner exception stack trace ---
  at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue, System.Boolean allowIdle) [0x00117] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue) [0x00000] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.XplatUIX11.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr handle, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00022] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.XplatUI.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.Application.RunLoop (System.Boolean Modal, System.Windows.Forms.ApplicationContext context) [0x003e9] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext context) [0x00014] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at System.Windows.Forms.Application.Run (System.Windows.Forms.Form mainForm) [0x00006] in <5d999439b3404adfac86e7eebb5f00d6>:0
  at Eddie.UI.Linux.Program.Main () [0x00086] in <e4296a97969a4ae491a778564ae29acf>:0
EDIT: it actually works now, but it needs the mono-devel package, even though it's the non-mono Portable version
