xxgxx
New user needs help with speed
Hi
I'm new to airvpn - had previously used VPNs but had read good reports
I get just over 100mps when not logged into AirVPN
but get about 16mps when logged in when connecting to recommended
I am in the UK and am not very technical
so please simple explanations
Thanks in advance
G
Hi
Thanks in advance
G
UK here too. I've never needed to actually compare Air/Non Air speeds because its always been quick but I do use a speed monitor so from my 16Mbs I can get more than that when connected to most NL servers which I mostly use. The new UK Bellatrix server seems pretty quick for me too so I use that or Carinae but that gets used a lot these days.
Another Edit: Try going into Preferences -> Advanced -> General and changing both  the TCP/UDP settings to 256 (or 512 later), then clos the client and restart
like MeAndroid said, changing the bit might be useful, also try different protocols and ports your router or ISP might be blocking some of them, also I personally recommend the server Naos I get pretty decent speeds considering and the NAT also is good for gaming
