Not connected, Your IP: 216.73.216.161
chepper.jones
Airvpn client stuck checking routes
I'm using eddie client (no Mono since there are no available dependencies in Debian Testing) and since some days ago it's getting stuck in "Checking Routes" phase, after some time it will log "Request timeout". I normally use it through tor network but now I have set it in differen ways without result. Try with and without tor, also download the package again and still the same.
here is the log:
 2016.05.25 22:32:11 - Session starting.
W 2016.05.25 22:32:11 - Unable to understand if IPV6 is active.
I 2016.05.25 22:32:11 - Checking authorization ...
! 2016.05.25 22:32:12 - Connecting to Regulus (Canada, Toronto, Ontario)
. 2016.05.25 22:32:12 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Aug 13 2015
. 2016.05.25 22:32:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.25 22:32:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.25 22:32:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.25 22:32:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.25 22:32:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.25 22:32:12 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.05.25 22:32:12 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.25 22:32:12 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.34:443
. 2016.05.25 22:32:13 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.34:443, sid=35c02534 dfd7b39f
. 2016.05.25 22:32:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.25 22:32:13 - OpenVPN > Validating certificate key usage
. 2016.05.25 22:32:13 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.25 22:32:13 - OpenVPN > VERIFY KU OK
. 2016.05.25 22:32:13 - OpenVPN > Validating certificate extended key usage
. 2016.05.25 22:32:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.25 22:32:13 - OpenVPN > VERIFY EKU OK
. 2016.05.25 22:32:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.25 22:32:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.25 22:32:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.25 22:32:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.25 22:32:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.25 22:32:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.25 22:32:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.34:443
. 2016.05.25 22:32:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.25 22:32:23 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.251 255.255.0.0'
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.25 22:32:23 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.e25 22:32:23 - OpenVPN > TUN/TAP device tun0 opened
. 2016.05.25 22:32:23 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.05.25 22:32:23 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.25 22:32:23 - OpenVPN > /sbin/ifconfig tun0 10.4.14.251 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.05.25 22:32:28 - OpenVPN > /sbin/route add -net 184.75.221.34 netmask 255.255.255.255 gw 192.168.1.1
. 2016.05.25 22:32:28 - OpenVPN > /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.05.25 22:32:28 - OpenVPN > /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.4.0.1
. 2016.05.25 22:32:28 - Starting Management Interface
. 2016.05.25 22:32:28 - OpenVPN > Initialization Sequence Completed
I 2016.05.25 22:32:28 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.05.25 22:32:28 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.05.25 22:32:28 - Flushing DNS
I 2016.05.25 22:32:28 - Checking route
W 2016.05.25 22:33:18 - The request timed out
! 2016.05.25 22:33:18 - Disconnecting
. 2016.05.25 22:33:18 - Management - Send 'signal SIGTERM'
. 2016.05.25 22:33:18 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.25 22:33:18 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.05.25 22:33:18 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.05.25 22:33:18 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.05.25 22:33:23 - OpenVPN > /sbin/route del -net 184.75.221.34 netmask 255.255.255.255
. 2016.05.25 22:33:23 - OpenVPN > /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
. 2016.05.25 22:33:23 - OpenVPN > /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
. 2016.05.25 22:33:23 - OpenVPN > Closing TUN/TAP interface
. 2016.05.25 22:33:23 - OpenVPN > /sbin/ifconfig tun0 0.0.0.0
. 2016.05.25 22:33:23 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.05.25 22:33:23 - Connection terminated.
I 2016.05.25 22:33:23 - DNS of the system restored to original settings (Rename method)
Let me know your opinion.
Regards.
