cm0s
Conky
# arch_conky_nvidia
# splif edit 061817
background no
use_xft yes
xftfont sans:size=12
xftalpha 0.5
update_interval 1
double_buffer yes
total_run_times 0
own_window yes
own_window_transparent yes
own_window_type override
own_window_hints undecorate,sticky,skip_taskbar,skip_pager
default_bar_size 0 6
maximum_width 285
minimum_size 285
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
alignment top_left
gap_x 15
gap_y 20
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 2
override_utf8_locale yes
use_spacer none
default_shade_color 2E2E2D
default_color 606060
color0 606060
color1 4E7A79
color2 8A7C3E
color3 4A8754
color4 53A5B8
TEXT
${color2}${font :bold:size=11}s1stm ${color0}${hr 1} ${font :size=11}
${color0}${font :size=12}KERNL:${color1} ${alignr} ${kernel}
${color0}${font :size=12}ONLINE:${color1} ${alignr} ${uptime}
${color0}${font :size=12}TIME:${color1} ${alignr} ${exec date +"%H:%M"}
${color0}${font :size=12}DATE:${color1} ${alignr} ${exec date +"%A %b %d %Y"}
${color0}${hr 1}
${color1}┣━pr0cz${alignr}%cpu
${color1}┃ ${if_match ${top cpu 1} < 1}${color2}${else}${if_match ${top cpu 1} < 2}${color3}${else}${if_match ${top cpu 1} < 4}${color4}${else}${if_match ${top cpu 1} < 8}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top name 1}$alignr${top cpu 1}
${color1}┃ ${if_match ${top cpu 2} < 1}${color2}${else}${if_match ${top cpu 2} < 2}${color3}${else}${if_match ${top cpu 2} < 4}${color4}${else}${if_match ${top cpu 2} < 8}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top name 2}$alignr${top cpu 2}
${color1}┃ ${if_match ${top cpu 3} < 1}${color2}${else}${if_match ${top cpu 3} < 2}${color3}${else}${if_match ${top cpu 3} < 4}${color4}${else}${if_match ${top cpu 3} < 8}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top name 3}$alignr${top cpu 3}
${color1}┃ ${if_match ${top cpu 4} < 1}${color2}${else}${if_match ${top cpu 4} < 2}${color3}${else}${if_match ${top cpu 4} < 4}${color4}${else}${if_match ${top cpu 4} < 8}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top name 4}$alignr${top cpu 4}
${color1}┃ ${if_match ${top cpu 5} < 1}${color2}${else}${if_match ${top cpu 5} < 2}${color3}${else}${if_match ${top cpu 5} < 4}${color4}${else}${if_match ${top cpu 5} < 8}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top name 5}$alignr${top cpu 5}
${color1}┃
┣━appz${alignr}mem
${color1}┃ ${if_match ${eval ${execp echo '${top_mem mem 1}' | xargs}} < 0.5}${color2}${else}${if_match ${eval ${execp echo '${top_mem mem 1}' | xargs}} < 2.1}${color3}${else}${if_match ${eval ${execp echo '${top_mem mem 1}' | xargs}} < 4.2}${color4}${else}${if_match ${eval ${execp echo '${top_mem mem 1}' | xargs}} < 8.4}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top_mem name 1}${alignr}${top_mem mem_res 1}
${color1}┃ ${if_match ${eval ${execp echo '${top_mem mem 2}' | xargs}} < 0.5}${color2}${else}${if_match ${eval ${execp echo '${top_mem mem 2}' | xargs}} < 2.1}${color3}${else}${if_match ${eval ${execp echo '${top_mem mem 2}' | xargs}} < 4.2}${color4}${else}${if_match ${eval ${execp echo '${top_mem mem 2}' | xargs}} < 8.4}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top_mem name 2}${alignr}${top_mem mem_res 2}
${color1}┃ ${if_match ${eval ${execp echo '${top_mem mem 3}' | xargs}} < 0.5}${color2}${else}${if_match ${eval ${execp echo '${top_mem mem 3}' | xargs}} < 2.1}${color3}${else}${if_match ${eval ${execp echo '${top_mem mem 3}' | xargs}} < 4.2}${color4}${else}${if_match ${eval ${execp echo '${top_mem mem 3}' | xargs}} < 8.4}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top_mem name 3}${alignr}${top_mem mem_res 3}
${color1}┃ ${if_match ${eval ${execp echo '${top_mem mem 4}' | xargs}} < 0.5}${color2}${else}${if_match ${eval ${execp echo '${top_mem mem 4}' | xargs}} < 2.1}${color3}${else}${if_match ${eval ${execp echo '${top_mem mem 4}' | xargs}} < 4.2}${color4}${else}${if_match ${eval ${execp echo '${top_mem mem 4}' | xargs}} < 8.4}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top_mem name 4}${alignr}${top_mem mem_res 4}
${color1}┃ ${if_match ${eval ${execp echo '${top_mem mem 5}' | xargs}} < 0.5}${color2}${else}${if_match ${eval ${execp echo '${top_mem mem 5}' | xargs}} < 2.1}${color3}${else}${if_match ${eval ${execp echo '${top_mem mem 5}' | xargs}} < 4.2}${color4}${else}${if_match ${eval ${execp echo '${top_mem mem 5}' | xargs}} < 8.4}${color5}${else}${color6}${endif}${endif}${endif}${endif}${top_mem name 5}${alignr}${top_mem mem_res 5}
${color2}${font :bold:size=11}n3twrx ${color0}${hr 1} ${font :size=11}
${color1}wan: ${color0} ${alignr} ${execi 60 curl https://ipv4.icanhazip.com/ | tail}
${color1}lan: ${color0} ${alignr} ${addr eth0}
${color1}dns: ${color0} ${alignr} ${nameserver}
${color1}tun0: ${color0} ${alignr} ${addr tun0}
${color1}wlan0: ${color0} ${alignr} ${addr wlan0}
${color1}mon: ${color0} ${alignr} ${addr wlan0mon}
${color1}gateway: ${color0} ${alignr} ${gw_ip}
${color1}essid: ${color0} ${alignr} ${wireless_essid wlan0}
${color1}AP-mac: ${color0} ${alignr} ${wireless_ap}
${color1}signal: ${color0} ${alignr} ${wireless_link_qual_perc wlan0}
${color1}mode: ${color0} ${alignr} ${wireless_mode wlan0}
${color2}▲ ${color1}UP: ${alignr} ${upspeedf eth0} ${color0}k/s
${color4}${voffset -14} ${alignc} ${upspeedgraph eth0 10,80}
${color2}▼ ${color1}DOWN: ${alignr} ${downspeedf eth0} ${color0}k/s
${color4}${voffset -14} ${alignc} ${downspeedgraph eth0 10,80}
${color2} ${font :bold:size=11}nmap ${color1} ${hr 1} ${font :size=11}
${color0} ${font :size=11} ${execi 120 nmap -sP 192.168.1.0/24 | awk '/Nmap scan report for/{printf $5;}/MAC Address:/{print " ➜ "$3;}' | awk '{ printf "%-15s%-20s%s\n",$1,$2,$3}'}
${color2}${font :bold:size=11}n3tstat ${color0}${hr 1} ${font :size=11}
#${color0}${execi 120 netstat -e -p -t | grep ESTABLISHED | cut -c45-68,80-86,102-140 | rev | column -t | rev}
${execi 60 netstat -ept | grep ESTAB | awk '{print $9}' | cut -d: -f1 | sort | uniq -c | column -t}
${color0}${hr 1}
can start it with:
#!/bin/sh
# starts conky
# 040817_edit
# chmod +x startz.sh
# ./startz.sh
sleep 2
conky -q -c ~/.conx/conxarch & exit
