zhang888
Private Tracker users (SceneAccess) got deanonimized using BBcode injection
Hello, you might have heard about a recent "vulnerability" that is making some headlines,
specifically the one that allowed a private tracker user to embed an object to a 3d party location,
where he set up a sniffer with logs on his own server.
The full story is available on TorrentFreak:
https://torrentfreak.com/private-tracker-member-data-leaked-via-bbcode-exploit-160313/
Now, if you ask yourself why did Air implement the external resource redirect warning - this was
done in order to mitigate such issues, as well as many more. Another great addition by Air is the
image proxy - so now if you load an Avatar or a signature, or try to embed anything using BBcode,
that URL will be pre-processed and in case an image will be found, an external script will pick up
this image from the remote server without exposing your real IP.
So AirVPN community was never vulnerable to such attack classes in the first place
This is another good example why it is mandatory to use VPNs when you access torrent trackers or
any other content on the internet where a 3d party may log or analyze your activities.
