Aspisoph
Having trouble connecting
  As above I am having trouble connecting using the Eddie Client. Sometimes it connects, then the next time it won't connect on the same server with the same settings. It seems to behave in a random manner.
. 2016.09.16 20:43:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.35.211 255.255.0.0'
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.16 20:43:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.16 20:43:31 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eno1 HWADDR=f0:79:59:dd:c4:a3
. 2016.09.16 20:43:31 - OpenVPN > TUN/TAP device tun0 opened
. 2016.09.16 20:43:31 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.09.16 20:43:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.09.16 20:43:31 - OpenVPN > /sbin/ifconfig tun0 10.4.35.211 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.09.16 20:43:36 - OpenVPN > /sbin/route add -net 71.19.252.113 netmask 255.255.255.255 gw 192.168.0.1
. 2016.09.16 20:43:36 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.09.16 20:43:36 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.09.16 20:43:36 - Starting Management Interface
. 2016.09.16 20:43:36 - OpenVPN > Initialization Sequence Completed
I 2016.09.16 20:43:36 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.09.16 20:43:36 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.09.16 20:43:36 - Flushing DNS
I 2016.09.16 20:43:36 - Checking route
I 2016.09.16 20:43:38 - Checking DNS
E 2016.09.16 20:43:39 - DNS checking failed.
. 2016.09.16 20:43:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2016.09.16 20:43:39 - Disconnecting
. 2016.09.16 20:43:39 - Management - Send 'signal SIGTERM'
. 2016.09.16 20:43:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.09.16 20:43:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.09.16 20:43:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.09.16 20:43:44 - OpenVPN > /sbin/route del -net 71.19.252.113 netmask 255.255.255.255
. 2016.09.16 20:43:44 - OpenVPN > /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
. 2016.09.16 20:43:44 - OpenVPN > /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
. 2016.09.16 20:43:44 - OpenVPN > Closing TUN/TAP interface
. 2016.09.16 20:43:44 - OpenVPN > /sbin/ifconfig tun0 0.0.0.0
. 2016.09.16 20:43:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.09.16 20:43:44 - Connection terminated.
I 2016.09.16 20:43:44 - DNS of the system restored to original settings (Rename method)
I 2016.09.16 20:43:46 - Cancel requested.
! 2016.09.16 20:43:46 - Session terminated.
! 2016.09.16 20:44:20 - Deactivation of Network Lock
I 2016.09.16 20:44:25 - Session starting.
W 2016.09.16 20:44:26 - Unable to understand if IPv6 is active.
I 2016.09.16 20:44:26 - Checking authorization ...
! 2016.09.16 20:44:26 - Connecting to Mimosa (Canada, Vancouver)
. 2016.09.16 20:44:26 - OpenVPN > OpenVPN 2.3.11 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on May 19 2016
. 2016.09.16 20:44:26 - OpenVPN > library versions: OpenSSL 1.0.2h  3 May 2016, LZO 2.09
. 2016.09.16 20:44:26 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.09.16 20:44:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.09.16 20:44:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.16 20:44:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.16 20:44:26 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2016.09.16 20:44:26 - OpenVPN > UDPv4 link local: [undef]
. 2016.09.16 20:44:26 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.251.247:443
. 2016.09.16 20:44:27 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.251.247:443, sid=ee15f044 f1be4b15
. 2016.09.16 20:44:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.09.16 20:44:27 - OpenVPN > Validating certificate key usage
. 2016.09.16 20:44:27 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.09.16 20:44:27 - OpenVPN > VERIFY KU OK
. 2016.09.16 20:44:27 - OpenVPN > Validating certificate extended key usage
. 2016.09.16 20:44:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.09.16 20:44:27 - OpenVPN > VERIFY EKU OK
. 2016.09.16 20:44:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.09.16 20:44:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.16 20:44:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.16 20:44:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.16 20:44:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.16 20:44:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.09.16 20:44:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.251.247:443
. 2016.09.16 20:44:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.09.16 20:44:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.36.224 255.255.0.0'
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.16 20:44:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.16 20:44:30 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eno1 HWADDR=f0:79:59:dd:c4:a3
. 2016.09.16 20:44:30 - OpenVPN > TUN/TAP device tun0 opened
. 2016.09.16 20:44:30 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.09.16 20:44:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.09.16 20:44:30 - OpenVPN > /sbin/ifconfig tun0 10.4.36.224 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.09.16 20:44:35 - OpenVPN > /sbin/route add -net 71.19.251.247 netmask 255.255.255.255 gw 192.168.0.1
. 2016.09.16 20:44:35 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.09.16 20:44:35 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.09.16 20:44:35 - Starting Management Interface
. 2016.09.16 20:44:35 - OpenVPN > Initialization Sequence Completed
I 2016.09.16 20:44:35 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.09.16 20:44:35 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.09.16 20:44:35 - Flushing DNS
I 2016.09.16 20:44:35 - Checking route
I 2016.09.16 20:44:37 - Checking DNS
E 2016.09.16 20:44:38 - DNS checking failed.
. 2016.09.16 20:44:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2016.09.16 20:44:38 - Disconnecting
. 2016.09.16 20:44:38 - Management - Send 'signal SIGTERM'
. 2016.09.16 20:44:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.09.16 20:44:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.09.16 20:44:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.09.16 20:44:43 - OpenVPN > /sbin/route del -net 71.19.251.247 netmask 255.255.255.255
. 2016.09.16 20:44:43 - OpenVPN > /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
. 2016.09.16 20:44:43 - OpenVPN > /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
. 2016.09.16 20:44:43 - OpenVPN > Closing TUN/TAP interface
. 2016.09.16 20:44:43 - OpenVPN > /sbin/ifconfig tun0 0.0.0.0
. 2016.09.16 20:44:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.09.16 20:44:43 - Connection terminated.
I 2016.09.16 20:44:43 - DNS of the system restored to original settings (Rename method)
I 2016.09.16 20:44:46 - Cancel requested.
! 2016.09.16 20:44:46 - Session terminated.
I 2016.09.16 20:46:51 - Break signal received. Shutdown. Hit again to force break.
Try disabling the DNS checks.
Thanks for the suggestion will try it in future.
Something I've been doing with success if it fails to connect, is shutting the client down completely and then restarting it. If I do that it has connected me immediately the last couple of days. The only issue I've noticed is there are DNS leaks the first couple of times I get a connection with the network lock on. So I shut it down and restart until the leaks are no longer detected.
giganerd
Restarting wasn't working this time, so I unchecked the 'Check AirVPN DNS:' setting and it got past that failure.
So it is doing what I do when I go to https://ipleak.net/ I just want to be sure it is safe to surf.
I
