Bypass WIFI VPN restriction on iPhone
None of the VPN's for iOS work on the wifi. The wifi blocks vpn connections. Is there anything I can do about this or any special setting I pick when gettjng a config file. Or is there nothing for me to do?
Thanks!
Did you try different ports or protocols? You should have luck with port 443 and TCP on a public wifi. So Choose TCP on 443.
In addition for the ios client go into the settings and make sure seamless tunnel is checked also adaptive and no connection timeout.These settings are not found in the main app, go into phone settings and find openvpn on the list scroll down.
I tried every TCP port availabe for configuration download. none of them worked. My settings matched yours except my connection timeout which was 30 seconds. I don't think it will fix the issue but it is worth a shot I guess. Thank you!
