mrpetersmith
Constantly disconnecting
In the last few months airvpn has started to disonnect a lot. It usually stays connected for 10min before it disonnects.
Can someone take a look at my log and tell me if they see something:
I 2015.12.19 13:06:01 - AirVPN client version: 2.9.2, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Architecture: x64
. 2015.12.19 13:06:01 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2015.12.19 13:06:02 - Data Path: C:\Program Files\AirVPN
. 2015.12.19 13:06:02 - App Path: C:\Program Files\AirVPN
. 2015.12.19 13:06:02 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.12.19 13:06:02 - Command line arguments (0):
. 2015.12.19 13:06:02 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.12.19 13:06:02 - Updating systems & servers data ...
I 2015.12.19 13:06:02 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.12.19 13:06:02 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.12.19 13:06:02 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.12.19 13:06:02 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.12.19 13:06:02 - Ready
. 2015.12.19 13:06:03 - Systems & servers data update completed
I 2015.12.19 13:06:04 - Session starting.
I 2015.12.19 13:06:05 - IPv6 disabled.
I 2015.12.19 13:06:07 - Checking authorization ...
! 2015.12.19 13:06:08 - Connecting to Gorgonea (Canada, Toronto, Ontario)
. 2015.12.19 13:06:08 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.12.19 13:06:08 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.12.19 13:06:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.12.19 13:06:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.12.19 13:06:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:06:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:06:08 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.12.19 13:06:08 - OpenVPN > UDPv4 link local: [undef]
. 2015.12.19 13:06:08 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.250:443
. 2015.12.19 13:06:08 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.250:443, sid=97f9119a f75fa4e9
. 2015.12.19 13:06:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.12.19 13:06:09 - OpenVPN > Validating certificate key usage
. 2015.12.19 13:06:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.12.19 13:06:09 - OpenVPN > VERIFY KU OK
. 2015.12.19 13:06:09 - OpenVPN > Validating certificate extended key usage
. 2015.12.19 13:06:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.12.19 13:06:09 - OpenVPN > VERIFY EKU OK
. 2015.12.19 13:06:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.12.19 13:06:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:06:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:06:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:06:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:06:15 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.12.19 13:06:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.250:443
. 2015.12.19 13:06:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.12.19 13:06:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.5.148 255.255.0.0'
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.12.19 13:06:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.12.19 13:06:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.12.19 13:06:17 - OpenVPN > open_tun, tt->ipv6=0
. 2015.12.19 13:06:17 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{270519E4-9557-44BD-BB15-D00BFA37D4AB}.tap
. 2015.12.19 13:06:17 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.12.19 13:06:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.5.148/255.255.0.0 [sUCCEEDED]
. 2015.12.19 13:06:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.5.148/255.255.0.0 on interface {270519E4-9557-44BD-BB15-D00BFA37D4AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.12.19 13:06:17 - OpenVPN > Successful ARP Flush on interface [12] {270519E4-9557-44BD-BB15-D00BFA37D4AB}
. 2015.12.19 13:06:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.12.19 13:06:22 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.250 MASK 255.255.255.255 192.168.1.254
. 2015.12.19 13:06:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.12.19 13:06:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.12.19 13:06:22 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.12.19 13:06:22 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:06:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.12.19 13:06:22 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:06:22 - Starting Management Interface
. 2015.12.19 13:06:22 - OpenVPN > Initialization Sequence Completed
I 2015.12.19 13:06:22 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:06:22 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.12.19 13:06:22 - Flushing DNS
I 2015.12.19 13:06:22 - Checking route
I 2015.12.19 13:06:25 - Checking DNS
! 2015.12.19 13:06:25 - Connected.
. 2015.12.19 13:06:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.12.19 13:06:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.12.19 13:25:05 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.12.19 13:25:05 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.12.19 13:25:05 - OpenVPN > Restart pause, 2 second(s)
! 2015.12.19 13:25:05 - Disconnecting
. 2015.12.19 13:25:05 - Management - Send 'signal SIGTERM'
. 2015.12.19 13:25:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.12.19 13:25:05 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.12.19 13:25:05 - OpenVPN > Assertion failed at misc.c:788
. 2015.12.19 13:25:05 - OpenVPN > Exiting due to fatal error
. 2015.12.19 13:25:05 - Connection terminated.
I 2015.12.19 13:25:05 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:25:05 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.12.19 13:25:13 - Checking authorization ...
! 2015.12.19 13:25:14 - Connecting to Rotanev (Canada, Toronto, Ontario)
. 2015.12.19 13:25:14 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.12.19 13:25:14 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.12.19 13:25:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.12.19 13:25:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.12.19 13:25:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:25:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:25:14 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.12.19 13:25:14 - OpenVPN > UDPv4 link local: [undef]
. 2015.12.19 13:25:14 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.186:443
. 2015.12.19 13:25:15 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.186:443, sid=f882075a e8bb2637
. 2015.12.19 13:25:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.12.19 13:25:18 - OpenVPN > Validating certificate key usage
. 2015.12.19 13:25:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.12.19 13:25:18 - OpenVPN > VERIFY KU OK
. 2015.12.19 13:25:18 - OpenVPN > Validating certificate extended key usage
. 2015.12.19 13:25:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.12.19 13:25:18 - OpenVPN > VERIFY EKU OK
. 2015.12.19 13:25:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.12.19 13:25:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:25:21 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:25:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:25:21 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:25:21 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.12.19 13:25:21 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.186:443
. 2015.12.19 13:25:23 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.12.19 13:25:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.80 255.255.0.0'
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.12.19 13:25:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.12.19 13:25:24 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.12.19 13:25:24 - OpenVPN > open_tun, tt->ipv6=0
. 2015.12.19 13:25:24 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{270519E4-9557-44BD-BB15-D00BFA37D4AB}.tap
. 2015.12.19 13:25:24 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.12.19 13:25:24 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.80/255.255.0.0 [sUCCEEDED]
. 2015.12.19 13:25:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.80/255.255.0.0 on interface {270519E4-9557-44BD-BB15-D00BFA37D4AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.12.19 13:25:24 - OpenVPN > Successful ARP Flush on interface [12] {270519E4-9557-44BD-BB15-D00BFA37D4AB}
. 2015.12.19 13:25:29 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.12.19 13:25:29 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.186 MASK 255.255.255.255 192.168.1.254
. 2015.12.19 13:25:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.12.19 13:25:29 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.12.19 13:25:29 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.12.19 13:25:29 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.12.19 13:25:29 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.12.19 13:25:29 - OpenVPN > Route addition fallback to route.exe
. 2015.12.19 13:25:29 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.12.19 13:25:29 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:25:29 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2015.12.19 13:25:29 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:25:29 - Starting Management Interface
. 2015.12.19 13:25:29 - OpenVPN > Initialization Sequence Completed
I 2015.12.19 13:25:29 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:25:29 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.12.19 13:25:29 - Flushing DNS
I 2015.12.19 13:25:29 - Checking route
I 2015.12.19 13:25:32 - Checking DNS
! 2015.12.19 13:25:33 - Connected.
. 2015.12.19 13:25:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.12.19 13:25:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.12.19 13:35:14 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.12.19 13:35:14 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.12.19 13:35:14 - OpenVPN > Restart pause, 2 second(s)
! 2015.12.19 13:35:14 - Disconnecting
. 2015.12.19 13:35:14 - Management - Send 'signal SIGTERM'
. 2015.12.19 13:35:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.12.19 13:35:14 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.12.19 13:35:14 - OpenVPN > Assertion failed at misc.c:788
. 2015.12.19 13:35:14 - OpenVPN > Exiting due to fatal error
. 2015.12.19 13:35:14 - Connection terminated.
I 2015.12.19 13:35:14 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:35:14 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.12.19 13:35:17 - Checking authorization ...
! 2015.12.19 13:35:18 - Connecting to Grumium (Canada, Toronto, Ontario)
. 2015.12.19 13:35:18 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.12.19 13:35:18 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.12.19 13:35:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.12.19 13:35:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.12.19 13:35:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:35:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:35:18 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.12.19 13:35:18 - OpenVPN > UDPv4 link local: [undef]
. 2015.12.19 13:35:18 - OpenVPN > UDPv4 link remote: [AF_INET]199.19.95.187:443
. 2015.12.19 13:35:18 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.95.187:443, sid=2c92292b dddc3d6f
. 2015.12.19 13:35:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.12.19 13:35:26 - OpenVPN > Validating certificate key usage
. 2015.12.19 13:35:26 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.12.19 13:35:26 - OpenVPN > VERIFY KU OK
. 2015.12.19 13:35:26 - OpenVPN > Validating certificate extended key usage
. 2015.12.19 13:35:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.12.19 13:35:26 - OpenVPN > VERIFY EKU OK
. 2015.12.19 13:35:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.12.19 13:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:35:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:35:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:35:38 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.12.19 13:35:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.95.187:443
. 2015.12.19 13:35:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.12.19 13:35:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.8.62 255.255.0.0'
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.12.19 13:35:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.12.19 13:35:40 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.12.19 13:35:40 - OpenVPN > open_tun, tt->ipv6=0
. 2015.12.19 13:35:40 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{270519E4-9557-44BD-BB15-D00BFA37D4AB}.tap
. 2015.12.19 13:35:40 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.12.19 13:35:40 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.8.62/255.255.0.0 [sUCCEEDED]
. 2015.12.19 13:35:40 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.8.62/255.255.0.0 on interface {270519E4-9557-44BD-BB15-D00BFA37D4AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.12.19 13:35:40 - OpenVPN > Successful ARP Flush on interface [12] {270519E4-9557-44BD-BB15-D00BFA37D4AB}
. 2015.12.19 13:35:45 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.12.19 13:35:45 - OpenVPN > C:\Windows\system32\route.exe ADD 199.19.95.187 MASK 255.255.255.255 192.168.1.254
. 2015.12.19 13:35:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.12.19 13:35:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.12.19 13:35:45 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.12.19 13:35:45 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.12.19 13:35:45 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.12.19 13:35:45 - OpenVPN > Route addition fallback to route.exe
. 2015.12.19 13:35:45 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.12.19 13:35:45 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:35:45 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2015.12.19 13:35:45 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:35:45 - Starting Management Interface
. 2015.12.19 13:35:45 - OpenVPN > Initialization Sequence Completed
I 2015.12.19 13:35:45 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:35:45 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.12.19 13:35:45 - Flushing DNS
I 2015.12.19 13:35:45 - Checking route
I 2015.12.19 13:35:48 - Checking DNS
! 2015.12.19 13:35:50 - Connected.
. 2015.12.19 13:35:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.12.19 13:35:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.12.19 13:36:17 - Updating systems & servers data ...
. 2015.12.19 13:36:19 - Systems & servers data update completed
. 2015.12.19 13:43:02 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.12.19 13:43:02 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.12.19 13:43:02 - OpenVPN > Restart pause, 2 second(s)
! 2015.12.19 13:43:02 - Disconnecting
. 2015.12.19 13:43:02 - Management - Send 'signal SIGTERM'
. 2015.12.19 13:43:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.12.19 13:43:02 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.12.19 13:43:02 - OpenVPN > Assertion failed at misc.c:788
. 2015.12.19 13:43:02 - OpenVPN > Exiting due to fatal error
. 2015.12.19 13:43:02 - Connection terminated.
I 2015.12.19 13:43:02 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:43:02 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.12.19 13:43:19 - Checking authorization ...
! 2015.12.19 13:43:21 - Connecting to Agena (Canada, Toronto, Ontario)
. 2015.12.19 13:43:21 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.12.19 13:43:21 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.12.19 13:43:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.12.19 13:43:21 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.12.19 13:43:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:43:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:43:21 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.12.19 13:43:21 - OpenVPN > UDPv4 link local: [undef]
. 2015.12.19 13:43:21 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.210:443
. 2015.12.19 13:43:21 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.210:443, sid=b722c717 b1916b11
. 2015.12.19 13:43:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.12.19 13:43:24 - OpenVPN > Validating certificate key usage
. 2015.12.19 13:43:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.12.19 13:43:24 - OpenVPN > VERIFY KU OK
. 2015.12.19 13:43:24 - OpenVPN > Validating certificate extended key usage
. 2015.12.19 13:43:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.12.19 13:43:25 - OpenVPN > VERIFY EKU OK
. 2015.12.19 13:43:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.12.19 13:43:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:43:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:43:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:43:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:43:27 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.12.19 13:43:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.210:443
. 2015.12.19 13:43:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.12.19 13:43:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.8.77 255.255.0.0'
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.12.19 13:43:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.12.19 13:43:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.12.19 13:43:30 - OpenVPN > open_tun, tt->ipv6=0
. 2015.12.19 13:43:30 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{270519E4-9557-44BD-BB15-D00BFA37D4AB}.tap
. 2015.12.19 13:43:30 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.12.19 13:43:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.8.77/255.255.0.0 [sUCCEEDED]
. 2015.12.19 13:43:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.8.77/255.255.0.0 on interface {270519E4-9557-44BD-BB15-D00BFA37D4AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.12.19 13:43:30 - OpenVPN > Successful ARP Flush on interface [12] {270519E4-9557-44BD-BB15-D00BFA37D4AB}
. 2015.12.19 13:43:35 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.12.19 13:43:35 - OpenVPN > C:\Windows\system32\route.exe ADD 184.75.223.210 MASK 255.255.255.255 192.168.1.254
. 2015.12.19 13:43:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.12.19 13:43:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.12.19 13:43:35 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.12.19 13:43:35 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.12.19 13:43:35 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.12.19 13:43:35 - OpenVPN > Route addition fallback to route.exe
. 2015.12.19 13:43:35 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.12.19 13:43:35 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:43:35 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2015.12.19 13:43:35 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:43:35 - Starting Management Interface
. 2015.12.19 13:43:35 - OpenVPN > Initialization Sequence Completed
I 2015.12.19 13:43:35 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:43:35 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.12.19 13:43:35 - Flushing DNS
I 2015.12.19 13:43:35 - Checking route
I 2015.12.19 13:43:38 - Checking DNS
! 2015.12.19 13:43:39 - Connected.
. 2015.12.19 13:43:39 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.12.19 13:43:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.12.19 13:45:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12810 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:00 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12858 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13946 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:03 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #13948 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15478 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15479 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15480 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15481 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:45:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #15482 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.12.19 13:47:52 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.12.19 13:47:52 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.12.19 13:47:52 - OpenVPN > Restart pause, 2 second(s)
! 2015.12.19 13:47:52 - Disconnecting
. 2015.12.19 13:47:52 - Management - Send 'signal SIGTERM'
. 2015.12.19 13:47:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.12.19 13:47:52 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.12.19 13:47:52 - OpenVPN > Assertion failed at misc.c:788
. 2015.12.19 13:47:52 - OpenVPN > Exiting due to fatal error
. 2015.12.19 13:47:52 - Connection terminated.
I 2015.12.19 13:47:52 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:47:52 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.12.19 13:47:55 - Checking authorization ...
! 2015.12.19 13:48:17 - Connecting to Enif (Canada, Toronto, Ontario)
. 2015.12.19 13:48:17 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.12.19 13:48:17 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.12.19 13:48:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.12.19 13:48:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.12.19 13:48:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:48:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:48:17 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.12.19 13:48:17 - OpenVPN > UDPv4 link local: [undef]
. 2015.12.19 13:48:17 - OpenVPN > UDPv4 link remote: [AF_INET]104.254.90.242:443
. 2015.12.19 13:48:17 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.242:443, sid=e9aa1944 616c05a3
. 2015.12.19 13:48:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.12.19 13:48:18 - OpenVPN > Validating certificate key usage
. 2015.12.19 13:48:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.12.19 13:48:18 - OpenVPN > VERIFY KU OK
. 2015.12.19 13:48:18 - OpenVPN > Validating certificate extended key usage
. 2015.12.19 13:48:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.12.19 13:48:18 - OpenVPN > VERIFY EKU OK
. 2015.12.19 13:48:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.12.19 13:48:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:48:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:48:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.12.19 13:48:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.12.19 13:48:26 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.12.19 13:48:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.242:443
. 2015.12.19 13:48:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.12.19 13:48:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.10.88 255.255.0.0'
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.12.19 13:48:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.12.19 13:48:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.12.19 13:48:28 - OpenVPN > open_tun, tt->ipv6=0
. 2015.12.19 13:48:28 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{270519E4-9557-44BD-BB15-D00BFA37D4AB}.tap
. 2015.12.19 13:48:28 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.12.19 13:48:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.10.88/255.255.0.0 [sUCCEEDED]
. 2015.12.19 13:48:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.10.88/255.255.0.0 on interface {270519E4-9557-44BD-BB15-D00BFA37D4AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.12.19 13:48:28 - OpenVPN > Successful ARP Flush on interface [12] {270519E4-9557-44BD-BB15-D00BFA37D4AB}
. 2015.12.19 13:48:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.12.19 13:48:33 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.242 MASK 255.255.255.255 192.168.1.254
. 2015.12.19 13:48:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.12.19 13:48:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.12.19 13:48:33 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.12.19 13:48:33 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.12.19 13:48:33 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.12.19 13:48:33 - OpenVPN > Route addition fallback to route.exe
. 2015.12.19 13:48:33 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.12.19 13:48:33 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:48:33 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2015.12.19 13:48:33 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.12.19 13:48:33 - Starting Management Interface
. 2015.12.19 13:48:33 - OpenVPN > Initialization Sequence Completed
I 2015.12.19 13:48:33 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2015.12.19 13:48:33 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.12.19 13:48:33 - Flushing DNS
I 2015.12.19 13:48:33 - Checking route
I 2015.12.19 13:48:37 - Checking DNS
! 2015.12.19 13:48:37 - Connected.
. 2015.12.19 13:48:37 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.12.19 13:48:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I changed protocols setting from 'automatic' to 'protocol TCP, port 80' and so far have had almost 3 hours without disconnecting once so that could be the answer. Is this an ISP issue?
I had a similar problem while torrenting and the solution was to try each protocol. I use SSH port 53 now and it doesnt disconnect.
