thomasqg 0 Posted ... Windows 10, Dell XPS15Here is the log: I 2016.03.20 15:12:44 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64. 2016.03.20 15:12:44 - Reading options from C:\Users\Tom\AppData\Local\AirVPN\AirVPN.xml. 2016.03.20 15:12:44 - Data Path: C:\Users\Tom\AppData\Local\AirVPN. 2016.03.20 15:12:44 - App Path: C:\Program Files\AirVPN. 2016.03.20 15:12:44 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.03.20 15:12:44 - Command line arguments (1): path="home". 2016.03.20 15:12:44 - Operating System: Microsoft Windows NT 6.2.9200.0. 2016.03.20 15:12:44 - Updating systems & servers data ...I 2016.03.20 15:12:44 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1I 2016.03.20 15:12:44 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)I 2016.03.20 15:12:44 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.03.20 15:12:44 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)! 2016.03.20 15:12:44 - Ready. 2016.03.20 15:12:45 - Systems & servers data update completedI 2016.03.20 15:12:46 - Session starting.I 2016.03.20 15:12:46 - IPv6 disabled.I 2016.03.20 15:12:48 - Checking authorization ...! 2016.03.20 15:12:49 - Connecting to Cynosura (Canada, Vancouver). 2016.03.20 15:12:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.03.20 15:12:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.03.20 15:12:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.03.20 15:12:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.03.20 15:12:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:12:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:12:49 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.03.20 15:12:49 - OpenVPN > UDPv4 link local: [undef]. 2016.03.20 15:12:49 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.21:443. 2016.03.20 15:12:52 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=38836501 f75d868d. 2016.03.20 15:12:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.20 15:12:52 - OpenVPN > Validating certificate key usage. 2016.03.20 15:12:52 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.20 15:12:52 - OpenVPN > VERIFY KU OK. 2016.03.20 15:12:52 - OpenVPN > Validating certificate extended key usage. 2016.03.20 15:12:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.20 15:12:52 - OpenVPN > VERIFY EKU OK. 2016.03.20 15:12:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.20 15:12:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:12:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:12:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:12:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:12:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.20 15:12:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.21:443. 2016.03.20 15:13:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.03.20 15:13:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.13.167 255.255.0.0'. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.03.20 15:13:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.03.20 15:13:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.03.20 15:13:00 - OpenVPN > open_tun, tt->ipv6=0. 2016.03.20 15:13:00 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{29801D3F-3079-4096-A27D-FF4F043EACB9}.tap. 2016.03.20 15:13:00 - OpenVPN > All TAP-Windows adapters on this system are currently in use.. 2016.03.20 15:13:00 - OpenVPN > Exiting due to fatal error! 2016.03.20 15:13:01 - Disconnecting. 2016.03.20 15:13:01 - Connection terminated.I 2016.03.20 15:13:04 - Checking authorization ...! 2016.03.20 15:13:04 - Connecting to Cynosura (Canada, Vancouver). 2016.03.20 15:13:04 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.03.20 15:13:04 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.03.20 15:13:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.03.20 15:13:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.03.20 15:13:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:05 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.03.20 15:13:05 - OpenVPN > UDPv4 link local: [undef]. 2016.03.20 15:13:05 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.21:443. 2016.03.20 15:13:05 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=62166929 1775d9fe. 2016.03.20 15:13:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.20 15:13:05 - OpenVPN > Validating certificate key usage. 2016.03.20 15:13:05 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.20 15:13:05 - OpenVPN > VERIFY KU OK. 2016.03.20 15:13:05 - OpenVPN > Validating certificate extended key usage. 2016.03.20 15:13:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.20 15:13:05 - OpenVPN > VERIFY EKU OK. 2016.03.20 15:13:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.20 15:13:11 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:13:11 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:11 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:13:11 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.20 15:13:11 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.21:443. 2016.03.20 15:13:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.03.20 15:13:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.13.167 255.255.0.0'. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.03.20 15:13:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.03.20 15:13:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.03.20 15:13:14 - OpenVPN > open_tun, tt->ipv6=0. 2016.03.20 15:13:14 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{29801D3F-3079-4096-A27D-FF4F043EACB9}.tap. 2016.03.20 15:13:14 - OpenVPN > All TAP-Windows adapters on this system are currently in use.. 2016.03.20 15:13:14 - OpenVPN > Exiting due to fatal error! 2016.03.20 15:13:14 - Disconnecting. 2016.03.20 15:13:14 - Connection terminated.I 2016.03.20 15:13:17 - Checking authorization ...! 2016.03.20 15:13:17 - Connecting to Cynosura (Canada, Vancouver). 2016.03.20 15:13:17 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.03.20 15:13:17 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.03.20 15:13:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.03.20 15:13:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.03.20 15:13:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:18 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.03.20 15:13:18 - OpenVPN > UDPv4 link local: [undef]. 2016.03.20 15:13:18 - OpenVPN > UDPv4 link remote: [AF_INET]71.19.252.21:443. 2016.03.20 15:13:18 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=3ad5e534 53b24e53. 2016.03.20 15:13:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.03.20 15:13:18 - OpenVPN > Validating certificate key usage. 2016.03.20 15:13:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.03.20 15:13:18 - OpenVPN > VERIFY KU OK. 2016.03.20 15:13:18 - OpenVPN > Validating certificate extended key usage. 2016.03.20 15:13:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.03.20 15:13:18 - OpenVPN > VERIFY EKU OK. 2016.03.20 15:13:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.03.20 15:13:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:13:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.03.20 15:13:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.03.20 15:13:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.03.20 15:13:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]71.19.252.21:443 Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... . 2016.03.20 15:13:00 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{29801D3F-3079-4096-A27D-FF4F043EACB9}.tap . 2016.03.20 15:13:00 - OpenVPN > All TAP-Windows adapters on this system are currently in use. Did you try a simple reboot? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
zhang888 1067 Posted ... Alternatively try to disable and re-enable all other TAP adapters you might have on your system.This might have happened if you have many other VPN clients (from other providers) installed, howeverthis issue only occurs on Windows, especially if you try to start the client with a non privileged,for example a Guest or a corporate low-policy user. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
nitehawk 4 Posted ... go into Preferance - Advanced , Uninstall driver. shut down appreboot pcopen app , connect (which in turn installs tap driver again)should connect this timeif the issue happens again just keep uninstalling TAP driver. thats the most simple fix for me Quote Share this post Link to post
