stevehendo34
Eddie Lock Problem when hooked through router
If I start Eddie with Ubuntu PC hooked directly to cable modem and connect to airVPN all is fine I comes up locked.
If I start when going through my Linksys DD-WRT router it maxs out all 4 cores and network traffic peaks.
The PC is set to Automatic IPV4 I also tried manual.
Dose anyone know what I might have to do to router settings in router?
Should the router make any difference at all?
My IPTables are as follows when Eddie comes up in locked mode.
$ sudo iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -s 255.255.255.255/32 -j ACCEPT
-A INPUT -s 192.168.0.0/16 -d 192.168.0.0/16 -j ACCEPT
-A INPUT -s 10.0.0.0/8 -d 10.0.0.0/8 -j ACCEPT
-A INPUT -s 172.16.0.0/12 -d 172.16.0.0/12 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 8 -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i tun+ -j ACCEPT
-A INPUT -j DROP
-A FORWARD -i tun+ -j ACCEPT
-A FORWARD -j DROP
-A OUTPUT -d 104.243.24.237/32 -j ACCEPT
-A OUTPUT -d 104.243.24.235/32 -j ACCEPT
-A OUTPUT -d 23.105.129.220/32 -j ACCEPT
-A OUTPUT -d 23.105.129.218/32 -j ACCEPT
-A OUTPUT -d 173.44.55.180/32 -j ACCEPT
-A OUTPUT -d 173.44.55.178/32 -j ACCEPT
-A OUTPUT -d 96.47.229.60/32 -j ACCEPT
-A OUTPUT -d 96.47.229.58/32 -j ACCEPT
-A OUTPUT -d 173.44.55.156/32 -j ACCEPT
-A OUTPUT -d 173.44.55.154/32 -j ACCEPT
-A OUTPUT -d 199.241.147.36/32 -j ACCEPT
-A OUTPUT -d 199.241.147.34/32 -j ACCEPT
-A OUTPUT -d 199.241.146.164/32 -j ACCEPT
-A OUTPUT -d 199.241.146.162/32 -j ACCEPT
-A OUTPUT -d 199.241.146.180/32 -j ACCEPT
-A OUTPUT -d 199.241.146.178/32 -j ACCEPT
-A OUTPUT -d 198.203.28.44/32 -j ACCEPT
-A OUTPUT -d 198.203.28.42/32 -j ACCEPT
-A OUTPUT -d 94.100.23.164/32 -j ACCEPT
-A OUTPUT -d 94.100.23.162/32 -j ACCEPT
-A OUTPUT -d 46.21.151.108/32 -j ACCEPT
-A OUTPUT -d 46.21.151.106/32 -j ACCEPT
-A OUTPUT -d 149.255.33.156/32 -j ACCEPT
-A OUTPUT -d 149.255.33.154/32 -j ACCEPT
-A OUTPUT -d 46.21.154.84/32 -j ACCEPT
-A OUTPUT -d 46.21.154.82/32 -j ACCEPT
-A OUTPUT -d 23.82.53.92/32 -j ACCEPT
-A OUTPUT -d 23.82.53.90/32 -j ACCEPT
-A OUTPUT -d 103.254.153.100/32 -j ACCEPT
-A OUTPUT -d 103.254.153.68/32 -j ACCEPT
-A OUTPUT -d 62.102.148.176/32 -j ACCEPT
-A OUTPUT -d 62.102.148.136/32 -j ACCEPT
-A OUTPUT -d 62.102.148.170/32 -j ACCEPT
-A OUTPUT -d 62.102.148.139/32 -j ACCEPT
-A OUTPUT -d 62.102.148.178/32 -j ACCEPT
-A OUTPUT -d 62.102.148.135/32 -j ACCEPT
-A OUTPUT -d 62.102.148.180/32 -j ACCEPT
-A OUTPUT -d 62.102.148.134/32 -j ACCEPT
-A OUTPUT -d 62.102.148.182/32 -j ACCEPT
-A OUTPUT -d 62.102.148.133/32 -j ACCEPT
-A OUTPUT -d 62.102.148.184/32 -j ACCEPT
-A OUTPUT -d 62.102.148.132/32 -j ACCEPT
-A OUTPUT -d 62.102.148.174/32 -j ACCEPT
-A OUTPUT -d 62.102.148.137/32 -j ACCEPT
-A OUTPUT -d 62.102.148.188/32 -j ACCEPT
-A OUTPUT -d 62.102.148.130/32 -j ACCEPT
-A OUTPUT -d 62.102.148.186/32 -j ACCEPT
-A OUTPUT -d 62.102.148.131/32 -j ACCEPT
-A OUTPUT -d 185.57.80.148/32 -j ACCEPT
-A OUTPUT -d 185.57.80.146/32 -j ACCEPT
-A OUTPUT -d 109.163.226.155/32 -j ACCEPT
-A OUTPUT -d 109.163.230.232/32 -j ACCEPT
-A OUTPUT -d 91.109.116.66/32 -j ACCEPT
-A OUTPUT -d 91.109.114.3/32 -j ACCEPT
-A OUTPUT -d 213.163.74.41/32 -j ACCEPT
-A OUTPUT -d 213.163.74.22/32 -j ACCEPT
-A OUTPUT -d 213.152.161.150/32 -j ACCEPT
-A OUTPUT -d 213.152.161.148/32 -j ACCEPT
-A OUTPUT -d 213.152.161.134/32 -j ACCEPT
-A OUTPUT -d 213.152.161.132/32 -j ACCEPT
-A OUTPUT -d 213.152.161.139/32 -j ACCEPT
-A OUTPUT -d 213.152.161.137/32 -j ACCEPT
-A OUTPUT -d 213.152.162.100/32 -j ACCEPT
-A OUTPUT -d 213.152.162.98/32 -j ACCEPT
-A OUTPUT -d 213.152.161.75/32 -j ACCEPT
-A OUTPUT -d 213.152.161.73/32 -j ACCEPT
-A OUTPUT -d 213.152.161.16/32 -j ACCEPT
-A OUTPUT -d 213.152.161.14/32 -j ACCEPT
-A OUTPUT -d 213.152.162.115/32 -j ACCEPT
-A OUTPUT -d 213.152.162.113/32 -j ACCEPT
-A OUTPUT -d 213.152.161.21/32 -j ACCEPT
-A OUTPUT -d 213.152.161.19/32 -j ACCEPT
-A OUTPUT -d 213.152.162.85/32 -j ACCEPT
-A OUTPUT -d 213.152.162.83/32 -j ACCEPT
-A OUTPUT -d 213.152.162.150/32 -j ACCEPT
-A OUTPUT -d 213.152.162.148/32 -j ACCEPT
-A OUTPUT -d 109.232.227.150/32 -j ACCEPT
-A OUTPUT -d 109.232.227.148/32 -j ACCEPT
-A OUTPUT -d 213.152.161.26/32 -j ACCEPT
-A OUTPUT -d 213.152.161.24/32 -j ACCEPT
-A OUTPUT -d 213.152.162.155/32 -j ACCEPT
-A OUTPUT -d 213.152.162.153/32 -j ACCEPT
-A OUTPUT -d 213.152.162.90/32 -j ACCEPT
-A OUTPUT -d 213.152.162.88/32 -j ACCEPT
-A OUTPUT -d 213.152.162.70/32 -j ACCEPT
-A OUTPUT -d 213.152.162.68/32 -j ACCEPT
-A OUTPUT -d 213.152.161.31/32 -j ACCEPT
-A OUTPUT -d 213.152.161.29/32 -j ACCEPT
-A OUTPUT -d 109.232.227.139/32 -j ACCEPT
-A OUTPUT -d 109.232.227.137/32 -j ACCEPT
-A OUTPUT -d 213.152.162.105/32 -j ACCEPT
-A OUTPUT -d 213.152.162.103/32 -j ACCEPT
-A OUTPUT -d 213.152.162.182/32 -j ACCEPT
-A OUTPUT -d 213.152.162.180/32 -j ACCEPT
-A OUTPUT -d 213.152.161.86/32 -j ACCEPT
-A OUTPUT -d 213.152.161.84/32 -j ACCEPT
-A OUTPUT -d 213.152.162.110/32 -j ACCEPT
-A OUTPUT -d 213.152.162.108/32 -j ACCEPT
-A OUTPUT -d 213.152.161.36/32 -j ACCEPT
-A OUTPUT -d 213.152.161.34/32 -j ACCEPT
-A OUTPUT -d 213.152.161.41/32 -j ACCEPT
-A OUTPUT -d 213.152.161.39/32 -j ACCEPT
-A OUTPUT -d 213.152.162.95/32 -j ACCEPT
-A OUTPUT -d 213.152.162.93/32 -j ACCEPT
-A OUTPUT -d 213.152.161.102/32 -j ACCEPT
-A OUTPUT -d 213.152.161.100/32 -j ACCEPT
-A OUTPUT -d 213.152.162.75/32 -j ACCEPT
-A OUTPUT -d 213.152.162.73/32 -j ACCEPT
-A OUTPUT -d 213.152.161.46/32 -j ACCEPT
-A OUTPUT -d 213.152.161.44/32 -j ACCEPT
-A OUTPUT -d 213.152.161.166/32 -j ACCEPT
-A OUTPUT -d 213.152.161.164/32 -j ACCEPT
-A OUTPUT -d 109.232.227.134/32 -j ACCEPT
-A OUTPUT -d 109.232.227.132/32 -j ACCEPT
-A OUTPUT -d 213.152.161.70/32 -j ACCEPT
-A OUTPUT -d 213.152.161.68/32 -j ACCEPT
-A OUTPUT -d 213.152.162.171/32 -j ACCEPT
-A OUTPUT -d 213.152.162.169/32 -j ACCEPT
-A OUTPUT -d 213.152.161.11/32 -j ACCEPT
-A OUTPUT -d 213.152.161.9/32 -j ACCEPT
-A OUTPUT -d 109.202.103.171/32 -j ACCEPT
-A OUTPUT -d 109.202.103.169/32 -j ACCEPT
-A OUTPUT -d 213.152.162.166/32 -j ACCEPT
-A OUTPUT -d 213.152.162.164/32 -j ACCEPT
-A OUTPUT -d 213.152.161.171/32 -j ACCEPT
-A OUTPUT -d 213.152.161.169/32 -j ACCEPT
-A OUTPUT -d 213.152.161.6/32 -j ACCEPT
-A OUTPUT -d 213.152.161.4/32 -j ACCEPT
-A OUTPUT -d 213.152.162.80/32 -j ACCEPT
-A OUTPUT -d 213.152.162.78/32 -j ACCEPT
-A OUTPUT -d 213.152.161.118/32 -j ACCEPT
-A OUTPUT -d 213.152.161.116/32 -j ACCEPT
-A OUTPUT -d 213.152.161.182/32 -j ACCEPT
-A OUTPUT -d 213.152.161.180/32 -j ACCEPT
-A OUTPUT -d 159.148.186.33/32 -j ACCEPT
-A OUTPUT -d 159.148.186.31/32 -j ACCEPT
-A OUTPUT -d 159.148.186.26/32 -j ACCEPT
-A OUTPUT -d 159.148.186.24/32 -j ACCEPT
-A OUTPUT -d 159.148.186.19/32 -j ACCEPT
-A OUTPUT -d 159.148.186.17/32 -j ACCEPT
-A OUTPUT -d 159.148.186.12/32 -j ACCEPT
-A OUTPUT -d 159.148.186.10/32 -j ACCEPT
-A OUTPUT -d 46.166.165.240/32 -j ACCEPT
-A OUTPUT -d 46.166.165.124/32 -j ACCEPT
-A OUTPUT -d 103.10.197.188/32 -j ACCEPT
-A OUTPUT -d 103.10.197.186/32 -j ACCEPT
-A OUTPUT -d 103.16.27.27/32 -j ACCEPT
-A OUTPUT -d 103.16.27.25/32 -j ACCEPT
-A OUTPUT -d 78.129.153.59/32 -j ACCEPT
-A OUTPUT -d 78.129.153.40/32 -j ACCEPT
-A OUTPUT -d 84.39.116.181/32 -j ACCEPT
-A OUTPUT -d 84.39.116.179/32 -j ACCEPT
-A OUTPUT -d 84.39.117.58/32 -j ACCEPT
-A OUTPUT -d 84.39.117.56/32 -j ACCEPT
-A OUTPUT -d 82.145.37.204/32 -j ACCEPT
-A OUTPUT -d 82.145.37.202/32 -j ACCEPT
-A OUTPUT -d 94.229.74.92/32 -j ACCEPT
-A OUTPUT -d 94.229.74.90/32 -j ACCEPT
-A OUTPUT -d 88.150.241.17/32 -j ACCEPT
-A OUTPUT -d 88.150.240.7/32 -j ACCEPT
-A OUTPUT -d 80.84.49.20/32 -j ACCEPT
-A OUTPUT -d 80.84.49.4/32 -j ACCEPT
-A OUTPUT -d 46.29.125.15/32 -j ACCEPT
-A OUTPUT -d 46.29.125.13/32 -j ACCEPT
-A OUTPUT -d 212.129.42.171/32 -j ACCEPT
-A OUTPUT -d 195.154.188.113/32 -j ACCEPT
-A OUTPUT -d 195.154.43.198/32 -j ACCEPT
-A OUTPUT -d 195.154.194.18/32 -j ACCEPT
-A OUTPUT -d 95.215.62.93/32 -j ACCEPT
-A OUTPUT -d 95.215.62.91/32 -j ACCEPT
-A OUTPUT -d 46.182.35.49/32 -j ACCEPT
-A OUTPUT -d 46.182.35.14/32 -j ACCEPT
-A OUTPUT -d 178.238.229.55/32 -j ACCEPT
-A OUTPUT -d 79.143.191.166/32 -j ACCEPT
-A OUTPUT -d 178.162.198.112/32 -j ACCEPT
-A OUTPUT -d 178.162.198.102/32 -j ACCEPT
-A OUTPUT -d 46.165.208.110/32 -j ACCEPT
-A OUTPUT -d 46.165.208.69/32 -j ACCEPT
-A OUTPUT -d 46.165.208.106/32 -j ACCEPT
-A OUTPUT -d 46.165.208.65/32 -j ACCEPT
-A OUTPUT -d 178.162.198.110/32 -j ACCEPT
-A OUTPUT -d 178.162.198.103/32 -j ACCEPT
-A OUTPUT -d 178.162.198.46/32 -j ACCEPT
-A OUTPUT -d 178.162.198.40/32 -j ACCEPT
-A OUTPUT -d 46.165.208.109/32 -j ACCEPT
-A OUTPUT -d 46.165.208.70/32 -j ACCEPT
-A OUTPUT -d 91.214.169.70/32 -j ACCEPT
-A OUTPUT -d 91.214.169.68/32 -j ACCEPT
-A OUTPUT -d 46.19.137.115/32 -j ACCEPT
-A OUTPUT -d 46.19.137.114/32 -j ACCEPT
-A OUTPUT -d 71.19.249.197/32 -j ACCEPT
-A OUTPUT -d 71.19.249.195/32 -j ACCEPT
-A OUTPUT -d 184.75.223.204/32 -j ACCEPT
-A OUTPUT -d 184.75.223.202/32 -j ACCEPT
-A OUTPUT -d 137.63.71.52/32 -j ACCEPT
-A OUTPUT -d 137.63.71.50/32 -j ACCEPT
-A OUTPUT -d 199.19.94.195/32 -j ACCEPT
-A OUTPUT -d 199.19.94.19/32 -j ACCEPT
-A OUTPUT -d 104.254.90.196/32 -j ACCEPT
-A OUTPUT -d 104.254.90.194/32 -j ACCEPT
-A OUTPUT -d 184.75.223.196/32 -j ACCEPT
-A OUTPUT -d 184.75.223.194/32 -j ACCEPT
-A OUTPUT -d 184.75.223.228/32 -j ACCEPT
-A OUTPUT -d 184.75.223.226/32 -j ACCEPT
-A OUTPUT -d 104.254.90.188/32 -j ACCEPT
-A OUTPUT -d 104.254.90.186/32 -j ACCEPT
-A OUTPUT -d 199.19.94.137/32 -j ACCEPT
-A OUTPUT -d 199.19.94.132/32 -j ACCEPT
-A OUTPUT -d 184.75.223.220/32 -j ACCEPT
-A OUTPUT -d 184.75.223.218/32 -j ACCEPT
-A OUTPUT -d 184.75.221.4/32 -j ACCEPT
-A OUTPUT -d 184.75.221.2/32 -j ACCEPT
-A OUTPUT -d 199.19.94.65/32 -j ACCEPT
-A OUTPUT -d 199.19.94.61/32 -j ACCEPT
-A OUTPUT -d 199.19.95.189/32 -j ACCEPT
-A OUTPUT -d 199.19.95.187/32 -j ACCEPT
-A OUTPUT -d 104.254.90.252/32 -j ACCEPT
-A OUTPUT -d 104.254.90.250/32 -j ACCEPT
-A OUTPUT -d 104.254.90.244/32 -j ACCEPT
-A OUTPUT -d 104.254.90.242/32 -j ACCEPT
-A OUTPUT -d 199.21.149.70/32 -j ACCEPT
-A OUTPUT -d 199.21.149.44/32 -j ACCEPT
-A OUTPUT -d 104.254.90.236/32 -j ACCEPT
-A OUTPUT -d 104.254.90.234/32 -j ACCEPT
-A OUTPUT -d 184.75.214.164/32 -j ACCEPT
-A OUTPUT -d 184.75.214.162/32 -j ACCEPT
-A OUTPUT -d 184.75.223.236/32 -j ACCEPT
-A OUTPUT -d 184.75.223.234/32 -j ACCEPT
-A OUTPUT -d 104.254.90.204/32 -j ACCEPT
-A OUTPUT -d 104.254.90.202/32 -j ACCEPT
-A OUTPUT -d 199.19.94.18/32 -j ACCEPT
-A OUTPUT -d 199.19.94.12/32 -j ACCEPT
-A OUTPUT -d 162.219.176.4/32 -j ACCEPT
-A OUTPUT -d 162.219.176.2/32 -j ACCEPT
-A OUTPUT -d 184.75.223.212/32 -j ACCEPT
-A OUTPUT -d 184.75.223.210/32 -j ACCEPT
-A OUTPUT -d 95.211.138.143/32 -j ACCEPT
-A OUTPUT -d 54.93.175.114/32 -j ACCEPT
-A OUTPUT -d 54.225.156.17/32 -j ACCEPT
-A OUTPUT -d 54.246.124.152/32 -j ACCEPT
-A OUTPUT -o lo -j ACCEPT
-A OUTPUT -d 255.255.255.255/32 -j ACCEPT
-A OUTPUT -s 192.168.0.0/16 -d 192.168.0.0/16 -j ACCEPT
-A OUTPUT -s 10.0.0.0/8 -d 10.0.0.0/8 -j ACCEPT
-A OUTPUT -s 172.16.0.0/12 -d 172.16.0.0/12 -j ACCEPT
-A OUTPUT -o tun+ -j ACCEPT
-A OUTPUT -j DROP
Good, now please write your solution here for the ones having this problem in the future, too.
(Sent via Tapatalk - this generally means I'm not sitting in front of my PC)
