VpnTurtle
DD-WRT firewall script problems
I've a new router (Linksys WRT1200AC), I've configured it using this guide https://airvpn.org/ddwrt/ and it is working perfectly.
The only problem is that firewall script doesn't work.
In the past I've used this script on a similar router:
iptables -I FORWARD -i br0 -o tun1 -j ACCEPT
iptables -I FORWARD -i tun1 -o br0 -j ACCEPT
iptables -I FORWARD -i br0 -o vlan2 -j DROP
iptables -I INPUT -i tun1 -j REJECT
iptables -t nat -A POSTROUTING -o tun1 -j MASQUERADE
But with this new router, it doesn't work: I can still access the net while I'm not connected to the VPN...
Can someone help me with this please?
What are your interface names? Run ifconfig and update the interfaces in the script accordingly.
Should I run ifconfig on the router itself (using ssh) or from my computer connected to the router?
