hackers2016
Problem Connecting
I can't connect to the VPN at home I shut down my pc because I had to replace my RAID controller and when I turned back on my VPN won't connect to any server. I reinstall the software and I am still having problem connecting with or without network lock
​any suggestions
[sOLVED] NEVER MIND ​
Actually is not When I activate the network lock none of the servers responding only reconnecting
! 2016.04.30 14:51:23 - Connecting to Zibal (Netherlands, Alblasserdam)
. 2016.04.30 14:51:23 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.04.30 14:51:23 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.04.30 14:51:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.04.30 14:51:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.04.30 14:51:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.30 14:51:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.30 14:51:23 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.04.30 14:51:23 - OpenVPN > UDPv4 link local: [undef]
. 2016.04.30 14:51:23 - OpenVPN > UDPv4 link remote: [AF_INET]xx.x.xx.xx:443
. 2016.04.30 14:51:23 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.148:443, sid=1687fc77 064dcaba
. 2016.04.30 14:51:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.04.30 14:51:23 - OpenVPN > Validating certificate key usage
. 2016.04.30 14:51:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.04.30 14:51:23 - OpenVPN > VERIFY KU OK
. 2016.04.30 14:51:23 - OpenVPN > Validating certificate extended key usage
. 2016.04.30 14:51:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.04.30 14:51:23 - OpenVPN > VERIFY EKU OK
. 2016.04.30 14:51:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.04.30 14:51:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.30 14:51:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.30 14:51:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.04.30 14:51:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.04.30 14:51:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.04.30 14:51:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.148:443
. 2016.04.30 14:51:32 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.04.30 14:51:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS xx.x.xx.xx,comp-lzo no,route-gateway xx.x.xx.xx,topology subnet,ping 10,ping-restart 60,ifconfig xx.x.xx.xx 255.255.0.0'
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.04.30 14:51:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.04.30 14:51:32 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.04.30 14:51:32 - OpenVPN > open_tun, tt->ipv6=0
. 2016.04.30 14:51:32 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{2C5D017E-A190-4DE5-A3AB-AE69ADD81903}.tap
. 2016.04.30 14:51:32 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.04.30 14:51:32 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = xx.x.xx.xx/xx.x.xx.xx/255.255.0.0 [sUCCEEDED]
. 2016.04.30 14:51:32 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of xx.x.xx.xx/255.255.0.0 on interface {2C5D017E-A190-4DE5-A3AB-AE69ADD81903} [DHCP-serv: xx.x.xx.xx, lease-time: 31536000]
. 2016.04.30 14:51:32 - OpenVPN > Successful ARP Flush on interface [14] {2C5D017E-A190-4DE5-A3AB-AE69ADD81903}
. 2016.04.30 14:51:37 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.04.30 14:51:37 - OpenVPN > C:\Windows\system32\route.exe ADD xx.x.xx.xx MASK 255.255.255.255 192.168.1.1
. 2016.04.30 14:51:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2016.04.30 14:51:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.04.30 14:51:37 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 11
. 2016.04.30 14:51:37 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2016.04.30 14:51:37 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.04.30 14:51:37 - OpenVPN > Route addition fallback to route.exe
. 2016.04.30 14:51:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.04.30 14:51:37 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 xx.x.xx.xx
. 2016.04.30 14:51:37 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=14]
. 2016.04.30 14:51:37 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 xx.x.xx.xx
. 2016.04.30 14:51:37 - Starting Management Interface
W 2016.04.30 14:51:37 - An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100
! 2016.04.30 14:51:37 - Disconnecting
. 2016.04.30 14:51:37 - Connection terminated.
I 2016.04.30 14:51:39 - Cancel requested.
I 2016.04.30 14:51:39 - IPv6 restored.
! 2016.04.30 14:51:39 - Session terminated.
! 2016.04.30 14:51:42 - Deactivation of Network Lock
I 2016.04.30 14:51:50 - Session starting.
I 2016.04.30 14:51:51 - IPv6 disabled.
I 2016.04.30 14:51:51 - Checking authorization ...
I 2016.04.30 14:51:54 - Cancel requested.
I 2016.04.30 14:51:54 - IPv6 restored.
! 2016.04.30 14:51:54 - Session terminated.
Going through those logs it is not Network lock that cause the issue because you connect just fine to the server however
this error shows up, I recommend reinstalling TAP and see how goes.
NO I reinstalled both the software and TAP I can connect without network lock.
. 2016.05.01 23:58:05 - Connection terminated.
I 2016.05.01 23:58:09 - Checking authorization ...
! 2016.05.01 23:58:12 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.05.01 23:58:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.05.01 23:58:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.01 23:58:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.05.01 23:58:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.01 23:58:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.01 23:58:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.01 23:58:12 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.05.01 23:58:12 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.01 23:58:12 - OpenVPN > UDPv4 link remote: [AF_INET]xxx.xxx.xxx.xxx:443
. 2016.05.01 23:58:12 - OpenVPN > TLS: Initial packet from [AF_INET]xxx.xxx.xxx.xxx:443, sid=06b9bd47 dfce428c
. 2016.05.01 23:58:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.01 23:58:13 - OpenVPN > Validating certificate key usage
. 2016.05.01 23:58:13 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2016.05.01 23:58:13 - OpenVPN > VERIFY KU OK
. 2016.05.01 23:58:13 - OpenVPN > Validating certificate extended key usage
. 2016.05.01 23:58:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.01 23:58:13 - OpenVPN > VERIFY EKU OK
. 2016.05.01 23:58:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.01 23:58:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.01 23:58:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.01 23:58:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.01 23:58:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.01 23:58:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.01 23:58:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]xxx.xxx.xxx.xxx:443
. 2016.05.01 23:58:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.01 23:58:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS xxx.xxx.xxx.xxx,comp-lzo no,route-gateway xxx.xxx.xxx.xxx,topology subnet,ping 10,ping-restart 60,ifconfig xxx.xxx.xxx.xxx 255.255.0.0'
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.01 23:58:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.01 23:58:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.01 23:58:18 - OpenVPN > open_tun, tt->ipv6=0
. 2016.05.01 23:58:18 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{FF57B6EE-ADA9-455E-AF97-DCFF3DDCE25A}.tap
. 2016.05.01 23:58:18 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.05.01 23:58:18 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = xxx.xxx.xxx.xxx/xxx.xxx.xxx.xxx/255.255.0.0 [sUCCEEDED]
. 2016.05.01 23:58:18 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of xxx.xxx.xxx.xxx/255.255.0.0 on interface {FF57B6EE-ADA9-455E-AF97-DCFF3DDCE25A} [DHCP-serv: xxx.xxx.xxx.xxx, lease-time: 31536000]
. 2016.05.01 23:58:18 - OpenVPN > Successful ARP Flush on interface [14] {FF57B6EE-ADA9-455E-AF97-DCFF3DDCE25A}
. 2016.05.01 23:58:23 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.05.01 23:58:23 - OpenVPN > C:\Windows\system32\route.exe ADD xxx.xxx.xxx.xxx MASK 255.255.255.255 192.168.1.1
. 2016.05.01 23:58:23 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=11]
. 2016.05.01 23:58:23 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.05.01 23:58:23 - OpenVPN > Route addition fallback to route.exe
. 2016.05.01 23:58:23 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.05.01 23:58:23 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 11
. 2016.05.01 23:58:23 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 xxx.xxx.xxx.xxx
. 2016.05.01 23:58:23 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=14]
. 2016.05.01 23:58:23 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 xxx.xxx.xxx.xxx
. 2016.05.01 23:58:23 - Starting Management Interface
W 2016.05.01 23:58:37 - An attempt was made to access a socket in a way forbidden by its access permissions 127.0.0.1:3100
! 2016.05.01 23:58:37 - Disconnecting
. 2016.05.01 23:58:37 - Connection terminated.
Anyone?
I got a bit busy, glad you got it fixed however.
