oollaa
Airvpn on SJ (Swedish trains)
My Airvpn will not connect when I´m online using the public wifi on the SJ trains in Sweden, anyone had the same problem?
I´m using OpenVpn (Ios)
I found this (https://kundo.se/org/sj/d/problem-med-vpn-pa-sj-tag/)   (In swedish)
Th MTU must be set to 1225 or lower,
VPN software must be NAT-capable,
Firewalls need to be open for GRE traffic and TCP traffic on port 1723.
GRE and TCP port 1723 are required for PPTP/L2TP based VPNs, not for OpenVPN.
In order for AirVPN to work, you need to have either TCP/UDP 53/80/443/2018 ports open,
or alternatively port 22 for SSH tunnelling to the servers.
This is a hard scenario to reproduce (unless other readers use the train WiFi in Sweden as well)
so only you can effectively test what works.
