laskipukki
Connection issues
Using win7 home premium. My modem is set to bridged mode.
Tried with suspending firewall & virus protection yet no effect. I use ESET Nod Endpoint and Outpost Firewall.
I 2015.11.25 10:45:51 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2015.11.25 10:45:51 - Reading options from C:\Users\laskipukki\AppData\Local\AirVPN\AirVPN.xml
. 2015.11.25 10:45:51 - Data Path: C:\Users\laskipukki\AppData\Local\AirVPN
. 2015.11.25 10:45:51 - App Path: C:\Program Files\AirVPN
. 2015.11.25 10:45:51 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.11.25 10:45:51 - Command line arguments (1): path="home"
. 2015.11.25 10:45:51 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.11.25 10:45:51 - Updating systems & servers data ...
I 2015.11.25 10:45:51 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.11.25 10:45:51 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.11.25 10:45:51 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.11.25 10:45:51 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.11.25 10:45:51 - Ready
. 2015.11.25 10:45:52 - Systems & servers data update completed
! 2015.11.25 10:45:55 - Activation of Network Lock - Windows Firewall
I 2015.11.25 10:46:07 - Session starting.
I 2015.11.25 10:46:07 - IPv6 disabled.
I 2015.11.25 10:46:07 - Checking authorization ...
! 2015.11.25 10:46:07 - Connecting to Nodus (Sweden, Uppsala)
. 2015.11.25 10:46:07 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.25 10:46:07 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.25 10:46:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.25 10:46:07 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.25 10:46:07 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:46:07 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:46:07 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.11.25 10:46:07 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.25 10:46:07 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.133:443
. 2015.11.25 10:46:07 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.133:443, sid=d2561e4f 6fdf9194
. 2015.11.25 10:46:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.25 10:46:08 - OpenVPN > Validating certificate key usage
. 2015.11.25 10:46:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.25 10:46:08 - OpenVPN > VERIFY KU OK
. 2015.11.25 10:46:08 - OpenVPN > Validating certificate extended key usage
. 2015.11.25 10:46:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.25 10:46:08 - OpenVPN > VERIFY EKU OK
. 2015.11.25 10:46:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.25 10:46:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.25 10:46:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:46:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.25 10:46:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:46:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.25 10:46:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.133:443
. 2015.11.25 10:46:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.25 10:46:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.28.38 255.255.0.0'
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.25 10:46:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.25 10:46:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.25 10:46:11 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.25 10:46:11 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{808EB3FE-CE88-426C-962E-F0CBADF9785C}.tap
. 2015.11.25 10:46:11 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.25 10:46:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.28.38/255.255.0.0 [sUCCEEDED]
. 2015.11.25 10:46:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.28.38/255.255.0.0 on interface {808EB3FE-CE88-426C-962E-F0CBADF9785C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.25 10:46:11 - OpenVPN > Successful ARP Flush on interface [20] {808EB3FE-CE88-426C-962E-F0CBADF9785C}
. 2015.11.25 10:46:16 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.25 10:46:16 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.133 MASK 255.255.255.255 89.27.120.1
. 2015.11.25 10:46:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.11.25 10:46:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.25 10:46:16 - OpenVPN > C:\Windows\system32\route.exe ADD 81.175.171.116 MASK 255.255.255.255 89.27.120.1
. 2015.11.25 10:46:16 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.25 10:46:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.11.25 10:46:16 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.25 10:46:16 - Starting Management Interface
. 2015.11.25 10:46:16 - OpenVPN > Initialization Sequence Completed
I 2015.11.25 10:46:16 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2015.11.25 10:46:16 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.25 10:46:16 - Flushing DNS
I 2015.11.25 10:46:16 - Checking route
I 2015.11.25 10:46:17 - Checking DNS
! 2015.11.25 10:46:17 - Connected.
. 2015.11.25 10:46:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.11.25 10:46:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.11.25 10:47:27 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.11.25 10:47:27 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.11.25 10:47:27 - OpenVPN > Restart pause, 2 second(s)
! 2015.11.25 10:47:27 - Disconnecting
. 2015.11.25 10:47:27 - Management - Send 'signal SIGTERM'
. 2015.11.25 10:47:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.11.25 10:47:27 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.11.25 10:47:27 - OpenVPN > Assertion failed at misc.c:779
. 2015.11.25 10:47:27 - OpenVPN > Exiting due to fatal error
. 2015.11.25 10:47:27 - Connection terminated.
I 2015.11.25 10:47:27 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2015.11.25 10:47:27 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.11.25 10:47:30 - Checking authorization ...
W 2015.11.25 10:48:10 - Authorization check failed, continue anyway ({1])
! 2015.11.25 10:48:10 - Connecting to Acubens (Sweden, Uppsala)
. 2015.11.25 10:48:10 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.25 10:48:10 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.25 10:48:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.25 10:48:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.25 10:48:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:48:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:48:10 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.11.25 10:48:10 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.25 10:48:10 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.131:443
. 2015.11.25 10:48:42 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.11.25 10:48:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.11.25 10:48:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.11.25 10:48:47 - Disconnecting
. 2015.11.25 10:48:47 - Connection terminated.
I 2015.11.25 10:48:50 - Checking authorization ...
W 2015.11.25 10:49:30 - Authorization check failed, continue anyway ({1])
I 2015.11.25 10:49:30 - IPv6 restored.
! 2015.11.25 10:49:30 - Session terminated.
I 2015.11.25 10:54:47 - Session starting.
I 2015.11.25 10:54:47 - IPv6 disabled.
I 2015.11.25 10:54:47 - Checking authorization ...
! 2015.11.25 10:54:48 - Connecting to Acubens (Sweden, Uppsala)
. 2015.11.25 10:54:48 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.25 10:54:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.25 10:54:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.25 10:54:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.25 10:54:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:54:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:54:48 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.11.25 10:54:48 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.25 10:54:48 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.131:443
. 2015.11.25 10:54:48 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.131:443, sid=5ab2b41e a0b1c7bc
. 2015.11.25 10:54:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.25 10:54:48 - OpenVPN > Validating certificate key usage
. 2015.11.25 10:54:48 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.25 10:54:48 - OpenVPN > VERIFY KU OK
. 2015.11.25 10:54:48 - OpenVPN > Validating certificate extended key usage
. 2015.11.25 10:54:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.25 10:54:48 - OpenVPN > VERIFY EKU OK
. 2015.11.25 10:54:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.25 10:54:51 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.25 10:54:51 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:54:51 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.25 10:54:51 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.25 10:54:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.25 10:54:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.131:443
. 2015.11.25 10:54:53 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.25 10:54:53 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.138 255.255.0.0'
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.25 10:54:53 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.25 10:54:53 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.25 10:54:53 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.25 10:54:54 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{808EB3FE-CE88-426C-962E-F0CBADF9785C}.tap
. 2015.11.25 10:54:54 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.25 10:54:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.26.138/255.255.0.0 [sUCCEEDED]
. 2015.11.25 10:54:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.26.138/255.255.0.0 on interface {808EB3FE-CE88-426C-962E-F0CBADF9785C} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.25 10:54:54 - OpenVPN > Successful ARP Flush on interface [20] {808EB3FE-CE88-426C-962E-F0CBADF9785C}
. 2015.11.25 10:54:59 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.25 10:54:59 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.131 MASK 255.255.255.255 89.27.120.1
. 2015.11.25 10:54:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.11.25 10:54:59 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.25 10:54:59 - OpenVPN > C:\Windows\system32\route.exe ADD 81.175.171.116 MASK 255.255.255.255 89.27.120.1
. 2015.11.25 10:54:59 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=12]
. 2015.11.25 10:54:59 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.11.25 10:54:59 - OpenVPN > Route addition fallback to route.exe
. 2015.11.25 10:54:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.11.25 10:54:59 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.25 10:54:59 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=20]
. 2015.11.25 10:54:59 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.25 10:54:59 - Starting Management Interface
. 2015.11.25 10:54:59 - OpenVPN > Initialization Sequence Completed
I 2015.11.25 10:54:59 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2015.11.25 10:54:59 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.25 10:54:59 - Flushing DNS
I 2015.11.25 10:54:59 - Checking route
I 2015.11.25 10:55:00 - Checking DNS
! 2015.11.25 10:55:00 - Connected.
. 2015.11.25 10:55:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.11.25 10:55:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.11.25 10:59:13 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.11.25 10:59:13 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.11.25 10:59:13 - OpenVPN > Restart pause, 2 second(s)
! 2015.11.25 10:59:13 - Disconnecting
. 2015.11.25 10:59:13 - Management - Send 'signal SIGTERM'
. 2015.11.25 10:59:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.11.25 10:59:13 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.11.25 10:59:13 - OpenVPN > Assertion failed at misc.c:779
. 2015.11.25 10:59:13 - OpenVPN > Exiting due to fatal error
. 2015.11.25 10:59:13 - Connection terminated.
I 2015.11.25 10:59:13 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2015.11.25 10:59:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.11.25 10:59:16 - Checking authorization ...
W 2015.11.25 10:59:57 - Authorization check failed, continue anyway ({1])
I 2015.11.25 10:59:57 - IPv6 restored.
! 2015.11.25 10:59:57 - Session terminated.
