Quintilius
DNS Error Connection errors
Hi
Been using VPN for a week now with no issues.  Complete n00b, so apologies.  Inital DNS leaks as expected (Windows 10), fixed these with fixed IP/DNS in Ipv4 settings, and disabled IPv6.  Tested on ipleak.net - everything fine.
Went to use today still with orignal IP settings.  Connection drops after 1-2 minutes, browsers report DNS Connection errors.  Once I revert to automatic IP/DNS settings, problem solved but now leaking DNS.  Any suggestions?  Thiis the log where intially connected then changed IP/DNS settings when all connection lost (between 9.22-9.33).
Then follows another log when connected via fixed IP settings. AirVPN says connected, browser reports DNS porbe error
I 2015.11.19 09:22:28 - AirVPN client version: 2.10.3 / x86, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2015.11.19 09:22:29 - Reading options from C:\Users\*********l\AirVPN\AirVPN.xml
. 2015.11.19 09:22:29 - Data Path: C:\Users\**********\Local\AirVPN
. 2015.11.19 09:22:29 - App Path: C:\Program Files\AirVPN
. 2015.11.19 09:22:29 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.11.19 09:22:29 - Command line arguments (1): path="home"
. 2015.11.19 09:22:29 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2015.11.19 09:22:29 - Updating systems & servers data ...
. 2015.11.19 09:22:30 - Systems & servers data update completed
I 2015.11.19 09:22:30 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.11.19 09:22:30 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.11.19 09:22:30 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.11.19 09:22:30 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.11.19 09:22:30 - Ready
I 2015.11.19 09:23:00 - Session starting.
I 2015.11.19 09:23:01 - IPv6 disabled.
I 2015.11.19 09:23:01 - Checking authorization ...
! 2015.11.19 09:23:01 - Connecting to Salm (Netherlands, Alblasserdam)
. 2015.11.19 09:23:01 - OpenVPN > OpenVPN 2.3.8 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.19 09:23:01 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.19 09:23:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.19 09:23:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.19 09:23:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:23:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:23:02 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072]
. 2015.11.19 09:23:02 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.19 09:23:02 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.19:443
. 2015.11.19 09:23:02 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.19:443, sid=0e617575 0a4ed954
. 2015.11.19 09:23:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.19 09:23:02 - OpenVPN > Validating certificate key usage
. 2015.11.19 09:23:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.19 09:23:02 - OpenVPN > VERIFY KU OK
. 2015.11.19 09:23:02 - OpenVPN > Validating certificate extended key usage
. 2015.11.19 09:23:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.19 09:23:02 - OpenVPN > VERIFY EKU OK
. 2015.11.19 09:23:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.19 09:23:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:23:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:23:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:23:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:23:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.19 09:23:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.19:443
. 2015.11.19 09:23:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.19 09:23:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.33.80 255.255.0.0'
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.19 09:23:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.19 09:23:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.19 09:23:06 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.19 09:23:07 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E4347739-BC1E-4D3A-8845-65D4A350A91A}.tap
. 2015.11.19 09:23:07 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.19 09:23:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.33.80/255.255.0.0 [sUCCEEDED]
. 2015.11.19 09:23:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.33.80/255.255.0.0 on interface {E4347739-BC1E-4D3A-8845-65D4A350A91A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.19 09:23:07 - OpenVPN > Successful ARP Flush on interface [21] {E4347739-BC1E-4D3A-8845-65D4A350A91A}
. 2015.11.19 09:23:11 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.19 09:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.19 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:23:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.11.19 09:23:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.19 09:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 20
. 2015.11.19 09:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:23:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.11.19 09:23:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:23:11 - Starting Management Interface
. 2015.11.19 09:23:11 - OpenVPN > Initialization Sequence Completed
I 2015.11.19 09:23:12 - DNS of a network adapter forced (Broadcom 802.11n Network Adapter)
I 2015.11.19 09:23:13 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.19 09:23:13 - Flushing DNS
I 2015.11.19 09:23:13 - Checking route
I 2015.11.19 09:23:14 - Checking DNS
W 2015.11.19 09:24:01 - The remote name could not be resolved: 'salm_exit.airservers.org'
! 2015.11.19 09:24:01 - Disconnecting
. 2015.11.19 09:24:01 - Management - Send 'signal SIGTERM'
. 2015.11.19 09:24:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.11.19 09:24:01 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.11.19 09:24:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.11.19 09:24:01 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2015.11.19 09:24:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.19 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:24:06 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.11.19 09:24:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:24:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:24:06 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:24:06 - OpenVPN > Closing TUN/TAP interface
. 2015.11.19 09:24:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.11.19 09:24:06 - Connection terminated.
I 2015.11.19 09:24:09 - DNS of a network adapter restored to original settings (Broadcom 802.11n Network Adapter)
I 2015.11.19 09:24:10 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.11.19 09:24:13 - Checking authorization ...
! 2015.11.19 09:24:13 - Connecting to Salm (Netherlands, Alblasserdam)
. 2015.11.19 09:24:13 - OpenVPN > OpenVPN 2.3.8 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.19 09:24:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.19 09:24:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.19 09:24:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.19 09:24:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:24:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:24:14 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072]
. 2015.11.19 09:24:14 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.19 09:24:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.19:443
. 2015.11.19 09:24:14 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.19:443, sid=147124a1 c04e9752
. 2015.11.19 09:24:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.19 09:24:14 - OpenVPN > Validating certificate key usage
. 2015.11.19 09:24:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.19 09:24:14 - OpenVPN > VERIFY KU OK
. 2015.11.19 09:24:14 - OpenVPN > Validating certificate extended key usage
. 2015.11.19 09:24:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.19 09:24:14 - OpenVPN > VERIFY EKU OK
. 2015.11.19 09:24:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.19 09:24:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:24:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:24:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:24:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:24:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.19 09:24:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.19:443
. 2015.11.19 09:24:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.19 09:24:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.33.80 255.255.0.0'
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.19 09:24:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.19 09:24:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.19 09:24:17 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.19 09:24:17 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E4347739-BC1E-4D3A-8845-65D4A350A91A}.tap
. 2015.11.19 09:24:17 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.19 09:24:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.33.80/255.255.0.0 [sUCCEEDED]
. 2015.11.19 09:24:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.33.80/255.255.0.0 on interface {E4347739-BC1E-4D3A-8845-65D4A350A91A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.19 09:24:17 - OpenVPN > Successful ARP Flush on interface [21] {E4347739-BC1E-4D3A-8845-65D4A350A91A}
. 2015.11.19 09:24:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.19 09:24:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.19 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:24:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.11.19 09:24:22 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.19 09:24:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 20
. 2015.11.19 09:24:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:24:22 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.11.19 09:24:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:24:22 - Starting Management Interface
. 2015.11.19 09:24:22 - OpenVPN > Initialization Sequence Completed
I 2015.11.19 09:24:23 - Flushing DNS
I 2015.11.19 09:24:25 - Checking route
I 2015.11.19 09:24:25 - Checking DNS
! 2015.11.19 09:24:25 - Connected.
. 2015.11.19 09:24:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.11.19 09:24:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.11.19 09:32:41 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.11.19 09:32:41 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.11.19 09:32:41 - OpenVPN > Restart pause, 2 second(s)
! 2015.11.19 09:32:41 - Disconnecting
. 2015.11.19 09:32:41 - Management - Send 'signal SIGTERM'
. 2015.11.19 09:32:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.11.19 09:32:41 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.11.19 09:32:41 - OpenVPN > Assertion failed at misc.c:779
. 2015.11.19 09:32:41 - OpenVPN > Exiting due to fatal error
. 2015.11.19 09:32:41 - Connection terminated.
I 2015.11.19 09:32:45 - Checking authorization ...
! 2015.11.19 09:32:45 - Connecting to Alshat (Netherlands, Alblasserdam)
. 2015.11.19 09:32:45 - OpenVPN > OpenVPN 2.3.8 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.19 09:32:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.19 09:32:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.19 09:32:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.19 09:32:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:32:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:32:45 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072]
. 2015.11.19 09:32:45 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.19 09:32:45 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.4:443
. 2015.11.19 09:32:45 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.4:443, sid=24d6f83c 814f2ed5
. 2015.11.19 09:32:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.19 09:32:46 - OpenVPN > Validating certificate key usage
. 2015.11.19 09:32:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.19 09:32:46 - OpenVPN > VERIFY KU OK
. 2015.11.19 09:32:46 - OpenVPN > Validating certificate extended key usage
. 2015.11.19 09:32:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.19 09:32:46 - OpenVPN > VERIFY EKU OK
. 2015.11.19 09:32:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.19 09:32:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:32:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:32:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:32:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:32:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.19 09:32:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.4:443
. 2015.11.19 09:32:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.19 09:32:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.30.244 255.255.0.0'
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.19 09:32:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.19 09:32:49 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.19 09:32:49 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.19 09:32:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E4347739-BC1E-4D3A-8845-65D4A350A91A}.tap
. 2015.11.19 09:32:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.19 09:32:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.30.244/255.255.0.0 [sUCCEEDED]
. 2015.11.19 09:32:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.30.244/255.255.0.0 on interface {E4347739-BC1E-4D3A-8845-65D4A350A91A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.19 09:32:49 - OpenVPN > Successful ARP Flush on interface [21] {E4347739-BC1E-4D3A-8845-65D4A350A91A}
. 2015.11.19 09:32:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.19 09:32:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.4 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:32:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.11.19 09:32:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.19 09:32:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:32:54 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=21]
. 2015.11.19 09:32:54 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.11.19 09:32:54 - OpenVPN > Route addition fallback to route.exe
. 2015.11.19 09:32:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.11.19 09:32:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:32:54 - Starting Management Interface
. 2015.11.19 09:32:54 - OpenVPN > Initialization Sequence Completed
I 2015.11.19 09:32:54 - DNS of a network adapter forced (Broadcom 802.11n Network Adapter)
I 2015.11.19 09:32:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.19 09:32:54 - Flushing DNS
I 2015.11.19 09:32:55 - Checking route
2nd log
I 2015.11.19 09:43:29 - AirVPN client version: 2.10.3 / x86, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2015.11.19 09:43:29 - Reading options from C:\Users\******\AirVPN\AirVPN.xml
. 2015.11.19 09:43:29 - Data Path: C:\Users\*******\Local\AirVPN
. 2015.11.19 09:43:29 - App Path: C:\Program Files\AirVPN
. 2015.11.19 09:43:29 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.11.19 09:43:29 - Command line arguments (1): path="home"
. 2015.11.19 09:43:30 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2015.11.19 09:43:30 - Updating systems & servers data ...
I 2015.11.19 09:43:30 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.11.19 09:43:30 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.11.19 09:43:30 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.11.19 09:43:30 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.11.19 09:43:30 - Ready
. 2015.11.19 09:43:30 - Systems & servers data update completed
I 2015.11.19 09:43:39 - Session starting.
I 2015.11.19 09:43:39 - IPv6 disabled.
I 2015.11.19 09:43:42 - Checking authorization ...
! 2015.11.19 09:43:42 - Connecting to Salm (Netherlands, Alblasserdam)
. 2015.11.19 09:43:42 - OpenVPN > OpenVPN 2.3.8 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.19 09:43:42 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.19 09:43:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.19 09:43:42 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.19 09:43:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:43:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:43:42 - OpenVPN > Socket Buffers: R=[65536->131072] S=[64512->131072]
. 2015.11.19 09:43:42 - OpenVPN > UDPv4 link local: [undef]
. 2015.11.19 09:43:42 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.19:443
. 2015.11.19 09:43:42 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.19:443, sid=9553eca1 35c6690f
. 2015.11.19 09:43:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.19 09:43:43 - OpenVPN > Validating certificate key usage
. 2015.11.19 09:43:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.19 09:43:43 - OpenVPN > VERIFY KU OK
. 2015.11.19 09:43:43 - OpenVPN > Validating certificate extended key usage
. 2015.11.19 09:43:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.19 09:43:43 - OpenVPN > VERIFY EKU OK
. 2015.11.19 09:43:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.19 09:43:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:43:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:43:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.19 09:43:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.19 09:43:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.19 09:43:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.19:443
. 2015.11.19 09:43:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.19 09:43:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.33.80 255.255.0.0'
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.19 09:43:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.19 09:43:49 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.19 09:43:49 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.19 09:43:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{E4347739-BC1E-4D3A-8845-65D4A350A91A}.tap
. 2015.11.19 09:43:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.19 09:43:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.33.80/255.255.0.0 [sUCCEEDED]
. 2015.11.19 09:43:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.33.80/255.255.0.0 on interface {E4347739-BC1E-4D3A-8845-65D4A350A91A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.11.19 09:43:49 - OpenVPN > Successful ARP Flush on interface [21] {E4347739-BC1E-4D3A-8845-65D4A350A91A}
. 2015.11.19 09:43:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.11.19 09:43:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.19 MASK 255.255.255.255 192.168.0.1
. 2015.11.19 09:43:54 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=20]
. 2015.11.19 09:43:54 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.11.19 09:43:54 - OpenVPN > Route addition fallback to route.exe
. 2015.11.19 09:43:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.11.19 09:43:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:43:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.11.19 09:43:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.19 09:43:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.11.19 09:43:54 - Starting Management Interface
. 2015.11.19 09:43:54 - OpenVPN > Initialization Sequence Completed
I 2015.11.19 09:43:55 - DNS of a network adapter forced (Broadcom 802.11n Network Adapter)
I 2015.11.19 09:43:55 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.19 09:43:55 - Flushing DNS
I 2015.11.19 09:43:56 - Checking route
I 2015.11.19 09:43:56 - Checking DNS
! 2015.11.19 09:44:08 - Connected.
. 2015.11.19 09:44:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.11.19 09:44:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Whilst connected with fixed IP/DNS all these timeout
ping airvpn.org
ping 212.117.180.25
ping 10.4.0.1
Thanks as always
