PsychoWolf 16 Posted ... Hi, I use a single port forward on my router (Netgear Nighthawk R7000 with Tomato installed). I've got the firewall configured appropriately, but port forwarding reports timed out from the web interface when I test the port if I am connected to a US server. If I connect to a server in Canada, port forwarding seems to work just fine. To test if my configuration was the problem, I put a virtual machine in the DMZ and installed your Windows client. It too, when connected to a US server, would not allow port forwarding to work. Not sure what's happening, but it doesn't seem like it's a user configuration error. Quote Share this post Link to post
wunderbar 26 Posted ... I've got the firewall configured appropriatelyit doesn't seem like it's a user configuration error You will have to prove/document these statements. It is most likely that you are wrong. Quote Share this post Link to post
PsychoWolf 16 Posted ... iptables -I FORWARD -i tun11 -p udp -d 192.168.1.120 --dport 29411 -j ACCEPT iptables -I FORWARD -i tun11 -p tcp -d 192.168.1.120 --dport 29411 -j ACCEPT iptables -t nat -I PREROUTING -i tun11 -p tcp --dport 29411 -j DNAT --to-destination 192.168.1.120 iptables -t nat -I PREROUTING -i tun11 -p udp --dport 29411 -j DNAT --to-destination 192.168.1.120 That's what I've added to IPTABLES. When connected to servers outside the US, port forwarding works. When connected to servers inside the US, it doesn't. If it was a config error on my end, I'd suspect that it would never work, regardless of which server I connect to. Deluge status when connected to US: Deluge status when connected to CA server: Air status when conencted to US Server:Air Status when connected to CA server: Proof enough for you? 1 a7b4f5b3 reacted to this Quote Share this post Link to post
Tech Jedi Alex 1586 Posted ... Delete the current and add a new random port. We had port forwarding issues in the past solved by a new port. 1 PsychoWolf reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
PsychoWolf 16 Posted ... Delete the current and add a new random port. We had port forwarding issues in the past solved by a new port.Tried that last night too. I'm on mobile now but I'll try again when I'm back near my router. Quote Share this post Link to post
PsychoWolf 16 Posted ... Just tried doing that three times in a row, and the first two didn't work but the third did. Thanks for the suggestion. Quote Share this post Link to post
flat4 98 Posted ... I am connected to Pavonis via pfsense and Internet is working great however for the last 2 day I have not been able to port forward anything. I have deleted and created different ports to no avail. I have also check the client to make sure a firewall wasn't on. As a last resort I put a port forward from clear net to the client on the VPN lan and this worked. However port forwarding via air is not. I have read almost all of the pfsense post on port forwarding and I cannot get it to work. I came across this post. I have not tried a Canadian server as i want to stay in the US Sent from my SAMSUNG-SM-N920A using Tapatalk Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
flat4 98 Posted ... Still having issues port forward 29253 to local 8080, pfsense NAT on VPN_WAN port forward 8080 still cannot connect nor does airvpn port forward page can establish a connection. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
PsychoWolf 16 Posted ... I can't help you with that one. I've never used pfsense. If you reconnect to a Canadian server does it start working? If so, removing the port and adding a new, different, port seemed to work for me. If not, you may be better off creating a new thread as your question wouldn't be really related to mine anymore. Quote Share this post Link to post
flat4 98 Posted ... I really dont want to try the Canadian servers as my speed takes a big hit. I've started a new thread, but it comes to that might have to try it. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
PsychoWolf 16 Posted ... I really dont want to try the Canadian servers as my speed takes a big hit. I've started a new thread, but it comes to that might have to try it. All I meant was that if it works there and doesn't on US servers, it eliminates your configuration as the issue. Just a quick was to test it. Best of luck. Quote Share this post Link to post
flat4 98 Posted ... You're probably correct I will try Sent from my SAMSUNG-SM-N920A using Tapatalk Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
