helmax
DansGuardian proxy
hi
in my work network have proxy
and i cant do nothing
i can install airvpn but how i can by pass DansGuardian
i never can login airvpn with application for windows give login time out
any help ?
Did you tried changing your protocol to SSL Tunnel 443 in Preferences- Protocols ?
You will need to use OpenVPN (not the AirVPN client Eddie) through an SSL tunnel. Download the configs and stunnel software and connect via that.
I would assume the login servers for AirVPN and normal OpenVPN connections are being blocked.
