T1rnanog
connection to server doesn't work name could not be changed
Yesterday it was working today its not, i have changed nothing.
Could someone point me in the right direction.
btw 'uncheckking the box check if the tunnel effictefly works" didnt work,
I 2016.03.15 08:33:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.03.15 08:33:05 - Flushing DNS
I 2016.03.15 08:33:05 - Checking route
W 2016.03.15 08:33:29 - De externe naam kan niet worden omgezet: 'atik_exit.airservers.org'
! 2016.03.15 08:33:29 - Disconnecting
. 2016.03.15 08:33:29 - Management - Send 'signal SIGTERM'
. 2016.03.15 08:33:29 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I think I have the same issue, everything was fine yesterday and today it stops at the DNS part.
. 2016.03.15 08:24:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.03.15 08:24:02 - Starting Management Interface
. 2016.03.15 08:24:02 - OpenVPN > Initialization Sequence Completed
I 2016.03.15 08:24:02 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.03.15 08:24:02 - DNS of a network adapter forced (TP-LINK Wireless USB Adapter)
I 2016.03.15 08:24:02 - Flushing DNS
I 2016.03.15 08:24:02 - Checking DNS
W 2016.03.15 08:25:14 - The operation has timed out
! 2016.03.15 08:25:14 - Disconnecting
I tried the common things:
-Disabled DNS things in the option,
-used opendns, google dns etc.
- went back to "get DNS automatically"
- "check if the tunnel works,
- dns switch mode to active and disabled
(if I disable this, I can connect to AIRVPN but cannot reach any website)
pretty confused right now
You could try looking at this thread
Thanks, switching to TCP actually worked.
Not a perfect solution but everything is still fast enough to worry about other things for now
Good, I thought it might be the TAP driver; all that stuff gets (re)directed to our TAP expert now
