zebulon
Issue when trying to compile Eddie 2.11 alpha under Linux
I was told to try compiling this branch under Linux:
https://github.com/Clodo76/airvpn-client/tree/66243777b166ccfe89fd8539ba28d74459defdc9
However, it does not compile under Archlinux 64, with mono 4.4. I get this error:
Target CoreCompile:
Tool /usr/lib/mono/4.5/mcs.exe execution started with arguments: /noconfig /debug:pdbonly /optimize+ /out:obj/Release/Lib.Core.dll /resource:obj/Release/AirVPN.Lib.Core.Properties.Resources.resources AreaInfo.cs AirExchange.cs Commands.cs CompatibilityManager.cs CountriesManager.cs XmlItem.cs OvpnManager.cs RemoteAccess.cs ProgramScope.cs TorControl.cs IpAddressRange.cs NetworkLockManager.cs NetworkLockPlugin.cs IpAddress.cs NetworkLocks/RoutingTable.cs RouteScope.cs RouteEntry.cs Debug.cs Process.cs ResourcesFiles.cs TemporaryFile.cs TemporaryFiles.cs UI/Chart.cs UI/Charts.cs Constants.cs Conversions.cs UI/Actions.cs CommandLine.cs UI/Colors.cs RandomGenerator.cs Stats.cs StatsEntry.cs Messages.cs Recovery.cs Engine.cs LogEntry.cs Platform.cs Properties/AssemblyInfo.cs Properties/Resources.Designer.cs ServerInfo.cs Software.cs Storage.cs Thread.cs Threads/Manifest.cs Threads/Session.cs Threads/Penalities.cs Threads/Pinger.cs TimeDelta.cs TrustCertificatePolicy.cs Utils.cs WebClientEx.cs /target:library /win32icon:Resources/icon.ico /define:TRACE /nostdlib /reference:/usr/lib/mono/2.0-api/System.dll /reference:/usr/lib/mono/2.0-api/System.Drawing.dll /reference:/usr/lib/mono/2.0-api/System.Xml.dll /reference:/usr/lib/mono/2.0-api/mscorlib.dll /warn:4
CSC: error CS2001: Source file `XmlItem.cs' could not be found
I cannot find XmlItem.cs anywhere in Eddie code, or in another library. Any idea? Thanks.
Try to remove this line and recompile. This is alpha branch.
I did a recursive grep for XmlItem.cs on the whole repository and could not find any reference to it. Any idea?
I did a bit of progress. I use xbuild to build the source:
xbuild /p:Configuration="Release" /p:Platform="x64" src/AirVPN.sln
but I get a lot of exceptions. Firstly, a lot of png files are missing:
Inner exception: Could not find file "/home/zebulon/airvpn_clodo76/airvpn-client/src/Lib.Forms/res/warning.png".
This is an example, there are around 10 png files missing (success.png, error.png, status_red.png, etc.)
Then after replacing them with a few personal PNGs, I get this error:
Inner exception: Could not find a part of the path "/home/zebulon/airvpn_clodo76/airvpn-client/src/Lib.Forms/Resources/skins.xml".
This directory does not exist.
Is it an issue with src/AirVPN.sln ?
Please note the problem occurs when building the x86 version too.
