strykenKN
Problem with Google / Youtube
So once again,
since today I have the problem when I go on the net and AirVPN e.g. Holland / Sweden / Kanda choose appears that I am from Germany and youtube locked out of me, because of GEMA lock.
IPV6 is disabled in Ubuntu 15:10
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
However, the client complains AirVPN rum that IPv6 is enabled (which is not true)
I ask you once the log in, maybe you find a mistake that I have overlooked.
I 2016.02.21 00:04:16 - AirVPN client version: 2.10.3 / x64, System: Linux, Name: Ubuntu 15.10 \n \l / x64
. 2016.02.21 00:04:16 - Reading options from /home/gerhard/.airvpn/AirVPN.xml
. 2016.02.21 00:04:17 - Data Path: /home/gerhard/.airvpn
. 2016.02.21 00:04:17 - App Path: /usr/lib/AirVPN
. 2016.02.21 00:04:17 - Executable Path: /usr/lib/AirVPN/AirVPN.exe
. 2016.02.21 00:04:17 - Command line arguments (1): path="/home/gerhard/.airvpn"
. 2016.02.21 00:04:17 - Updating systems & servers data ...
. 2016.02.21 00:04:17 - Operating System: Unix 4.4.2.40402 - Linux gerhard-desktop 4.4.2-040402-generic #201602171633 SMP Wed Feb 17 21:35:10 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I 2016.02.21 00:04:17 - OpenVPN Driver - Found, /dev/net/tun
I 2016.02.21 00:04:17 - OpenVPN - Version: OpenVPN 2.3.7 (/usr/sbin/openvpn)
I 2016.02.21 00:04:17 - SSH - Version: OpenSSH_6.9p1 Ubuntu-2ubuntu0.1, OpenSSL 1.0.2d 9 Jul 2015 (/usr/bin/ssh)
I 2016.02.21 00:04:17 - SSL - Version: stunnel 5.18 (/usr/bin/stunnel4)
! 2016.02.21 00:04:17 - Activation of Network Lock - Linux IPTables
. 2016.02.21 00:04:18 - Systems & servers data update completed
! 2016.02.21 00:04:21 - Ready
I 2016.02.21 00:04:35 - Session starting.
W 2016.02.21 00:04:35 - Unable to understand if IPV6 is active.
I 2016.02.21 00:04:35 - Checking authorization ...
! 2016.02.21 00:04:35 - Connecting to Diphda (Netherlands, Alblasserdam)
. 2016.02.21 00:04:35 - OpenVPN > OpenVPN 2.3.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Jul  8 2015
. 2016.02.21 00:04:35 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.21 00:04:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.21 00:04:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.21 00:04:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.21 00:04:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.21 00:04:35 - OpenVPN > Socket Buffers: R=[87380->262144] S=[16384->262144]
. 2016.02.21 00:04:35 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.161.164:443 [nonblock]
. 2016.02.21 00:04:36 - OpenVPN > TCP connection established with [AF_INET]213.152.161.164:443
. 2016.02.21 00:04:36 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.02.21 00:04:36 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]213.152.161.164:443
. 2016.02.21 00:04:36 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=618b13fd 1fb4dd16
. 2016.02.21 00:04:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.21 00:04:37 - OpenVPN > Validating certificate key usage
. 2016.02.21 00:04:37 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.21 00:04:37 - OpenVPN > VERIFY KU OK
. 2016.02.21 00:04:37 - OpenVPN > Validating certificate extended key usage
. 2016.02.21 00:04:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.21 00:04:37 - OpenVPN > VERIFY EKU OK
. 2016.02.21 00:04:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.21 00:04:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.21 00:04:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.21 00:04:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.21 00:04:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.21 00:04:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.21 00:04:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443
. 2016.02.21 00:04:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.21 00:04:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.3.235 255.255.0.0'
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.21 00:04:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.21 00:04:40 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=enp2s0 HWADDR=dc:9c:52:17:13:ff
. 2016.02.21 00:04:40 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.21 00:04:40 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.21 00:04:40 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.21 00:04:40 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2016.02.21 00:04:40 - OpenVPN > /sbin/ip addr add dev tun0 10.5.3.235/16 broadcast 10.5.255.255
. 2016.02.21 00:04:45 - OpenVPN > /sbin/ip route add 213.152.161.164/32 via 192.168.0.1
. 2016.02.21 00:04:45 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.5.0.1
. 2016.02.21 00:04:45 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.5.0.1
. 2016.02.21 00:04:45 - Starting Management Interface
. 2016.02.21 00:04:45 - OpenVPN > Initialization Sequence Completed
I 2016.02.21 00:04:45 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2016.02.21 00:04:45 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2016.02.21 00:04:45 - Flushing DNS
I 2016.02.21 00:04:45 - Checking route
I 2016.02.21 00:04:46 - Checking DNS
! 2016.02.21 00:04:46 - Connected.
. 2016.02.21 00:04:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.02.21 00:04:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.02.21 00:34:22 - Updating systems & servers data ...
. 2016.02.21 00:34:23 - Systems & servers data update completed
