BloodyMary
Connecting then immediately disconecting
Hi i recently got airvpn and it worked fine for the first day or so but now it connects and then immediately disconnects no mater what server i try to coronet with and i've not touched any of the setting at all. Am i doing something wrong?? can i get any help please
I 2016.05.08 18:49:51 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7600.0 / x64
. 2016.05.08 18:49:51 - Reading options from C:\Users\......5\AppData\Local\AirVPN\AirVPN.xml
. 2016.05.08 18:49:51 - Data Path: C:\Users\Johnny5\AppData\Local\AirVPN
. 2016.05.08 18:49:51 - App Path: C:\Program Files\AirVPN
. 2016.05.08 18:49:51 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.05.08 18:49:51 - Command line arguments (1): path="home"
. 2016.05.08 18:49:51 - Operating System: Microsoft Windows NT 6.1.7600.0
. 2016.05.08 18:49:51 - Updating systems & servers data ...
I 2016.05.08 18:49:52 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.05.08 18:49:52 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.05.08 18:49:52 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.05.08 18:49:52 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.05.08 18:49:52 - Ready
. 2016.05.08 18:49:52 - Systems & servers data update completed
I 2016.05.08 18:49:53 - Session starting.
I 2016.05.08 18:49:53 - IPv6 disabled.
I 2016.05.08 18:49:54 - Checking authorization ...
! 2016.05.08 18:49:55 - Connecting to Tejat (Canada, Toronto, Ontario)
. 2016.05.08 18:49:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.08 18:49:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.08 18:49:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.08 18:49:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.08 18:49:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.08 18:49:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.08 18:49:55 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.05.08 18:49:55 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.08 18:49:55 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.194:443
. 2016.05.08 18:49:55 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.194:443, sid=deda6c90 b82b5718
. 2016.05.08 18:49:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.08 18:49:55 - OpenVPN > Validating certificate key usage
. 2016.05.08 18:49:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.08 18:49:55 - OpenVPN > VERIFY KU OK
. 2016.05.08 18:49:55 - OpenVPN > Validating certificate extended key usage
. 2016.05.08 18:49:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.08 18:49:55 - OpenVPN > VERIFY EKU OK
. 2016.05.08 18:49:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.08 18:49:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.08 18:49:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.08 18:49:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.08 18:49:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.08 18:49:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.08 18:49:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.194:443
. 2016.05.08 18:49:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.08 18:50:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.9.181 255.255.0.0'
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.08 18:50:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.08 18:50:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.08 18:50:00 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.08 18:50:00 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{34C41A4A-120B-4BEA-88B2-08454F2B8C25}.tap
. 2016.05.08 18:50:00 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.05.08 18:50:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.9.181/255.255.0.0 [sUCCEEDED]
. 2016.05.08 18:50:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.9.181/255.255.0.0 on interface {34C41A4A-120B-4BEA-88B2-08454F2B8C25} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.05.08 18:50:00 - OpenVPN > Successful ARP Flush on interface [13] {34C41A4A-120B-4BEA-88B2-08454F2B8C25}
. 2016.05.08 18:50:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:05 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:10 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:11 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:12 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:13 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:14 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:15 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:16 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:17 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:19 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:20 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:22 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:23 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:24 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:25 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:27 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:28 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:29 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:30 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:31 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:32 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:33 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2016.05.08 18:50:34 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2016.05.08 18:50:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2016.05.08 18:50:35 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.221.194 MASK 255.255.255.255 192.168.2.1
. 2016.05.08 18:50:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.05.08 18:50:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.05.08 18:50:35 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 15
. 2016.05.08 18:50:35 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.08 18:50:35 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.05.08 18:50:35 - OpenVPN > SYSTEM ROUTING TABLE
. 2016.05.08 18:50:35 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.2.1 p=0 i=15 t=4 pr=3 a=688821 h=0 m=20/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=15 t=4 pr=3 a=58263 h=0 m=21/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=13 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.61.106 p=0 i=13 t=3 pr=3 a=85686 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 10.4.61.106 255.255.255.255 10.4.61.106 p=0 i=13 t=3 pr=3 a=85686 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.61.106 p=0 i=13 t=3 pr=3 a=85686 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=688841 h=0 m=306/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=688841 h=0 m=306/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=688841 h=0 m=306/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=15 t=4 pr=3 a=58263 h=0 m=21/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=13 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 169.254.0.0 255.255.0.0 192.168.2.10 p=0 i=15 t=3 pr=3 a=688729 h=0 m=316/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 169.254.255.255 255.255.255.255 192.168.2.10 p=0 i=15 t=3 pr=3 a=688729 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 184.75.221.194 255.255.255.255 192.168.2.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 192.168.2.0 255.255.255.0 192.168.2.10 p=0 i=15 t=3 pr=3 a=688821 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 192.168.2.1 255.255.255.255 192.168.2.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 192.168.2.10 255.255.255.255 192.168.2.10 p=0 i=15 t=3 pr=3 a=688821 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 192.168.2.255 255.255.255.255 192.168.2.10 p=0 i=15 t=3 pr=3 a=688821 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=688841 h=0 m=306/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.2.10 p=0 i=15 t=3 pr=3 a=688826 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.61.106 p=0 i=13 t=3 pr=3 a=85701 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=688841 h=0 m=306/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.2.10 p=0 i=15 t=3 pr=3 a=688826 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.61.106 p=0 i=13 t=3 pr=3 a=85701 h=0 m=276/0/0/0/0
. 2016.05.08 18:50:35 - OpenVPN > SYSTEM ADAPTER LIST
. 2016.05.08 18:50:35 - OpenVPN > Microsoft Virtual WiFi Miniport Adapter #2
. 2016.05.08 18:50:35 - OpenVPN >   Index = 16
. 2016.05.08 18:50:35 - OpenVPN >   GUID = {4B3975E3-97B9-4610-8DDB-857C0141D04D}
. 2016.05.08 18:50:35 - OpenVPN >   IP = 0.0.0.0/0.0.0.0
. 2016.05.08 18:50:35 - OpenVPN >   MAC = 06:66:b3:07:d7:17
. 2016.05.08 18:50:35 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN >   DHCP SERV =
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE OBTAINED = Sun May 08 18:50:35 2016
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE EXPIRES  = Sun May 08 18:50:35 2016
. 2016.05.08 18:50:35 - OpenVPN >   DNS SERV =
. 2016.05.08 18:50:35 - OpenVPN > TP-LINK 450Mbps Wireless N Adapter
. 2016.05.08 18:50:35 - OpenVPN >   Index = 15
. 2016.05.08 18:50:35 - OpenVPN >   GUID = {6AF282E0-994C-4FB2-A491-6EC40C49EE34}
. 2016.05.08 18:50:35 - OpenVPN >   IP = 192.168.2.10/255.255.255.0
. 2016.05.08 18:50:35 - OpenVPN >   MAC = 64:66:b3:07:d7:17
. 2016.05.08 18:50:35 - OpenVPN >   GATEWAY = 192.168.2.1/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN >   DHCP SERV = 192.168.2.1/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE OBTAINED = Sun May 08 18:48:59 2016
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE EXPIRES  = Wed May 11 18:48:59 2016
. 2016.05.08 18:50:35 - OpenVPN >   DNS SERV = 192.168.2.1/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN > TAP-Windows Adapter V9
. 2016.05.08 18:50:35 - OpenVPN >   Index = 13
. 2016.05.08 18:50:35 - OpenVPN >   GUID = {34C41A4A-120B-4BEA-88B2-08454F2B8C25}
. 2016.05.08 18:50:35 - OpenVPN >   IP = 10.4.61.106/255.255.0.0
. 2016.05.08 18:50:35 - OpenVPN >   MAC = 00:ff:34:c4:1a:4a
. 2016.05.08 18:50:35 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE OBTAINED = Sat May 07 19:02:29 2016
. 2016.05.08 18:50:35 - OpenVPN >   DHCP LEASE EXPIRES  = Sun May 07 19:02:29 2017
. 2016.05.08 18:50:35 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2016.05.08 18:50:35 - OpenVPN > Realtek PCI GBE Family Controller
. 2016.05.08 18:50:35 - OpenVPN >   Index = 11
. 2016.05.08 18:50:35 - OpenVPN >   GUID = {5661DD46-C49C-46A0-8E45-6361EFB72142}
. 2016.05.08 18:50:35 - OpenVPN >   MAC = 14:da:e9:c5:c5:26
. 2016.05.08 18:50:35 - Starting Management Interface
. 2016.05.08 18:50:35 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2016.05.08 18:50:35 - DNS of a network adapter forced (TP-LINK 450Mbps Wireless N Adapter)
! 2016.05.08 18:50:35 - Disconnecting
. 2016.05.08 18:50:35 - Management - Send 'signal SIGTERM'
. 2016.05.08 18:50:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2016.05.08 18:50:35 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.05.08 18:50:35 - Flushing DNS
. 2016.05.08 18:50:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.05.08 18:50:35 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.05.08 18:50:35 - OpenVPN > SIGTERM received, sending exit notification to peer
I can fix the problem by resetting my computer but resting my computer every time i want to reconnect to airvpn is getting kind of old. what is the process name for airvpn so i can manually shut it off through task manager?
