strykenKN
possible Restarts loop on Ubuntu 15:10 and no connection!
use Deepin 15.1 (Ubuntu 15.10 have the portable version because not install Eddy Ubuntu 15:10..
Now nothing works.
Every time I start AirVPN, he is in a restart loop and can not connect and then AirVPN like to depend on.
Slowly I'm fed up with the client.
Here that log:
 2016.02.11 19:37:00 - AirVPN client version: 2.10.3 / x64, System: Linux, Name: Deepin GNU/Linux 2015 \n \l / x64
. 2016.02.11 19:37:00 - Reading options from /home/gerhard/Dokumente/airvpn_linux_x64_portable/AirVPN.xml
. 2016.02.11 19:37:01 - Data Path: /home/gerhard/Dokumente/airvpn_linux_x64_portable
. 2016.02.11 19:37:01 - App Path: /home/gerhard/Dokumente/airvpn_linux_x64_portable
. 2016.02.11 19:37:01 - Executable Path: /home/gerhard/Dokumente/airvpn_linux_x64_portable/airvpn
. 2016.02.11 19:37:01 - Command line arguments (0):
. 2016.02.11 19:37:01 - Updating systems & servers data ...
. 2016.02.11 19:37:01 - Operating System: Unix 4.2.0.1 - Linux gerhard-pc 4.2.0-1-amd64 #1 SMP Debian 4.2.6-3 (2015-12-06) x86_64 GNU/Linux
I 2016.02.11 19:37:01 - OpenVPN Driver - Found, /dev/net/tun
I 2016.02.11 19:37:01 - OpenVPN - Version: OpenVPN 2.3.8 (/home/gerhard/Dokumente/airvpn_linux_x64_portable/openvpn)
I 2016.02.11 19:37:01 - SSH - Version: OpenSSH_7.1p2 Debian-2, OpenSSL 1.0.2e 3 Dec 2015 (/usr/bin/ssh)
I 2016.02.11 19:37:01 - SSL - Version: stunnel 5.06 (/home/gerhard/Dokumente/airvpn_linux_x64_portable/stunnel)
! 2016.02.11 19:37:01 - Ready
. 2016.02.11 19:37:02 - Systems & servers data update completed
! 2016.02.11 19:37:07 - Activation of Network Lock - Linux IPTables
I 2016.02.11 19:37:19 - Session starting.
W 2016.02.11 19:37:20 - Unable to understand if IPV6 is active.
I 2016.02.11 19:37:20 - Checking authorization ...
! 2016.02.11 19:37:20 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:37:20 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:37:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:37:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:37:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:37:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:20 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:37:20 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:37:20 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:20 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=3d73f968 06cfdc02
. 2016.02.11 19:37:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:37:20 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:37:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:37:20 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:37:20 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:37:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:37:20 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:37:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:37:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:37:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:26 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:37:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:37:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:37:26 - OpenVPN > TUN/TAP device tun0 opened
! 2016.02.11 19:37:26 - Disconnecting
. 2016.02.11 19:37:26 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:37:26 - Connection terminated.
. 2016.02.11 19:37:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:37:26 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:37:26 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:37:26 - OpenVPN > Exiting due to fatal error
I 2016.02.11 19:37:29 - Checking authorization ...
! 2016.02.11 19:37:29 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:37:29 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:37:29 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:37:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:37:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:37:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:29 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:37:29 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:37:29 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:29 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=efc7a24a 1ff7c6d4
. 2016.02.11 19:37:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:37:29 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:37:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:37:29 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:37:29 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:37:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:37:29 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:37:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:37:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:37:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:35 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:37:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:37:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:37:35 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.11 19:37:35 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:37:35 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:37:35 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:37:35 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:37:35 - OpenVPN > Exiting due to fatal error
! 2016.02.11 19:37:35 - Disconnecting
. 2016.02.11 19:37:35 - Connection terminated.
I 2016.02.11 19:37:38 - Checking authorization ...
! 2016.02.11 19:37:38 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:37:38 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:37:38 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:37:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:37:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:37:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:38 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:37:38 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:37:38 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:38 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=1d953206 571051c0
. 2016.02.11 19:37:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:37:38 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:37:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:37:38 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:37:38 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:37:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:37:38 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:37:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:37:41 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:41 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:41 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:41 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:41 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:37:41 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:44 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:37:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:37:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:37:44 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.11 19:37:44 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:37:44 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:37:44 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:37:44 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:37:44 - OpenVPN > Exiting due to fatal error
! 2016.02.11 19:37:44 - Disconnecting
. 2016.02.11 19:37:44 - Connection terminated.
I 2016.02.11 19:37:47 - Checking authorization ...
! 2016.02.11 19:37:47 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:37:47 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:37:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:37:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:37:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:37:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:47 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:37:47 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:37:47 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:47 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=9fbb5fac 838629b6
. 2016.02.11 19:37:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:37:47 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:37:47 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:37:47 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:37:47 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:37:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:37:47 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:37:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:37:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:37:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:37:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:37:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:37:53 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.11 19:37:53 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:37:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:37:53 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:37:53 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:37:53 - OpenVPN > Exiting due to fatal error
! 2016.02.11 19:37:53 - Disconnecting
. 2016.02.11 19:37:53 - Connection terminated.
I 2016.02.11 19:37:56 - Checking authorization ...
! 2016.02.11 19:37:56 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:37:56 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:37:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:37:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:37:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:37:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:56 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:37:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:37:56 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:37:56 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=c92a2231 fcafd2f3
. 2016.02.11 19:37:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:37:57 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:37:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:37:57 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:37:57 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:37:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:37:57 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:37:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:37:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:37:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:37:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:37:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:38:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:38:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:38:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:38:01 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.11 19:38:01 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:38:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:38:01 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:38:01 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:38:01 - OpenVPN > Exiting due to fatal error
! 2016.02.11 19:38:01 - Disconnecting
. 2016.02.11 19:38:01 - Connection terminated.
I 2016.02.11 19:38:05 - Checking authorization ...
! 2016.02.11 19:38:05 - Connecting to Rukbat (Netherlands, Alblasserdam)
. 2016.02.11 19:38:05 - OpenVPN > OpenVPN 2.3.8 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 13 2015
. 2016.02.11 19:38:05 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.02.11 19:38:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.02.11 19:38:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.02.11 19:38:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:38:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:38:05 - OpenVPN > Socket Buffers: R=[212992->262144] S=[212992->262144]
. 2016.02.11 19:38:05 - OpenVPN > UDPv4 link local: [undef]
. 2016.02.11 19:38:05 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.83:443
. 2016.02.11 19:38:05 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.83:443, sid=e8f751ef 0d261a41
. 2016.02.11 19:38:05 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.02.11 19:38:05 - OpenVPN > Validating certificate key usage
. 2016.02.11 19:38:05 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.02.11 19:38:05 - OpenVPN > VERIFY KU OK
. 2016.02.11 19:38:05 - OpenVPN > Validating certificate extended key usage
. 2016.02.11 19:38:05 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.02.11 19:38:05 - OpenVPN > VERIFY EKU OK
. 2016.02.11 19:38:05 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.02.11 19:38:07 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:38:07 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:38:07 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.02.11 19:38:07 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.02.11 19:38:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.02.11 19:38:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.83:443
. 2016.02.11 19:38:09 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.02.11 19:38:09 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.52.8 255.255.0.0'
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.02.11 19:38:09 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.02.11 19:38:09 - OpenVPN > TUN/TAP device tun0 opened
. 2016.02.11 19:38:09 - OpenVPN > TUN/TAP TX queue length set to 100
. 2016.02.11 19:38:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.02.11 19:38:09 - OpenVPN > /sbin/ifconfig tun0 10.4.52.8 netmask 255.255.0.0 mtu 1500 broadcast 10.4.255.255
. 2016.02.11 19:38:09 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2016.02.11 19:38:09 - OpenVPN > Exiting due to fatal error
! 2016.02.11 19:38:09 - Disconnecting
. 2016.02.11 19:38:09 - Connection terminated.
I 2016.02.11 19:38:09 - Cancel requested.
! 2016.02.11 19:38:09 - Session terminated.
! 2016.02.11 19:38:11 - Deactivation of Network Lock
Here the exact error introduced by Eddy, it seems to be what the OpenVPN.
linux ifconfig failed> could notz execute external program
OpenVPN> Exiting due to fatal error
This repeating line is the problem, indicating some error executing ifconfig. In these forums the only thread talking about this is VPN problems under Archlinux and indicates that a package called net-tools was missing. You should check whether net-tools is present, otherwise, wait for answers of other people.
Hello net-tools is with me already installed the version 1.60 of Ubuntu
the problem is not only that net-tool. But that I can build no connection. Eddy is permanently in a loop and makes permanent restarts.
Net-tool I loudly Archlinux uninstalled, but brings no improvement, but the error remains.
That's why I've provided here the log.
At some where is a mistake. Under Ubuntu, Fedora it worked, but at Deepin Linux 15.1 makes imense error. Although it is based on Ubuntu 10.15.
so I have found the error. Deepin Linux denied me the installation of NET-3 networking toolkit as it is no longer available. Will I install them manually, I have no chance because unavailable.
