mastijn
TCP Test fails
When I try to forward some random ports it simply does not work because the TCP Test keeps failing.
Does anyone know how to fix this?
I am using Windows 7 and Kali Linux 2.0
Thanks in advance
When it does the TCP test, it tries to connect to the port in question, if you got nothing listening for the port it can't connect.
