Yes this is possible with --lport directive.
However this is not very recommended, from many perspectives, and you will not gain any extra security
from this setting.
You should look into hardening your security on the network layer, not the transport layer.
So you will have a better solution dropping all connections to any destination except your entry IP.
Specifying a local port is not advisable for privacy reasons as well. If your ISP provides an IP address
behind NAT, they share the same IP address among many subsribers without virtually knowning who is
who. By using specific patterns and hard coded ports you are losing this little benefit.
