alibaba999xxx1
Issues with Arch and the Eddie client
Can people with Arch confirm that their setup currently works (Arch+Eddie) and what's your setup in detail?
I am sorry I have currently no logs to provide right now. I have over past few days tried several times, incl with clean installations, but both of the portable versions (with mono and without it) fail under Arch.
I get numerous errors, either the whole client freezes, mono crashes, it hangs at Checking authorization ... point, server list at one point is listed, then there are 0 servers in the list etc. I have played with the conf-n (f.e. unticked "check if the tunnel eff. works etc) of the client, I have double checked my firewall is off, installed all requested sw/dependencies etc.
So from one perspective lots of issues, at the same time I am interested who has successfully got the client to work in their Arch setup - how did you do it?
I am also running arch and usually eddy crashes shortly after first opening it and refreshing the server list or activating network log. Normally the second try works fine. Console output of latest crash:
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
I 2016.06.14 21:24:05 - AirVPN client version: 2.10.3 / x64, System: Linux, Name: Arch Linux \r (\l) / x64
. 2016.06.14 21:24:05 - Reading options from /root/.airvpn/AirVPN.xml
. 2016.06.14 21:24:06 - Data Path: /root/.airvpn
. 2016.06.14 21:24:06 - App Path: /usr/lib/AirVPN
. 2016.06.14 21:24:06 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2016.06.14 21:24:06 - Command line arguments (1): path="/root/.airvpn"
. 2016.06.14 21:24:06 - Updating systems & servers data ...
. 2016.06.14 21:24:06 - Operating System: Unix 4.6.2.1 - Linux pc 4.6.2-1-ARCH #1 SMP PREEMPT Wed Jun 8 08:40:59 CEST 2016 x86_64 GNU/Linux
I 2016.06.14 21:24:06 - OpenVPN Driver - Found, /dev/net/tun
I 2016.06.14 21:24:06 - OpenVPN - Version: OpenVPN 2.3.11 (/usr/bin/openvpn)
I 2016.06.14 21:24:06 - SSH - Version: OpenSSH_7.2p2, OpenSSL 1.0.2h  3 May 2016 (/usr/bin/ssh)
I 2016.06.14 21:24:06 - SSL - Version: stunnel 5.32 (/usr/bin/stunnel)
W 2016.06.14 21:24:06 - Recovery. Unexpected crash?
I 2016.06.14 21:24:06 - DNS of the system restored to original settings (Rename method)
! 2016.06.14 21:24:06 - Deactivation of Network Lock
! 2016.06.14 21:24:06 - Ready
. 2016.06.14 21:24:07 - Systems & servers data update completed
. 2016.06.14 21:24:15 - Updating systems & servers data ...
*** Error in `mono': double free or corruption (fasttop): 0x00000000035f5040 ***
======= Backtrace: =========
/usr/lib/libc.so.6(+0x6ed4b)[0x7fe182852d4b]
/usr/lib/libc.so.6(+0x74546)[0x7fe182858546]
/usr/lib/libc.so.6(+0x74d1e)[0x7fe182858d1e]
/usr/lib/libgdiplus.so(+0x34fd8)[0x7fe17ed7afd8]
/usr/lib/libgdiplus.so(GdipDeleteRegion+0x13)[0x7fe17ed7b293]
[0x406915c0]
======= Memory map: ========
00400000-00766000 r-xp 00000000 08:11 29789713                           /usr/bin/mono-sgen
00966000-00967000 r--p 00366000 08:11 29789713                           /usr/bin/mono-sgen
00967000-00971000 rw-p 00367000 08:11 29789713                           /usr/bin/mono-sgen
00971000-009a4000 rw-p 00000000 00:00 0
0291b000-037b5000 rw-p 00000000 00:00 0                                  [heap]
404da000-40712000 rwxp 00000000 00:00 0
41a67000-41a77000 rwxp 00000000 00:00 0
7fe138000000-7fe138021000 rw-p 00000000 00:00 0
7fe138021000-7fe13c000000 ---p 00000000 00:00 0
7fe13c000000-7fe13c032000 rw-p 00000000 00:00 0
7fe13c032000-7fe140000000 ---p 00000000 00:00 0
7fe143e00000-7fe143f00000 rw-p 00000000 00:00 0
7fe144000000-7fe144054000 rw-p 00000000 00:00 0
7fe144054000-7fe148000000 ---p 00000000 00:00 0
7fe148000000-7fe148038000 rw-p 00000000 00:00 0
7fe148038000-7fe14c000000 ---p 00000000 00:00 0
7fe14c000000-7fe14c039000 rw-p 00000000 00:00 0
7fe14c039000-7fe150000000 ---p 00000000 00:00 0
7fe150000000-7fe150021000 rw-p 00000000 00:00 0
7fe150021000-7fe154000000 ---p 00000000 00:00 0
7fe154000000-7fe154021000 rw-p 00000000 00:00 0
7fe154021000-7fe158000000 ---p 00000000 00:00 0
7fe158000000-7fe158061000 rw-p 00000000 00:00 0
7fe158061000-7fe15c000000 ---p 00000000 00:00 0
7fe15c000000-7fe15c3e8000 rw-p 00000000 00:00 0
7fe15c3e8000-7fe160000000 ---p 00000000 00:00 0
7fe160000000-7fe160021000 rw-p 00000000 00:00 0
7fe160021000-7fe164000000 ---p 00000000 00:00 0
7fe164000000-7fe16402d000 rw-p 00000000 00:00 0
7fe16402d000-7fe168000000 ---p 00000000 00:00 0
7fe168000000-7fe168021000 rw-p 00000000 00:00 0
7fe168021000-7fe16c000000 ---p 00000000 00:00 0
7fe16c000000-7fe16c0e2000 rw-p 00000000 00:00 0
7fe16c0e2000-7fe170000000 ---p 00000000 00:00 0
7fe170100000-7fe170200000 rw-p 00000000 00:00 0
7fe170278000-7fe1702f8000 rw-p 00000000 00:00 0
7fe1702fa000-7fe1702fe000 r-xp 00000000 08:11 29760398                   /usr/lib/libcap.so.2.25
7fe1702fe000-7fe1704fd000 ---p 00004000 08:11 29760398                   /usr/lib/libcap.so.2.25
7fe1704fd000-7fe1704fe000 rw-p 00003000 08:11 29760398                   /usr/lib/libcap.so.2.25
7fe1704fe000-7fe170507000 ---p 00000000 00:00 0
7fe170507000-7fe1706ff000 rw-p 00000000 00:00 0
7fe1706ff000-7fe170708000 ---p 00000000 00:00 0
7fe170708000-7fe170a00000 rw-p 00000000 00:00 0
7fe170a74000-7fe170af4000 rw-p 00000000 00:00 0
7fe170af7000-7fe170b00000 ---p 00000000 00:00 0
7fe170b00000-7fe170d78000 rw-p 00000000 00:00 0
7fe170d7c000-7fe170dfc000 rw-p 00000000 00:00 0
7fe170e00000-7fe170f00000 rw-p 00000000 00:00 0
7fe170f74000-7fe170ff4000 rw-p 00000000 00:00 0
7fe170ff7000-7fe170ffc000 r-xp 00000000 08:11 29770632                   /usr/lib/libnss_dns-2.23.so
7fe170ffc000-7fe1711fb000 ---p 00005000 08:11 29770632                   /usr/lib/libnss_dns-2.23.so
7fe1711fb000-7fe1711fc000 r--p 00004000 08:11 29770632                   /usr/lib/libnss_dns-2.23.so
7fe1711fc000-7fe1711fd000 rw-p 00005000 08:11 29770632                   /usr/lib/libnss_dns-2.23.so
7fe1711fd000-7fe171206000 ---p 00000000 00:00 0
7fe171206000-7fe1713fe000 rw-p 00000000 00:00 0
7fe1713fe000-7fe171407000 ---p 00000000 00:00 0
7fe171407000-7fe1715ff000 rw-p 00000000 00:00 0
7fe1715ff000-7fe171608000 ---p 00000000 00:00 0
7fe171608000-7fe171900000 rw-p 00000000 00:00 0
7fe17192f000-7fe171938000 ---p 00000000 00:00 0
7fe171938000-7fe171970000 rw-p 00000000 00:00 0
7fe171970000-7fe171b70000 rw-s 00000000 00:05 7897100                    /SYSV00000000 (deleted)
7fe171b70000-7fe171b79000 ---p 00000000 00:00 0
7fe171b79000-7fe171d71000 rw-p 00000000 00:00 0
7fe171d71000-7fe171d7a000 ---p 00000000 00:00 0
7fe171d7a000-7fe171f72000 rw-p 00000000 00:00 0
7fe171f72000-7fe171f7b000 ---p 00000000 00:00 0
7fe171f7b000-7fe172173000 rw-p 00000000 00:00 0
7fe172173000-7fe17217c000 ---p 00000000 00:00 0
7fe17217c000-7fe1723f4000 rw-p 00000000 00:00 0
7fe1723f8000-7fe172478000 rw-p 00000000 00:00 0
7fe17247c000-7fe1724fc000 rw-p 00000000 00:00 0
7fe172500000-7fe172600000 rw-p 00000000 00:00 0
7fe172624000-7fe172627000 rw-p 00000000 00:00 0
7fe172627000-7fe172637000 r-xp 00000000 08:11 29808838                   /usr/lib/libnss_myhostname.so.2
7fe172637000-7fe172638000 ---p 00010000 08:11 29808838                   /usr/lib/libnss_myhostname.so.2
7fe172638000-7fe17263a000 r--p 00010000 08:11 29808838                   /usr/lib/libnss_myhostname.so.2
7fe17263a000-7fe17263b000 rw-p 00012000 08:11 29808838                   /usr/lib/libnss_myhostname.so.2
7fe17263b000-7fe172644000 ---p 00000000 00:00 0
7fe172644000-7fe172800000 rw-p 00000000 00:00 0
7fe172801000-7fe172811000 rwxp 00000000 00:00 0
7fe172811000-7fe172836000 r--p 00000000 08:11 30287253                   /usr/share/fonts/TTF/verdana.ttf
7fe172836000-7fe1728ef000 r--p 00000000 08:11 30285272                   /usr/share/fonts/TTF/DejaVuSans.ttf
7fe1728ef000-7fe17290e000 r-xp 00000000 08:11 29789599                   /usr/lib/libMonoSupportW.so
7fe17290e000-7fe172b0e000 ---p 0001f000 08:11 29789599                   /usr/lib/libMonoSupportW.so
7fe172b0e000-7fe172b0f000 r--p 0001f000 08:11 29789599                   /usr/lib/libMonoSupportW.so
7fe172b0f000-7fe172b10000 rw-p 00020000 08:11 29789599                   /usr/lib/libMonoSupportW.so
7fe172b10000-7fe172b17000 r-xp 00000000 08:11 29801817                   /usr/lib/libdatrie.so.1.3.3
7fe172b17000-7fe172d16000 ---p 00007000 08:11 29801817                   /usr/lib/libdatrie.so.1.3.3
7fe172d16000-7fe172d17000 r--p 00006000 08:11 29801817                   /usr/lib/libdatrie.so.1.3.3
7fe172d17000-7fe172d18000 rw-p 00007000 08:11 29801817                   /usr/lib/libdatrie.so.1.3.3
7fe172d18000-7fe172d20000 r-xp 00000000 08:11 29797241                   /usr/lib/libffi.so.6.0.4
7fe172d20000-7fe172f1f000 ---p 00008000 08:11 29797241                   /usr/lib/libffi.so.6.0.4
7fe172f1f000-7fe172f20000 r--p 00007000 08:11 29797241                   /usr/lib/libffi.so.6.0.4
7fe172f20000-7fe172f21000 rw-p 00008000 08:11 29797241                   /usr/lib/libffi.so.6.0.4
7fe172f21000-7fe172f29000 r-xp 00000000 08:11 29776546                   /usr/lib/libthai.so.0.2.4
7fe172f29000-7fe173128000 ---p 00008000 08:11 29776546                   /usr/lib/libthai.so.0.2.4
7fe173128000-7fe173129000 r--p 00007000 08:11 29776546                   /usr/lib/libthai.so.0.2.4
7fe173129000-7fe17312a000 rw-p 00008000 08:11 29776546                   /usr/lib/libthai.so.0.2.4
7fe17312a000-7fe17313e000 r-xp 00000000 08:11 29770642                   /usr/lib/libresolv-2.23.so
7fe17313e000-7fe17333d000 ---p 00014000 08:11 29770642                   /usr/lib/libresolv-2.23.so
7fe17333d000-7fe17333e000 r--p 00013000 08:11 29770642                   /usr/lib/libresolv-2.23.so
7fe17333e000-7fe17333f000 rw-p 00014000 08:11 29770642                   /usr/lib/libresolv-2.23.so
7fe17333f000-7fe173341000 rw-p 00000000 00:00 0
7fe173341000-7fe173343000 r-xp 00000000 08:11 29776621                   /usr/lib/libXdamage.so.1.1.0
7fe173343000-7fe173542000 ---p 00002000 08:11 29776621                   /usr/lib/libXdamage.so.1.1.0
7fe173542000-7fe173543000 r--p 00001000 08:11 29776621                   /usr/lib/libXdamage.so.1.1.0
7fe173543000-7fe173544000 rw-p 00002000 08:11 29776621                   /usr/lib/libXdamage.so.1.1.0
7fe173544000-7fe173546000 r-xp 00000000 08:11 29777321                   /usr/lib/libXcomposite.so.1.0.0
7fe173546000-7fe173745000 ---p 00002000 08:11 29777321                   /usr/lib/libXcomposite.so.1.0.0
7fe173745000-7fe173746000 r--p 00001000 08:11 29777321                   /usr/lib/libXcomposite.so.1.0.0
7fe173746000-7fe173747000 rw-p 00002000 08:11 29777321                   /usr/lib/libXcomposite.so.1.0.0
7fe173747000-7fe173751000 r-xp 00000000 08:11 29789870                   /usr/lib/libXcursor.so.1.0.2
7fe173751000-7fe173950000 ---p 0000a000 08:11 29789870                   /usr/lib/libXcursor.so.1.0.2
7fe173950000-7fe173951000 r--p 00009000 08:11 29789870                   /usr/lib/libXcursor.so.1.0.2
7fe173951000-7fe173952000 rw-p 0000a000 08:11 29789870                   /usr/lib/libXcursor.so.1.0.2
7fe173952000-7fe17395c000 r-xp 00000000 08:11 29789810                   /usr/lib/libXrandr.so.2.2.0
7fe17395c000-7fe173b5b000 ---p 0000a000 08:11 29789810                   /usr/lib/libXrandr.so.2.2.0
7fe173b5b000-7fe173b5c000 r--p 00009000 08:11 29789810                   /usr/lib/libXrandr.so.2.2.0
7fe173b5c000-7fe173b5d000 rw-p 0000a000 08:11 29789810                   /usr/lib/libXrandr.so.2.2.0
7fe173b5d000-7fe173b6c000 r-xp 00000000 08:11 29777068                   /usr/lib/libXi.so.6.1.0
7fe173b6c000-7fe173d6b000 ---p 0000f000 08:11 29777068                   /usr/lib/libXi.so.6.1.0
7fe173d6b000-7fe173d6c000 r--p 0000e000 08:11 29777068                   /usr/lib/libXi.so.6.1.0
7fe173d6c000-7fe173d6d000 rw-p 0000f000 08:11 29777068                   /usr/lib/libXi.so.6.1.0
7fe173d6d000-7fe173d6f000 r-xp 00000000 08:11 29776850                   /usr/lib/libXinerama.so.1.0.0
7fe173d6f000-7fe173f6e000 ---p 00002000 08:11 29776850                   /usr/lib/libXinerama.so.1.0.0
7fe173f6e000-7fe173f6f000 r--p 00001000 08:11 29776850                   /usr/lib/libXinerama.so.1.0.0
7fe173f6f000-7fe173f70000 rw-p 00002000 08:11 29776850                   /usr/lib/libXinerama.so.1.0.0
7fe173f70000-7fe173fc1000 r-xp 00000000 08:11 29795770                   /usr/lib/libgobject-2.0.so.0.4800.1
7fe173fc1000-7fe1741c0000 ---p 00051000 08:11 29795770                   /usr/lib/libgobject-2.0.so.0.4800.1
7fe1741c0000-7fe1741c1000 r--p 00050000 08:11 29795770                   /usr/lib/libgobject-2.0.so.0.4800.1
7fe1741c1000-7fe1741c2000 rw-p 00051000 08:11 29795770                   /usr/lib/libgobject-2.0.so.0.4800.1
7fe1741c2000-7fe17420b000 r-xp 00000000 08:11 29784964                   /usr/lib/libpango-1.0.so.0.4000.1
7fe17420b000-7fe17440b000 ---p 00049000 08:11 29784964                   /usr/lib/libpango-1.0.so.0.4000.1
7fe17440b000-7fe17440d000 r--p 00049000 08:11 29784964                   /usr/lib/libpango-1.0.so.0.4000.1
7fe17440d000-7fe17440e000 rw-p 0004b000 08:11 29784964                   /usr/lib/libpango-1.0.so.0.4000.1
7fe17440e000-7fe174422000 r-xp 00000000 08:11 29784966                   /usr/lib/libpangoft2-1.0.so.0.4000.1
7fe174422000-7fe174621000 ---p 00014000 08:11 29784966                   /usr/lib/libpangoft2-1.0.so.0.4000.1
7fe174621000-7fe174622000 r--p 00013000 08:11 29784966                   /usr/lib/libpangoft2-1.0.so.0.4000.1
7fe174622000-7fe174623000 rw-p 00014000 08:11 29784966                   /usr/lib/libpangoft2-1.0.so.0.4000.1
7fe174623000-7fe1747a1000 r-xp 00000000 08:11 29795920                   /usr/lib/libgio-2.0.so.0.4800.1
7fe1747a1000-7fe1749a1000 ---p 0017e000 08:11 29795920                   /usr/lib/libgio-2.0.so.0.4800.1
7fe1749a1000-7fe1749a5000 r--p 0017e000 08:11 29795920                   /usr/lib/libgio-2.0.so.0.4800.1
7fe1749a5000-7fe1749a7000 rw-p 00182000 08:11 29795920                   /usr/lib/libgio-2.0.so.0.4800.1
7fe1749a7000-7fe1749a9000 rw-p 00000000 00:00 0
7fe1749a9000-7fe1749cd000 r-xp 00000000 08:11 29777185                   /usr/lib/libgdk_pixbuf-2.0.so.0.3400.0
7fe1749cd000-7fe174bcd000 ---p 00024000 08:11 29777185                   /usr/lib/libgdk_pixbuf-2.0.so.0.3400.0
7fe174bcd000-7fe174bce000 r--p 00024000 08:11 29777185                   /usr/lib/libgdk_pixbuf-2.0.so.0.3400.0
7fe174bce000-7fe174bcf000 rw-p 00025000 08:11 29777185                   /usr/lib/libgdk_pixbuf-2.0.so.0.3400.0
7fe174bcf000-7fe174bf2000 r-xp 00000000 08:11 29805078                   /usr/lib/libatk-1.0.so.0.22009.1
7fe174bf2000-7fe174df1000 ---p 00023000 08:11 29805078                   /usr/lib/libatk-1.0.so.0.22009.1
7fe174df1000-7fe174df4000 r--p 00022000 08:11 29805078                   /usr/lib/libatk-1.0.so.0.22009.1
7fe174df4000-7fe174df5000 rw-p 00025000 08:11 29805078                   /usr/lib/libatk-1.0.so.0.22009.1
7fe174df5000-7fe174dfa000 r-xp 00000000 08:11 29789869                   /usr/lib/libXfixes.so.3.1.0
7fe174dfa000-7fe174ff9000 ---p 00005000 08:11 29789869                   /usr/lib/libXfixes.so.3.1.0
7fe174ff9000-7fe174ffa000 r--p 00004000 08:11 29789869                   /usr/lib/libXfixes.so.3.1.0
7fe174ffa000-7fe174ffb000 rw-p 00005000 08:11 29789869                   /usr/lib/libXfixes.so.3.1.0
7fe174ffb000-7fe175007000 r-xp 00000000 08:11 29806410                   /usr/lib/libpangocairo-1.0.so.0.4000.1
7fe175007000-7fe175206000 ---p 0000c000 08:11 29806410                   /usr/lib/libpangocairo-1.0.so.0.4000.1
7fe175206000-7fe175207000 r--p 0000b000 08:11 29806410                   /usr/lib/libpangocairo-1.0.so.0.4000.1
7fe175207000-7fe175208000 rw-p 0000c000 08:11 29806410                   /usr/lib/libpangocairo-1.0.so.0.4000.1
7fe175208000-7fe17520b000 r-xp 00000000 08:11 29795768                   /usr/lib/libgmodule-2.0.so.0.4800.1
7fe17520b000-7fe17540a000 ---p 00003000 08:11 29795768                   /usr/lib/libgmodule-2.0.so.0.4800.1
7fe17540a000-7fe17540b000 r--p 00002000 08:11 29795768                   /usr/lib/libgmodule-2.0.so.0.4800.1
7fe17540b000-7fe17540c000 rw-p 00003000 08:11 29795768                   /usr/lib/libgmodule-2.0.so.0.4800.1
7fe17540c000-7fe1754bc000 r-xp 00000000 08:11 29778524                   /usr/lib/libgdk-x11-2.0.so.0.2400.30
7fe1754bc000-7fe1756bc000 ---p 000b0000 08:11 29778524                   /usr/lib/libgdk-x11-2.0.so.0.2400.30
7fe1756bc000-7fe1756c0000 r--p 000b0000 08:11 29778524                   /usr/lib/libgdk-x11-2.0.so.0.2400.30
7fe1756c0000-7fe1756c2000 rw-p 000b4000 08:11 29778524                   /usr/lib/libgdk-x11-2.0.so.0.2400.30
7fe1756c2000-7fe175af7000 r-xp 00000000 08:11 29778525                   /usr/lib/libgtk-x11-2.0.so.0.2400.30
7fe175af7000-7fe175cf6000 ---p 00435000 08:11 29778525                   /usr/lib/libgtk-x11-2.0.so.0.2400.30
7fe175cf6000-7fe175cfd000 r--p 00434000 08:11 29778525                   /usr/lib/libgtk-x11-2.0.so.0.2400.30
7fe175cfd000-7fe175d01000 rw-p 0043b000 08:11 29778525                   /usr/lib/libgtk-x11-2.0.so.0.2400.30
7fe175d01000-7fe175d04000 rw-p 00000000 00:00 0
7fe175d04000-7fe175d78000 rw-p 00000000 00:00 0
7fe175d78000-7fe175d83000 r-xp 00000000 08:11 29770633                   /usr/lib/libnss_files-2.23.so
7fe175d83000-7fe175f82000 ---p 0000b000 08:11 29770633                   /usr/lib/libnss_files-2.23.so
7fe175f82000-7fe175f83000 r--p 0000a000 08:11 29770633                   /usr/lib/libnss_files-2.23.so
7fe175f83000-7fe175f84000 rw-p 0000b000 08:11 29770633                   /usr/lib/libnss_files-2.23.so
7fe175f84000-7fe175f8a000 rw-p 00000000 00:00 0
7fe175f8a000-7fe175fc7000 r-xp 00000000 08:11 29789598                   /usr/lib/libMonoPosixHelper.so
7fe175fc7000-7fe1761c6000 ---p 0003d000 08:11 29789598                   /usr/lib/libMonoPosixHelper.so
7fe1761c6000-7fe1761c7000 r--p 0003c000 08:11 29789598                   /usr/lib/libMonoPosixHelper.so
7fe1761c7000-7fe1761c8000 rw-p 0003d000 08:11 29789598                   /usr/lib/libMonoPosixHelper.so
7fe1761c8000-7fe1761c9000 rw-p 00000000 00:00 0
7fe1761c9000-7fe17623b000 r-xp 00000000 08:11 29784953                   /usr/lib/libnvidia-glsi.so.367.27
7fe17623b000-7fe17643a000 ---p 00072000 08:11 29784953                   /usr/lib/libnvidia-glsi.so.367.27
7fe17643a000-7fe176443000 rw-p 00071000 08:11 29784953                   /usr/lib/libnvidia-glsi.so.367.27
7fe176443000-7fe176452000 rw-p 00000000 00:00 0
7fe176452000-7fe17651d000 r-xp 00000000 08:11 29789796                   /usr/lib/libEGL_nvidia.so.367.27
7fe17651d000-7fe17671c000 ---p 000cb000 08:11 29789796                   /usr/lib/libEGL_nvidia.so.367.27
7fe17671c000-7fe176747000 rw-p 000ca000 08:11 29789796                   /usr/lib/libEGL_nvidia.so.367.27
7fe176747000-7fe17675b000 rw-p 00000000 00:00 0
7fe17675b000-7fe176785000 r-xp 00000000 08:11 29792573                   /usr/lib/libgraphite2.so.3.0.1
7fe176785000-7fe176984000 ---p 0002a000 08:11 29792573                   /usr/lib/libgraphite2.so.3.0.1
7fe176984000-7fe176986000 r--p 00029000 08:11 29792573                   /usr/lib/libgraphite2.so.3.0.1
7fe176986000-7fe176987000 rw-p 0002b000 08:11 29792573                   /usr/lib/libgraphite2.so.3.0.1
7fe176987000-7fe176997000 r-xp 00000000 08:11 29784542                   /usr/lib/libGLX.so.0.0.0
7fe176997000-7fe176b97000 ---p 00010000 08:11 29784542                   /usr/lib/libGLX.so.0.0.0
7fe176b97000-7fe176b98000 r--p 00010000 08:11 29784542                   /usr/lib/libGLX.so.0.0.0
7fe176b98000-7fe176b99000 rw-p 00011000 08:11 29784542                   /usr/lib/libGLX.so.0.0.0
7fe176b99000-7fe176bb9000 rw-p 00000000 00:00 0
7fe176bb9000-7fe176bbe000 r-xp 00000000 08:11 29771988                   /usr/lib/libXdmcp.so.6.0.0
7fe176bbe000-7fe176dbd000 ---p 00005000 08:11 29771988                   /usr/lib/libXdmcp.so.6.0.0
7fe176dbd000-7fe176dbe000 r--p 00004000 08:11 29771988                   /usr/lib/libXdmcp.so.6.0.0
7fe176dbe000-7fe176dbf000 rw-p 00005000 08:11 29771988                   /usr/lib/libXdmcp.so.6.0.0
7fe176dbf000-7fe176dc1000 r-xp 00000000 08:11 29771991                   /usr/lib/libXau.so.6.0.0
7fe176dc1000-7fe176fc1000 ---p 00002000 08:11 29771991                   /usr/lib/libXau.so.6.0.0
7fe176fc1000-7fe176fc2000 r--p 00002000 08:11 29771991                   /usr/lib/libXau.so.6.0.0
7fe176fc2000-7fe176fc3000 rw-p 00003000 08:11 29771991                   /usr/lib/libXau.so.6.0.0
7fe176fc3000-7fe17706a000 r-xp 00000000 08:11 29788968                   /usr/lib/libGLdispatch.so.0.0.0
7fe17706a000-7fe177269000 ---p 000a7000 08:11 29788968                   /usr/lib/libGLdispatch.so.0.0.0
7fe177269000-7fe177278000 r--p 000a6000 08:11 29788968                   /usr/lib/libGLdispatch.so.0.0.0
7fe177278000-7fe177279000 rw-p 000b5000 08:11 29788968                   /usr/lib/libGLdispatch.so.0.0.0
7fe177279000-7fe177299000 rw-p 00000000 00:00 0
7fe177299000-7fe1772c2000 r-xp 00000000 08:11 29782412                   /usr/lib/libexpat.so.1.6.0
7fe1772c2000-7fe1774c2000 ---p 00029000 08:11 29782412                   /usr/lib/libexpat.so.1.6.0
7fe1774c2000-7fe1774c4000 r--p 00029000 08:11 29782412                   /usr/lib/libexpat.so.1.6.0
7fe1774c4000-7fe1774c5000 rw-p 0002b000 08:11 29782412                   /usr/lib/libexpat.so.1.6.0
7fe1774c5000-7fe1774ea000 r-xp 00000000 08:11 29761985                   /usr/lib/liblzma.so.5.2.2
7fe1774ea000-7fe1776e9000 ---p 00025000 08:11 29761985                   /usr/lib/liblzma.so.5.2.2
7fe1776e9000-7fe1776ea000 r--p 00024000 08:11 29761985                   /usr/lib/liblzma.so.5.2.2
7fe1776ea000-7fe1776eb000 rw-p 00025000 08:11 29761985                   /usr/lib/liblzma.so.5.2.2
7fe1776eb000-7fe177765000 r-xp 00000000 08:11 29805337                   /usr/lib/libharfbuzz.so.0.10200.7
7fe177765000-7fe177965000 ---p 0007a000 08:11 29805337                   /usr/lib/libharfbuzz.so.0.10200.7
7fe177965000-7fe177966000 r--p 0007a000 08:11 29805337                   /usr/lib/libharfbuzz.so.0.10200.7
7fe177966000-7fe177967000 rw-p 0007b000 08:11 29805337                   /usr/lib/libharfbuzz.so.0.10200.7
7fe177967000-7fe177976000 r-xp 00000000 08:11 29759661                   /usr/lib/libbz2.so.1.0.6
7fe177976000-7fe177b75000 ---p 0000f000 08:11 29759661                   /usr/lib/libbz2.so.1.0.6
7fe177b75000-7fe177b77000 rw-p 0000e000 08:11 29759661                   /usr/lib/libbz2.so.1.0.6
7fe177b77000-7fe177beb000 r-xp 00000000 08:11 29791812                   /usr/lib/nvidia/libGL.so.1.0.0
7fe177beb000-7fe177deb000 ---p 00074000 08:11 29791812                   /usr/lib/nvidia/libGL.so.1.0.0
7fe177deb000-7fe177dec000 r--p 00074000 08:11 29791812                   /usr/lib/nvidia/libGL.so.1.0.0
7fe177dec000-7fe177ded000 rw-p 00075000 08:11 29791812                   /usr/lib/nvidia/libGL.so.1.0.0
7fe177ded000-7fe177dee000 rw-p 00000000 00:00 0
7fe177dee000-7fe177dff000 r-xp 00000000 08:11 29776161                   /usr/lib/libXext.so.6.4.0
7fe177dff000-7fe177ffe000 ---p 00011000 08:11 29776161                   /usr/lib/libXext.so.6.4.0
7fe177ffe000-7fe177fff000 r--p 00010000 08:11 29776161                   /usr/lib/libXext.so.6.4.0
7fe177fff000-7fe178000000 rw-p 00011000 08:11 29776161                   /usr/lib/libXext.so.6.4.0
7fe178000000-7fe178021000 rw-p 00000000 00:00 0
7fe178021000-7fe17c000000 ---p 00000000 00:00 0
7fe17c000000-7fe17c08c000 rw-p 00000000 00:00 0
7fe17c08e000-7fe17c0da000 r--p 00000000 08:11 30288041                   /usr/share/fonts/TTF/tahoma.ttf
7fe17c0da000-7fe17c125000 r--p 00000000 08:11 30288038                   /usr/share/fonts/TTF/micross.ttf
7fe17c125000-7fe17c18b000 r--s 00000000 08:11 23858590                   /var/cache/fontconfig/f6b893a7224233d96cb72fd88691c0b4-le64.cache-7
7fe17c18b000-7fe17c1b3000 r-xp 00000000 08:11 29772053                   /usr/lib/libxcb.so.1.1.0
7fe17c1b3000-7fe17c3b2000 ---p 00028000 08:11 29772053                   /usr/lib/libxcb.so.1.1.0
7fe17c3b2000-7fe17c3b3000 r--p 00027000 08:11 29772053                   /usr/lib/libxcb.so.1.1.0
7fe17c3b3000-7fe17c3b4000 rw-p 00028000 08:11 29772053                   /usr/lib/libxcb.so.1.1.0
7fe17c3b4000-7fe17c3c0000 r-xp 00000000 08:11 29772063                   /usr/lib/libxcb-render.so.0.0.0
7fe17c3c0000-7fe17c5c0000 ---p 0000c000 08:11 29772063                   /usr/lib/libxcb-render.so.0.0.0
7fe17c5c0000-7fe17c5c1000 r--p 0000c000 08:11 29772063                   /usr/lib/libxcb-render.so.0.0.0
7fe17c5c1000-7fe17c5c2000 rw-p 0000d000 08:11 29772063                   /usr/lib/libxcb-render.so.0.0.0
7fe17c5c2000-7fe17c5c4000 r-xp 00000000 08:11 29772067                   /usr/lib/libxcb-shm.so.0.0.0
7fe17c5c4000-7fe17c7c4000 ---p 00002000 08:11 29772067                   /usr/lib/libxcb-shm.so.0.0.0
7fe17c7c4000-7fe17c7c5000 r--p 00002000 08:11 29772067                   /usr/lib/libxcb-shm.so.0.0.0
7fe17c7c5000-7fe17c7c6000 rw-p 00003000 08:11 29772067                   /usr/lib/libxcb-shm.so.0.0.0
7fe17c7c6000-7fe17c7ca000 r-xp 00000000 08:11 29790138                   /usr/lib/nvidia/libEGL.so.1
7fe17c7ca000-7fe17c9c9000 ---p 00004000 08:11 29790138                   /usr/lib/nvidia/libEGL.so.1
7fe17c9c9000-7fe17c9ca000 rw-p 00003000 08:11 29790138                   /usr/lib/nvidia/libEGL.so.1
7fe17c9ca000-7fe17ca69000 r-xp 00000000 08:11 29794427                   /usr/lib/libpixman-1.so.0.34.0
7fe17ca69000-7fe17cc69000 ---p 0009f000 08:11 29794427                   /usr/lib/libpixman-1.so.0.34.0
7fe17cc69000-7fe17cc71000 r--p 0009f000 08:11 29794427                   /usr/lib/libpixman-1.so.0.34.0
7fe17cc71000-7fe17cc72000 rw-p 000a7000 08:11 29794427                   /usr/lib/libpixman-1.so.0.34.0
7fe17cc72000-7fe17cce1000 r-xp 00000000 08:11 29761334                   /usr/lib/libpcre.so.1.2.6
7fe17cce1000-7fe17cee0000 ---p 0006f000 08:11 29761334                   /usr/lib/libpcre.so.1.2.6
7fe17cee0000-7fe17cee1000 r--p 0006e000 08:11 29761334                   /usr/lib/libpcre.so.1.2.6
7fe17cee1000-7fe17cee2000 rw-p 0006f000 08:11 29761334                   /usr/lib/libpcre.so.1.2.6
7fe17cee2000-7fe17cf20000 r-xp 00000000 08:11 29805344                   /usr/lib/libfontconfig.so.1.9.1
7fe17cf20000-7fe17d11f000 ---p 0003e000 08:11 29805344                   /usr/lib/libfontconfig.so.1.9.1
7fe17d11f000-7fe17d121000 r--p 0003d000 08:11 29805344                   /usr/lib/libfontconfig.so.1.9.1
7fe17d121000-7fe17d126000 rw-p 0003f000 08:11 29805344                   /usr/lib/libfontconfig.so.1.9.1
7fe17d126000-7fe17d158000 r-xp 00000000 08:11 29780346                   /usr/lib/libexif.so.12.3.3
7fe17d158000-7fe17d357000 ---p 00032000 08:11 29780346                   /usr/lib/libexif.so.12.3.3
7fe17d357000-7fe17d36a000 r--p 00031000 08:11 29780346                   /usr/lib/libexif.so.12.3.3
7fe17d36a000-7fe17d36b000 rw-p 00044000 08:11 29780346                   /usr/lib/libexif.so.12.3.3
7fe17d36b000-7fe17d380000 r-xp 00000000 08:11 29756892                   /usr/lib/libz.so.1.2.8
7fe17d380000-7fe17d57f000 ---p 00015000 08:11 29756892                   /usr/lib/libz.so.1.2.8
7fe17d57f000-7fe17d580000 r--p 00014000 08:11 29756892                   /usr/lib/libz.so.1.2.8
7fe17d580000-7fe17d581000 rw-p 00015000 08:11 29756892                   /usr/lib/libz.so.1.2.8
7fe17d581000-7fe17d5b5000 r-xp 00000000 08:11 29765388                   /usr/lib/libpng16.so.16.22.0
7fe17d5b5000-7fe17d7b4000 ---p 00034000 08:11 29765388                   /usr/lib/libpng16.so.16.22.0
7fe17d7b4000-7fe17d7b5000 r--p 00033000 08:11 29765388                   /usr/lib/libpng16.so.16.22.0
7fe17d7b5000-7fe17d7b6000 rw-p 00034000 08:11 29765388                   /usr/lib/libpng16.so.16.22.0
7fe17d7b6000-7fe17d7be000 r-xp 00000000 08:11 29778699                   /usr/lib/libgif.so.7.0.0
7fe17d7be000-7fe17d9be000 ---p 00008000 08:11 29778699                   /usr/lib/libgif.so.7.0.0
7fe17d9be000-7fe17d9bf000 r--p 00008000 08:11 29778699                   /usr/lib/libgif.so.7.0.0
7fe17d9bf000-7fe17d9c0000 rw-p 00009000 08:11 29778699                   /usr/lib/libgif.so.7.0.0
7fe17d9c0000-7fe17da3c000 r-xp 00000000 08:11 29776983                   /usr/lib/libtiff.so.5.2.4
7fe17da3c000-7fe17dc3c000 ---p 0007c000 08:11 29776983                   /usr/lib/libtiff.so.5.2.4
7fe17dc3c000-7fe17dc3d000 r--p 0007c000 08:11 29776983                   /usr/lib/libtiff.so.5.2.4
7fe17dc3d000-7fe17dc43000 rw-p 0007d000 08:11 29776983                   /usr/lib/libtiff.so.5.2.4
7fe17dc43000-7fe17dc44000 rw-p 00000000 00:00 0
7fe17dc44000-7fe17dcad000 r-xp 00000000 08:11 29769310                   /usr/lib/libjpeg.so.8.1.2
7fe17dcad000-7fe17deac000 ---p 00069000 08:11 29769310                   /usr/lib/libjpeg.so.8.1.2
7fe17deac000-7fe17dead000 r--p 00068000 08:11 29769310                   /usr/lib/libjpeg.so.8.1.2
7fe17dead000-7fe17deae000 rw-p 00069000 08:11 29769310                   /usr/lib/libjpeg.so.8.1.2
7fe17deae000-7fe17dfe9000 r-xp 00000000 08:11 29774150                   /usr/lib/libX11.so.6.3.0
7fe17dfe9000-7fe17e1e8000 ---p 0013b000 08:11 29774150                   /usr/lib/libX11.so.6.3.0
7fe17e1e8000-7fe17e1ea000 r--p 0013a000 08:11 29774150                   /usr/lib/libX11.so.6.3.0
7fe17e1ea000-7fe17e1ef000 rw-p 0013c000 08:11 29774150                   /usr/lib/libX11.so.6.3.0
7fe17e1ef000-7fe17e1f0000 rw-p 00000000 00:00 0
7fe17e1f0000-7fe17e1f9000 r-xp 00000000 08:11 29755527                   /usr/lib/libXrender.so.1.3.0
7fe17e1f9000-7fe17e3f8000 ---p 00009000 08:11 29755527                   /usr/lib/libXrender.so.1.3.0
7fe17e3f8000-7fe17e3f9000 r--p 00008000 08:11 29755527                   /usr/lib/libXrender.so.1.3.0
7fe17e3f9000-7fe17e3fa000 rw-p 00009000 08:11 29755527                   /usr/lib/libXrender.so.1.3.0
7fe17e3fa000-7fe17e4b3000 r-xp 00000000 08:11 29806686                   /usr/lib/libfreetype.so.6.12.3
7fe17e4b3000-7fe17e6b3000 ---p 000b9000 08:11 29806686                   /usr/lib/libfreetype.so.6.12.3
7fe17e6b3000-7fe17e6b9000 r--p 000b9000 08:11 29806686                   /usr/lib/libfreetype.so.6.12.3
7fe17e6b9000-7fe17e6ba000 rw-p 000bf000 08:11 29806686                   /usr/lib/libfreetype.so.6.12.3
7fe17e6ba000-7fe17e7e3000 r-xp 00000000 08:11 29776671                   /usr/lib/libcairo.so.2.11400.6
7fe17e7e3000-7fe17e9e3000 ---p 00129000 08:11 29776671                   /usr/lib/libcairo.so.2.11400.6
7fe17e9e3000-7fe17e9e6000 r--p 00129000 08:11 29776671                   /usr/lib/libcairo.so.2.11400.6
7fe17e9e6000-7fe17e9e8000 rw-p 0012c000 08:11 29776671                   /usr/lib/libcairo.so.2.11400.6
7fe17e9e8000-7fe17e9e9000 rw-p 00000000 00:00 0
7fe17e9e9000-7fe17eaf6000 r-xp 00000000 08:11 29795767                   /usr/lib/libglib-2.0.so.0.4800.1
7fe17eaf6000-7fe17ecf5000 ---p 0010d000 08:11 29795767                   /usr/lib/libglib-2.0.so.0.4800.1
7fe17ecf5000-7fe17ecf6000 r--p 0010c000 08:11 29795767                   /usr/lib/libglib-2.0.so.0.4800.1
7fe17ecf6000-7fe17ecf7000 rw-p 0010d000 08:11 29795767                   /usr/lib/libglib-2.0.so.0.4800.1
7fe17ecf7000-7fe17ecf9000 rw-p 00000000 00:00 0
7fe17ecf9000-7fe17ed13000 rw-p 00000000 00:00 0
7fe17ed13000-7fe17ed46000 r--p 00000000 08:11 1578327                    /usr/lib/mono/gac/Mono.Posix/4.0.0.0__0738eb9f132ed756/Mono.Posix.dll
7fe17ed46000-7fe17edac000 r-xp 00000000 08:11 29760246                   /usr/lib/libgdiplus.so.0.0.0
7fe17edac000-7fe17efab000 ---p 00066000 08:11 29760246                   /usr/lib/libgdiplus.so.0.0.0
7fe17efab000-7fe17efac000 r--p 00065000 08:11 29760246                   /usr/lib/libgdiplus.so.0.0.0
7fe17efac000-7fe17efae000 rw-p 00066000 08:11 29760246                   /usr/lib/libgdiplus.so.0.0.0
7fe17efae000-7fe17f000000 r--p 00000000 08:11 1578302                    /usr/lib/mono/gac/Mono.Security/4.0.0.0__0738eb9f132ed756/Mono.Security.dll
7fe17f000000-7fe17f101000 rw-p 00000000 00:00 0
7fe17f101000-7fe17f114000 rw-p 00000000 00:00 0
7fe17f115000-7fe17f11f000 rw-p 00000000 00:00 0
7fe17f11f000-7fe17f144000 r--s 00000000 08:11 23858607                   /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-le64.cache-7
7fe17f144000-7fe17f1b3000 r--p 00000000 08:11 1574945                    /usr/lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
7fe17f1b3000-7fe17f4c3000 r--p 00000000 08:11 1578333                    /usr/lib/mono/gac/System.Xml/4.0.0.0__b77a5c561934e089/System.Xml.dll
7fe17f4c3000-7fe17f6e4000 r--p 00000000 08:11 1578335                    /usr/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll
7fe17f6e4000-7fe17f9cd000 r--p 00000000 08:11 1574906                    /usr/lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
7fe17f9cd000-7fe17fae4000 r--p 00000000 08:11 1845306                    /usr/lib/AirVPN/Lib.Forms.dll
7fe17fae4000-7fe18024b000 r-xp 00000000 08:11 30413907                   /usr/lib/mono/4.5/mscorlib.dll.so
7fe18024b000-7fe18044b000 ---p 00767000 08:11 30413907                   /usr/lib/mono/4.5/mscorlib.dll.so
7fe18044b000-7fe18044c000 rw-p 00767000 08:11 30413907                   /usr/lib/mono/4.5/mscorlib.dll.so
7fe18044c000-7fe18046a000 rw-p 00000000 00:00 0
7fe18046a000-7fe1807ff000 r--p 00000000 08:11 30413537                   /usr/lib/mono/4.5/mscorlib.dll
7fe1807ff000-7fe1817ff000 rw-p 00000000 00:00 0
7fe1817ff000-7fe181800000 ---p 00000000 00:00 0
7fe181800000-7fe182401000 rw-p 00000000 00:00 0
7fe182401000-7fe182404000 rw-p 00000000 00:00 0
7fe182404000-7fe182414000 rwxp 00000000 00:00 0
7fe182414000-7fe182434000 r--p 00000000 08:11 1577320                    /usr/lib/mono/gac/System.Configuration/4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
7fe182434000-7fe18248f000 r--p 00000000 08:11 1845311                    /usr/lib/AirVPN/Lib.Core.dll
7fe18248f000-7fe182498000 ---p 00000000 00:00 0
7fe182498000-7fe182785000 rw-p 00000000 00:00 0
7fe182785000-7fe1827e4000 ---p 00000000 00:00 0
7fe1827e4000-7fe18297b000 r-xp 00000000 08:11 29760028                   /usr/lib/libc-2.23.so
7fe18297b000-7fe182b7b000 ---p 00197000 08:11 29760028                   /usr/lib/libc-2.23.so
7fe182b7b000-7fe182b7f000 r--p 00197000 08:11 29760028                   /usr/lib/libc-2.23.so
7fe182b7f000-7fe182b81000 rw-p 0019b000 08:11 29760028                   /usr/lib/libc-2.23.so
7fe182b81000-7fe182b85000 rw-p 00000000 00:00 0
7fe182b85000-7fe182b9b000 r-xp 00000000 08:11 29770702                   /usr/lib/libgcc_s.so.1
7fe182b9b000-7fe182d9a000 ---p 00016000 08:11 29770702                   /usr/lib/libgcc_s.so.1
7fe182d9a000-7fe182d9b000 rw-p 00015000 08:11 29770702                   /usr/lib/libgcc_s.so.1
7fe182d9b000-7fe182db3000 r-xp 00000000 08:11 29756947                   /usr/lib/libpthread-2.23.so
7fe182db3000-7fe182fb2000 ---p 00018000 08:11 29756947                   /usr/lib/libpthread-2.23.so
7fe182fb2000-7fe182fb3000 r--p 00017000 08:11 29756947                   /usr/lib/libpthread-2.23.so
7fe182fb3000-7fe182fb4000 rw-p 00018000 08:11 29756947                   /usr/lib/libpthread-2.23.so
7fe182fb4000-7fe182fb8000 rw-p 00000000 00:00 0
7fe182fb8000-7fe182fba000 r-xp 00000000 08:11 29770639                   /usr/lib/libdl-2.23.so
7fe182fba000-7fe1831ba000 ---p 00002000 08:11 29770639                   /usr/lib/libdl-2.23.so
7fe1831ba000-7fe1831bb000 r--p 00002000 08:11 29770639                   /usr/lib/libdl-2.23.so
7fe1831bb000-7fe1831bc000 rw-p 00003000 08:11 29770639                   /usr/lib/libdl-2.23.so
7fe1831bc000-7fe1831c3000 r-xp 00000000 08:11 29770643                   /usr/lib/librt-2.23.so
7fe1831c3000-7fe1833c2000 ---p 00007000 08:11 29770643                   /usr/lib/librt-2.23.so
7fe1833c2000-7fe1833c3000 r--p 00006000 08:11 29770643                   /usr/lib/librt-2.23.so
7fe1833c3000-7fe1833c4000 rw-p 00007000 08:11 29770643                   /usr/lib/librt-2.23.so
7fe1833c4000-7fe1834c7000 r-xp 00000000 08:11 29770640                   /usr/lib/libm-2.23.so
7fe1834c7000-7fe1836c6000 ---p 00103000 08:11 29770640                   /usr/lib/libm-2.23.so
7fe1836c6000-7fe1836c7000 r--p 00102000 08:11 29770640                   /usr/lib/libm-2.23.so
7fe1836c7000-7fe1836c8000 rw-p 00103000 08:11 29770640                   /usr/lib/libm-2.23.so
7fe1836c8000-7fe1836eb000 r-xp 00000000 08:11 29760021                   /usr/lib/ld-2.23.so
7fe1836eb000-7fe1836ec000 rw-p 00000000 00:00 0
7fe1836ec000-7fe1836ff000 r--s 00000000 08:11 23858591                   /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-le64.cache-7
7fe1836ff000-7fe183897000 r--p 00000000 08:11 29808834                   /usr/lib/locale/locale-archive
7fe183897000-7fe18389e000 rw-p 00000000 00:00 0
7fe18389e000-7fe1838a4000 rw-p 00000000 00:00 0
7fe1838a4000-7fe1838a7000 r--s 00000000 08:11 23860518                   /var/cache/fontconfig/d4119bf364b3cb6badea4cd5ba92dc93-le64.cache-7
7fe1838a7000-7fe1838a9000 r--s 00000000 08:11 23858593                   /var/cache/fontconfig/6ba42ae0000f58711b5caaf10d690066-le64.cache-7
7fe1838a9000-7fe1838b8000 r--s 00000000 08:11 23858588                   /var/cache/fontconfig/f349e9996a5320f6dd491cedd2b1f964-le64.cache-7
7fe1838b8000-7fe1838ba000 rw-p 00000000 00:00 0
7fe1838ba000-7fe1838bd000 r--p 00000000 08:11 1574914                    /usr/lib/mono/gac/Accessibility/4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
7fe1838bd000-7fe1838c1000 r--p 00000000 08:11 1845305                    /usr/lib/AirVPN/Platforms.Linux.dll
7fe1838c1000-7fe1838cb000 rw-p 00000000 00:00 0
7fe1838cb000-7fe1838e0000 r--p 00000000 08:11 1845327                    /usr/lib/AirVPN/AirVPN.exe
7fe1838e0000-7fe1838ea000 rw-p 00000000 00:00 0
7fe1838ea000-7fe1838eb000 rw-s 00000000 00:14 185897                     /dev/shm/mono.7124
7fe1838eb000-7fe1838ec000 r--p 00023000 08:11 29760021                   /usr/lib/ld-2.23.so
7fe1838ec000-7fe1838ed000 rw-p 00024000 08:11 29760021                   /usr/lib/ld-2.23.so
7fe1838ed000-7fe1838ee000 rw-p 00000000 00:00 0
7ffe628f0000-7ffe628f8000 ---p 00000000 00:00 0
7ffe630ce000-7ffe630ef000 rw-p 00000000 00:00 0                          [stack]
7ffe631d9000-7ffe631dc000 r--p 00000000 00:00 0                          [vvar]
7ffe631dc000-7ffe631de000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Stacktrace:
  at <unknown> <0xffffffff>
  at (wrapper managed-to-native) System.Drawing.GDIPlus.GdipDeleteRegion (intptr) <0x0005f>
  at System.Drawing.Region.DisposeHandle () <0x0002b>
  at System.Drawing.Region.Dispose () <0x0000f>
  at (wrapper remoting-invoke-with-check) System.Drawing.Region.Dispose () <0x00053>
  at System.Windows.Forms.Control/DoubleBuffer.Invalidate () <0x00023>
  at System.Windows.Forms.Control.InvalidateBackBuffer () <0x0002b>
  at System.Windows.Forms.Control.OnInvalidated (System.Windows.Forms.InvalidateEventArgs) <0x0008f>
  at System.Windows.Forms.Control.Invalidate (System.Drawing.Rectangle,bool) <0x004c9>
  at System.Windows.Forms.Control.Invalidate () <0x0002b>
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control.Invalidate () <0x00053>
  at System.Windows.Forms.Control.Invalidate (System.Drawing.Rectangle,bool) <0x002fb>
  at System.Windows.Forms.Control.Invalidate (System.Drawing.Rectangle,bool) <0x0019f>
  at System.Windows.Forms.Control.Invalidate (bool) <0x00037>
  at System.Windows.Forms.Control.Refresh () <0x00033>
  at AirVPN.Gui.Forms.Main.OnMonoDelayedRedraw (object,System.Timers.ElapsedEventArgs) <0x0002b>
  at System.Timers.Timer.MyTimerCallback (object) <0x0013e>
  at System.Threading.Timer/Scheduler.TimerCB (object) <0x00147>
  at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () <0x0002f>
  at System.Threading.ThreadPoolWorkQueue.Dispatch () <0x001d6>
  at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () <0x00008>
  at (wrapper runtime-invoke) <Module>.runtime_invoke_bool (object,intptr,intptr,intptr) <0x0005a>
Native stacktrace:
    mono() [0x4ac77f]
    /usr/lib/libpthread.so.0(+0x10f00) [0x7fe182dabf00]
    /usr/lib/libc.so.6(gsignal+0x35) [0x7fe182817295]
    /usr/lib/libc.so.6(abort+0x16a) [0x7fe1828186da]
    /usr/lib/libc.so.6(+0x6ed50) [0x7fe182852d50]
    /usr/lib/libc.so.6(+0x74546) [0x7fe182858546]
    /usr/lib/libc.so.6(+0x74d1e) [0x7fe182858d1e]
    /usr/lib/libgdiplus.so(+0x34fd8) [0x7fe17ed7afd8]
    /usr/lib/libgdiplus.so(GdipDeleteRegion+0x13) [0x7fe17ed7b293]
    [0x406915c0]
Debug info from gdb:
[New LWP 7125]
[New LWP 7126]
[New LWP 7128]
[New LWP 7129]
[New LWP 7130]
[New LWP 7131]
[New LWP 7175]
[New LWP 7176]
[New LWP 7177]
[New LWP 7178]
[New LWP 7183]
[New LWP 7184]
[New LWP 7185]
[New LWP 7186]
warning: File "/usr/bin/mono-sgen-gdb.py" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load".
To enable execution of this file add
    add-auto-load-safe-path /usr/bin/mono-sgen-gdb.py
line to your configuration file "/root/.gdbinit".
To completely disable this security protection add
    set auto-load safe-path /
For more information about this security protection see the
"Auto-loading safe path" section in the GDB manual.  E.g., run from the shell:
    info "(gdb)Auto-loading safe path"
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
  Id   Target Id         Frame
* 1    Thread 0x7fe183897780 (LWP 7124) "mono" 0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
  2    Thread 0x7fe181fff700 (LWP 7125) "mono" 0x00007fe182da80af in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  3    Thread 0x7fe18268f700 (LWP 7126) "Finalizer" 0x00007fe182daa497 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
  4    Thread 0x7fe172373700 (LWP 7128) "mono" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  5    Thread 0x7fe172172700 (LWP 7129) "mono" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  6    Thread 0x7fe171f71700 (LWP 7130) "mono" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  7    Thread 0x7fe171d70700 (LWP 7131) "mono" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  8    Thread 0x7fe1717ff700 (LWP 7175) "Timer-Scheduler" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  9    Thread 0x7fe17267b700 (LWP 7176) "mono" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  10   Thread 0x7fe1715fe700 (LWP 7177) "Threadpool work" 0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
  11   Thread 0x7fe1713fd700 (LWP 7178) "Threadpool work" 0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
  12   Thread 0x7fe17196f700 (LWP 7183) "Threadpool work" 0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
  13   Thread 0x7fe170cf7700 (LWP 7184) "Threadpool work" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  14   Thread 0x7fe1708ff700 (LWP 7185) "Threadpool work" 0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
  15   Thread 0x7fe1706fe700 (LWP 7186) "Threadpool work" 0x00007fe182dabb5b in waitpid () from /usr/lib/libpthread.so.0
Thread 15 (Thread 0x7fe1706fe700 (LWP 7186)):
#0  0x00007fe182dabb5b in waitpid () from /usr/lib/libpthread.so.0
#1  0x00000000004ac856 in ?? ()
#2  <signal handler called>
#3  0x00007fe182817295 in raise () from /usr/lib/libc.so.6
#4  0x00007fe1828186da in abort () from /usr/lib/libc.so.6
#5  0x00007fe182852d50 in __libc_message () from /usr/lib/libc.so.6
#6  0x00007fe182858546 in malloc_printerr () from /usr/lib/libc.so.6
#7  0x00007fe182858d1e in _int_free () from /usr/lib/libc.so.6
#8  0x00007fe17ed7afd8 in ?? () from /usr/lib/libgdiplus.so
#9  0x00007fe17ed7b293 in GdipDeleteRegion () from /usr/lib/libgdiplus.so
#10 0x00000000406915c0 in ?? ()
#11 0x00007fe17249a2e8 in ?? ()
#12 0x0000000002a1a148 in ?? ()
#13 0x00007fe17249a2e8 in ?? ()
#14 0x00007fe170a9e6b0 in ?? ()
#15 0x00007fe170a9e6b0 in ?? ()
#16 0x00007fe13c001960 in ?? ()
#17 0x0000000002e7a100 in ?? ()
#18 0x00007fe1706fd140 in ?? ()
#19 0x00007fe1706fcee0 in ?? ()
#20 0x000000004069153c in ?? ()
#21 0x00007fe170a9e6b0 in ?? ()
#22 0x00000000406914e0 in ?? ()
#23 0x00007fe170a9e6b0 in ?? ()
#24 0x00000000406914a4 in ?? ()
#25 0x00007fe17249a2e8 in ?? ()
#26 0x00007fe17237ddd8 in ?? ()
#27 0x0000000000000000 in ?? ()
Thread 14 (Thread 0x7fe1708ff700 (LWP 7185)):
#0  0x00007fe182da8458 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
#1  0x000000000059bbe4 in ?? ()
#2  0x0000000000596801 in ?? ()
#3  0x000000000064719a in ?? ()
#4  0x00007fe182da2484 in start_thread () from /usr/lib/libpthread.so.0
#5  0x00007fe1828cb6dd in clone () from /usr/lib/libc.so.6
Thread 13 (Thread 0x7fe170cf7700 (LWP 7184)):
Thread 12 (Thread 0x7fe17196f700 (LWP 7183)):
#0  0x00007fe1828c26cd in poll () from /usr/lib/libc.so.6
#1  0x000000000059d472 in ?? ()
#2  0x000000000059e278 in ?? ()
#3  0x0000000000596801 in ?? ()
#4  0x000000000064719a in ?? ()
#5  0x00007fe182da2484 in start_thread () from /usr/lib/libpthread.so.0
#6  0x00007fe1828cb6dd in clone () from /usr/lib/libc.so.6
Thread 11 (Thread 0x7fe1713fd700 (LWP 7178)):
#1  0x00007fe173133c73 in ?? () from /usr/lib/libresolv.so.2
#2  0x00007fe173131c14 in __libc_res_nquery () from /usr/lib/libresolv.so.2
#3  0x00007fe173132285 in ?? () from /usr/lib/libresolv.so.2
#4  0x00007fe173132666 in __libc_res_nsearch () from /usr/lib/libresolv.so.2
#5  0x00007fe170ff9616 in _nss_dns_gethostbyname3_r () from /usr/lib/libnss_dns.so.2
#6  0x00007fe1828b78e3 in gaih_inet () from /usr/lib/libc.so.6
#7  0x00007fe1828b8681 in getaddrinfo () from /usr/lib/libc.so.6
#8  0x0000000000649463 in ?? ()
#9  0x000000000058734c in ?? ()
#10 0x00000000406ddec7 in ?? ()
#11 0x00007fe18237c980 in ?? ()
#12 0x00007fe18237cc20 in ?? ()
#13 0x0000000000001388 in ?? ()
#14 0x00007fe18237ca40 in ?? ()
#15 0x00007fe18237cc40 in ?? ()
#16 0x00007fe14c001960 in ?? ()
#17 0x0000000000001388 in ?? ()
#18 0x00007fe1713fc570 in ?? ()
#19 0x00007fe1713fc3a0 in ?? ()
#20 0x00000000406ddbd8 in ?? ()
#21 0x00007fe18237ca10 in ?? ()
#22 0x00007fe18237cc40 in ?? ()
#23 0x0000000000000000 in ?? ()
Thread 10 (Thread 0x7fe1715fe700 (LWP 7177)):
#4  0x00007fe173132a23 in __libc_res_nsearch () from /usr/lib/libresolv.so.2
#11 0x00007fe182379830 in ?? ()
#12 0x00007fe182379ad8 in ?? ()
#14 0x00007fe1823798f0 in ?? ()
#15 0x00007fe182379af8 in ?? ()
#16 0x00007fe158001960 in ?? ()
#18 0x00007fe1715fd570 in ?? ()
#19 0x00007fe1715fd3a0 in ?? ()
#21 0x00007fe1823798c0 in ?? ()
#22 0x00007fe182379af8 in ?? ()
Thread 9 (Thread 0x7fe17267b700 (LWP 7176)):
#1  0x0000000000645c8d in ?? ()
#2  0x000000000059ac61 in ?? ()
Thread 8 (Thread 0x7fe1717ff700 (LWP 7175)):
#1  0x000000000061b9a9 in ?? ()
#2  0x0000000000632523 in ?? ()
#3  0x0000000000596080 in ?? ()
#4  0x000000000059613d in ?? ()
#5  0x00000000406a60fd in ?? ()
#6  0x0000000000000038 in ?? ()
#7  0x00007fe15c1540d8 in ?? ()
#8  0x0000000000015f60 in ?? ()
#9  0x00007fe1823b5998 in ?? ()
#10 0x0000000000015f60 in ?? ()
#11 0x00007fe160001960 in ?? ()
#12 0x00007fe1823b5998 in ?? ()
#13 0x00007fe1717fe6d0 in ?? ()
#14 0x00007fe1717fe640 in ?? ()
#15 0x00007fe17fe3b3da in ?? () from /usr/lib/mono/4.5/mscorlib.dll.so
#16 0x00007fe1823a8a00 in ?? ()
#17 0x0000000000000000 in ?? ()
Thread 7 (Thread 0x7fe171d70700 (LWP 7131)):
#6  0x00007fe1820b1238 in ?? ()
#7  0x00007fe182047de0 in ?? ()
#8  0x00007fe1820b1238 in ?? ()
#9  0x00007fe18204c7b8 in ?? ()
#10 0x0000000000002710 in ?? ()
#11 0x00007fe15c001960 in ?? ()
#12 0x00007fe18204c7b8 in ?? ()
#13 0x00007fe171d6ee50 in ?? ()
#14 0x00007fe171d6edc0 in ?? ()
#16 0x00007fe1820b1401 in ?? ()
Thread 6 (Thread 0x7fe171f71700 (LWP 7130)):
#2  0x0000000000595e33 in ?? ()
#3  0x000000004060d592 in ?? ()
#4  0x00007fe1820cd870 in ?? ()
#5  0x00007fe17c078d60 in ?? ()
#6  0x0000000000000068 in ?? ()
#7  0x00007fe1820be2b8 in ?? ()
#8  0x00007fe1820cd7e0 in ?? ()
#9  0x00007fe168001960 in ?? ()
#10 0x00007fe17fc8f4e0 in ?? () from /usr/lib/mono/4.5/mscorlib.dll.so
#11 0x00007fe171f70860 in ?? ()
#12 0x00007fe171f70740 in ?? ()
#13 0x00007fe17fc8f4f7 in ?? () from /usr/lib/mono/4.5/mscorlib.dll.so
#14 0x0000000000000064 in ?? ()
#15 0x000000004060d360 in ?? ()
#16 0x00007fe16c023570 in ?? ()
#17 0x000000004060d379 in ?? ()
#18 0x00007fe17fb11390 in ?? () from /usr/lib/mono/4.5/mscorlib.dll.so
#19 0x0000000000000064 in ?? ()
#20 0x00007fe171f70860 in ?? ()
#21 0x000000004060d048 in ?? ()
#22 0x0000000000000000 in ?? ()
Thread 5 (Thread 0x7fe172172700 (LWP 7129)):
#4  0x000000000000000a in ?? ()
#5  0x00007fe182211040 in ?? ()
#6  0x00000000000000b4 in ?? ()
#7  0x00007fe18207b478 in ?? ()
#8  0x00007fe18218d5d0 in ?? ()
#9  0x00007fe164001960 in ?? ()
#10 0x000000a400000000 in ?? ()
#11 0x00007fe172171860 in ?? ()
#12 0x00007fe1721716f0 in ?? ()
#14 0x00000000000003e8 in ?? ()
#15 0x00007fe1721717f8 in ?? ()
#16 0x00007fe18208f568 in ?? ()
#18 0x00007fe18218d5d0 in ?? ()
#19 0x00000000000003e8 in ?? ()
#20 0x000000004060ccfa in ?? ()
#21 0x000000004060cd48 in ?? ()
#22 0x000000007fffffff in ?? ()
#23 0x00007fe17c078d60 in ?? ()
#24 0x00007fe18207b478 in ?? ()
#25 0x00007fe1820cd5c8 in ?? ()
#26 0x00007fe1721717f8 in ?? ()
#27 0x00007fe1820cd5c8 in ?? ()
#28 0x00000000405f55f1 in ?? ()
#29 0x00007fe17c078d60 in ?? ()
#30 0x00007fe17c078d60 in ?? ()
#31 0x00007fe17c078d60 in ?? ()
#32 0x0000000000000000 in ?? ()
Thread 4 (Thread 0x7fe172373700 (LWP 7128)):
#4  0x00007fe182735e70 in ?? ()
#5  0x00007fe182074038 in ?? ()
#6  0x00007fe1724ab420 in ?? ()
#7  0x0000000000000000 in ?? ()
Thread 3 (Thread 0x7fe18268f700 (LWP 7126)):
#0  0x00007fe182daa497 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
#1  0x00007fe182daa544 in __new_sem_wait_slow.constprop.0 () from /usr/lib/libpthread.so.0
#2  0x00000000005b66c7 in ?? ()
Thread 2 (Thread 0x7fe181fff700 (LWP 7125)):
#0  0x00007fe182da80af in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
#1  0x0000000000615473 in ?? ()
#2  0x00007fe182da2484 in start_thread () from /usr/lib/libpthread.so.0
#3  0x00007fe1828cb6dd in clone () from /usr/lib/libc.so.6
Thread 1 (Thread 0x7fe183897780 (LWP 7124)):
#1  0x00000000406c19d6 in ?? ()
#2  0x0000000000000002 in ?? ()
#3  0x00007ffe630ec050 in ?? ()
#4  0x00007fe1820b2e50 in ?? ()
#5  0x00007fe172462bf0 in ?? ()
#6  0x0000000000000002 in ?? ()
#7  0x00007fe172691560 in ?? ()
#8  0x0000000002965bb0 in ?? ()
#9  0x00007ffe630ec050 in ?? ()
#10 0x00007ffe630ec050 in ?? ()
#11 0x00007ffe630eb580 in ?? ()
#12 0x00007fe1820b2e70 in ?? ()
#13 0x00007fe172690001 in ?? ()
#14 0x00007ffe630ec050 in ?? ()
#15 0x00000000406c1148 in ?? ()
#16 0x00007ffe630eb970 in ?? ()
#17 0x00007ffe630ec050 in ?? ()
#18 0x00007fe1726a7230 in ?? ()
#19 0x00007fe172691560 in ?? ()
#20 0x00007ffe630eb970 in ?? ()
#21 0x00007ffe630eb970 in ?? ()
#22 0x000000000000000f in ?? ()
#23 0x00007fe1820b2e78 in ?? ()
#24 0x00000000406b24e5 in ?? ()
#25 0x00000000406b2584 in ?? ()
#26 0x00007fe1723926e0 in ?? ()
#27 0x00007ffe630eb938 in ?? ()
#28 0x0000000000000000 in ?? ()
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
/usr/bin/airvpn: line 2:  7124 Aborted                 (core dumped) mono /usr/lib/AirVPN/AirVPN.exe --path=$HOME/.airvpn "$@"
