anderstn
Need help debugging while connecting to germany via connection manager
Hi
Using a fresh install of Linux Mint and trying to connect to german VPN servers via the connection manager something is wrong. As far as I can tell the issue is routing related as I can ping the endpoints public address and my own internal address but not the internal tunnel gateway/DNS server.
I have attached the relevant parts of the syslog as well as my current routing table. The machine itself is a virtualbox vm running on windows 10 with a bridged network adapter.
syslog:
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: <info>  [1473856385.7505] audit: op="connection-activate" uuid="0d15c288-97d4-4926-a3c8-724bc867af72" name="AirVPN_Germany_UDP-2018" pid=2579 uid=1000 result="success"
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: <info>  [1473856385.7556] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",0]: Started the VPN service, PID 10505
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: <info>  [1473856385.7725] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",0]: Saw the service appear; activating connection
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: nm-openvpn-Message: openvpn[10509] started
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: <info>  [1473856385.7903] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",0]: VPN plugin: state changed: starting (3)
Sep 14 14:33:05 anders-VirtualBox NetworkManager[1615]: <info>  [1473856385.7904] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",0]: VPN connection: (ConnectInteractive) reply received
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: OpenVPN 2.3.10 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Feb  2 2016
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: library versions: OpenSSL 1.0.2g-fips  1 Mar 2016, LZO 2.08
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: WARNING: file '/media/sf_torrent-vm/user.key' is group or others accessible
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: WARNING: file '/media/sf_torrent-vm/ta.key' is group or others accessible
Sep 14 14:33:05 anders-VirtualBox nm-openvpn[10509]: Control Channel Authentication: using '/media/sf_torrent-vm/ta.key' as a OpenVPN static key file
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: NOTE: chroot will be delayed because of --client, --pull, or --up-delay
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: UDPv4 link local: [undef]
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: UDPv4 link remote: [AF_INET]178.162.198.102:2018
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1557', remote='link-mtu 1558'
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: WARNING: 'comp-lzo' is present in remote config but missing in local config, remote='comp-lzo'
Sep 14 14:33:06 anders-VirtualBox nm-openvpn[10509]: [server] Peer Connection Initiated with [AF_INET]178.162.198.102:2018
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: TUN/TAP device tun0 opened
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9033] manager: (tun0): new Tun device (/org/freedesktop/NetworkManager/Devices/7)
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: /usr/lib/NetworkManager/nm-openvpn-service-openvpn-helper --bus-name org.freedesktop.NetworkManager.openvpn.Connection_11 --tun -- tun0 1500 1557 10.30.0.132 255.255.0.0 init
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9119] devices added (path: /sys/devices/virtual/net/tun0, iface: tun0)
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9119] device added (path: /sys/devices/virtual/net/tun0, iface: tun0): no ifupdown configuration found.
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9200] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",0]: VPN connection: (IP Config Get) reply received.
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9215] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: VPN connection: (IP4 Config Get) reply received
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9224] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data: VPN Gateway: 178.162.198.102
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9226] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data: Tunnel Device: tun0
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9227] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data: IPv4 configuration:
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9228] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Internal Gateway: 10.30.0.1
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9229] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Internal Address: 10.30.0.132
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9231] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Internal Prefix: 16
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9234] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Internal Point-to-Point Address: 10.30.0.132
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9236] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Maximum Segment Size (MSS): 0
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9237] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Forbid Default Route: no
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9239] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   Internal DNS: 10.30.0.1
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9241] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data:   DNS Domain: '(none)'
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9243] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: Data: No IPv6 configuration
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9245] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: VPN plugin: state changed: started (4)
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: chroot to '/var/lib/openvpn/chroot' and cd to '/' succeeded
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: GID set to nm-openvpn
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: UID set to nm-openvpn
Sep 14 14:33:08 anders-VirtualBox nm-openvpn[10509]: Initialization Sequence Completed
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9271] vpn-connection[0x28385c0,0d15c288-97d4-4926-a3c8-724bc867af72,"AirVPN_Germany_UDP-2018",8:(tun0)]: VPN connection: (IP Config Get) complete
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9280] device (tun0): state change: unmanaged -> unavailable (reason 'connection-assumed') [10 20 41]
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9326] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9345] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9369] dns-mgr: Writing DNS information to /sbin/resolvconf
Sep 14 14:33:08 anders-VirtualBox dnsmasq[2220]: setting upstream servers from DBus
Sep 14 14:33:08 anders-VirtualBox dnsmasq[2220]: using nameserver 10.30.0.1#53
Sep 14 14:33:08 anders-VirtualBox dbus[1549]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9489] keyfile: add connection in-memory (ddc7383f-a29a-4c9f-a5fc-559acb8e1bab,"tun0")
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9507] device (tun0): state change: unavailable -> disconnected (reason 'connection-assumed') [20 30 41]
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9518] device (tun0): Activation: starting connection 'tun0' (ddc7383f-a29a-4c9f-a5fc-559acb8e1bab)
Sep 14 14:33:08 anders-VirtualBox NetworkManager[1615]: <info>  [1473856388.9559] device (tun0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Sep 14 14:33:08 anders-VirtualBox systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 14 14:33:09 anders-VirtualBox dbus[1549]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 14 14:33:09 anders-VirtualBox systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 14 14:33:09 anders-VirtualBox nm-dispatcher: req:1 'vpn-up' [tun0]: new request (1 scripts)
Sep 14 14:33:09 anders-VirtualBox nm-dispatcher: req:1 'vpn-up' [tun0]: start running ordered scripts...
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0228] device (tun0): state change: prepare -> config (reason 'none') [40 50 0]
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0246] device (tun0): state change: config -> ip-config (reason 'none') [50 70 0]
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0288] device (tun0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0303] device (tun0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0321] device (tun0): state change: secondaries -> activated (reason 'none') [90 100 0]
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0384] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0385] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0386] policy: set 'tun0' (tun0) as default for IPv4 routing and DNS
Sep 14 14:33:09 anders-VirtualBox NetworkManager[1615]: <info>  [1473856389.0386] device (tun0): Activation: successful, device activated.
Sep 14 14:33:09 anders-VirtualBox nm-dispatcher: req:2 'up' [tun0]: new request (1 scripts)
Sep 14 14:33:10 anders-VirtualBox ntpd[7236]: Listen normally on 7 tun0 10.30.0.132:123
Sep 14 14:33:10 anders-VirtualBox ntpd[7236]: new interface(s) found: waking up resolver
Sep 14 14:33:18 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:33:19 anders-VirtualBox nm-dispatcher: req:2 'up' [tun0]: start running ordered scripts...
Sep 14 14:33:19 anders-VirtualBox systemd[1]: Stopping LSB: Start NTP daemon...
Sep 14 14:33:19 anders-VirtualBox ntp[10651]:  * Stopping NTP server ntpd
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: ntpd exiting on signal 15 (Terminated)
Sep 14 14:33:19 anders-VirtualBox ntp[10651]:    ...done.
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 136.243.177.133 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 91.189.89.198 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 31.185.27.200 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 92.62.34.78 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 37.187.104.44 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 46.31.185.18 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 213.239.204.119 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 91.189.94.4 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 192.36.143.130 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 193.150.22.36 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 85.21.78.8 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 81.175.5.182 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 91.189.89.199 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 78.154.163.166 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 139.112.153.38 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 178.62.6.103 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 139.112.153.36 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 93.180.6.3 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 217.114.59.3 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox ntpd[7236]: 91.189.91.157 local addr 192.168.1.114 -> <null>
Sep 14 14:33:19 anders-VirtualBox systemd[1]: Stopped LSB: Start NTP daemon.
Sep 14 14:33:19 anders-VirtualBox ntpdate[10684]: no servers can be used, exiting
Sep 14 14:33:19 anders-VirtualBox systemd[1]: Starting LSB: Start NTP daemon...
Sep 14 14:33:19 anders-VirtualBox ntp[10710]:  * Starting NTP server ntpd
Sep 14 14:33:19 anders-VirtualBox ntpd[10721]: ntpd 4.2.8p4@1.3265-o Tue Aug  2 08:19:53 UTC 2016 (1): Starting
Sep 14 14:33:19 anders-VirtualBox ntpd[10721]: Command line: /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 108:114
Sep 14 14:33:19 anders-VirtualBox ntp[10710]:    ...done.
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: proto: precision = 0.142 usec (-23)
Sep 14 14:33:19 anders-VirtualBox systemd[1]: Started LSB: Start NTP daemon.
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen and drop on 0 v6wildcard [::]:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen normally on 2 lo 127.0.0.1:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen normally on 3 enp0s3 192.168.1.114:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen normally on 4 tun0 10.30.0.132:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen normally on 5 lo [::1]:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listen normally on 6 enp0s3 [fe80::45c4:5572:d0dd:40c8%2]:123
Sep 14 14:33:19 anders-VirtualBox ntpd[10723]: Listening on routing socket on fd #23 for interface updates
Sep 14 14:33:28 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:33:29 anders-VirtualBox systemd[1]: Stopping LSB: Start NTP daemon...
Sep 14 14:33:29 anders-VirtualBox ntp[10784]:  * Stopping NTP server ntpd
Sep 14 14:33:29 anders-VirtualBox ntpd[10723]: ntpd exiting on signal 15 (Terminated)
Sep 14 14:33:29 anders-VirtualBox ntp[10784]:    ...done.
Sep 14 14:33:29 anders-VirtualBox systemd[1]: Stopped LSB: Start NTP daemon.
Sep 14 14:33:29 anders-VirtualBox ntpdate[10800]: no servers can be used, exiting
Sep 14 14:33:29 anders-VirtualBox systemd[1]: Starting LSB: Start NTP daemon...
Sep 14 14:33:29 anders-VirtualBox ntp[10825]:  * Starting NTP server ntpd
Sep 14 14:33:29 anders-VirtualBox ntpd[10836]: ntpd 4.2.8p4@1.3265-o Tue Aug  2 08:19:53 UTC 2016 (1): Starting
Sep 14 14:33:29 anders-VirtualBox ntpd[10836]: Command line: /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 108:114
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: proto: precision = 0.064 usec (-24)
Sep 14 14:33:29 anders-VirtualBox ntp[10825]:    ...done.
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen and drop on 0 v6wildcard [::]:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen normally on 2 lo 127.0.0.1:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen normally on 3 enp0s3 192.168.1.114:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen normally on 4 tun0 10.30.0.132:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen normally on 5 lo [::1]:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listen normally on 6 enp0s3 [fe80::45c4:5572:d0dd:40c8%2]:123
Sep 14 14:33:29 anders-VirtualBox ntpd[10838]: Listening on routing socket on fd #23 for interface updates
Sep 14 14:33:29 anders-VirtualBox systemd[1]: Started LSB: Start NTP daemon.
Sep 14 14:33:38 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:33:48 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:33:50 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:33:58 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:08 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:10 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:34:18 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:28 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:30 anders-VirtualBox ntpd[10838]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:34:38 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:48 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:34:50 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:34:58 anders-VirtualBox nm-openvpn[10509]: write to TUN/TAP : Invalid argument (code=22)
Sep 14 14:35:10 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:35:30 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:35:50 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:35:58 anders-VirtualBox nm-openvpn[10509]: [server] Inactivity timeout (--ping-restart), restarting
Sep 14 14:35:58 anders-VirtualBox nm-openvpn[10509]: SIGUSR1[soft,ping-restart] received, process restarting
Sep 14 14:36:00 anders-VirtualBox nm-openvpn[10509]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 14 14:36:00 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:36:05 anders-VirtualBox nm-openvpn[10509]: message repeated 2 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:36:10 anders-VirtualBox ntpd[10838]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:36:10 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:36:25 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:36:30 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:36:30 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:36:45 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:36:50 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:36:50 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:37:10 anders-VirtualBox nm-openvpn[10509]: message repeated 4 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:37:10 anders-VirtualBox ntpd[10838]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:37:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:37:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:37:30 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:37:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:37:50 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:37:50 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:37:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:38:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:38:10 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:38:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:38:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:38:30 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:38:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:38:50 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:38:50 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:38:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:39:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:39:11 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:39:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:39:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:39:31 anders-VirtualBox ntpd[10838]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:39:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:39:50 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:39:51 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:39:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:40:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:40:11 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:40:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:40:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:40:31 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:40:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:40:50 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:40:51 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:40:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:41:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:41:11 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:41:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:41:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:41:31 anders-VirtualBox ntpd[10838]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
Sep 14 14:41:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:41:40 anders-VirtualBox systemd[1]: Started CUPS Scheduler.
Sep 14 14:41:40 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:41:50 anders-VirtualBox nm-openvpn[10509]: message repeated 2 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:41:51 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:41:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:42:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:42:11 anders-VirtualBox ntpd[10838]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:42:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:42:30 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:42:31 anders-VirtualBox ntpd[10838]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:42:35 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:42:50 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:42:51 anders-VirtualBox ntpd[10838]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:42:55 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
Sep 14 14:43:10 anders-VirtualBox nm-openvpn[10509]: message repeated 3 times: [ RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution]
Sep 14 14:43:11 anders-VirtualBox ntpd[10838]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
Sep 14 14:43:15 anders-VirtualBox nm-openvpn[10509]: RESOLVE: Cannot resolve host address: de.vpn.airdns.org: Temporary failure in name resolution
routing table:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.30.0.1       0.0.0.0         UG    50     0        0 tun0
default         192.168.1.11    0.0.0.0         UG    100    0        0 enp0s3
10.30.0.0       *               255.255.0.0     U     50     0        0 tun0
link-local      *               255.255.0.0     U     1000   0        0 enp0s3
178.162.198.102 192.168.1.11    255.255.255.255 UGH   100    0        0 enp0s3
192.168.1.0     *               255.255.255.0   U     100    0        0 enp0s3
