zenryou 0 Posted ... I have a 380Mbps down connection. Actual throughput at best with this VPN is under 4 MB/sec. Tried every possible port in the config and 512 buffer sizes. If each server has a max of 1 Gbps throughput....would not 100 users easily cap that out? I mean I've gotten at the least two tenths of that entire speed in the past on another VPN by myself.... I used to get 200-300 something Mbps connection using another VPN, but they started to suck and that's why I am here. Are ISPs throttling basically everything now? Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... If each server has a max of 1 Gbps throughput....would not 100 users easily cap that out? If all users are active (which happens rarely), maybe. Also, not everyone around here does have 10 MBit/s of bandwidth.. How do you connect? What's your setup? Even some logs can help us understand your situation. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... The default buffer sizes are just the ones mostly used, I had to set my own buffer sizes to get my full speed most of the time. Quote Share this post Link to post
rickjames 106 Posted ... Try different connection types and various ports. UDP / TCP / SSL / SSH. Try them all at what ever port options are available. Quote Share this post Link to post
