headkevin
Cant connect To TCP With proxy
Hello, i cant connect with open vpn to proxy config i can only connect with UDP
OpenVpn spamming: TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds
Logs:
Sat Nov 14 23:11:55 2015 OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [iPv6] built on Aug  4 2015
Sat Nov 14 23:11:55 2015 library versions: OpenSSL 1.0.1p 9 Jul 2015, LZO 2.08
Enter Management Password:
Sat Nov 14 23:11:55 2015 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Sat Nov 14 23:11:55 2015 Need hold release from management interface, waiting...
Sat Nov 14 23:11:56 2015 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Sat Nov 14 23:11:56 2015 MANAGEMENT: CMD 'state on'
Sat Nov 14 23:11:56 2015 MANAGEMENT: CMD 'log all on'
Sat Nov 14 23:11:56 2015 MANAGEMENT: CMD 'hold off'
Sat Nov 14 23:11:56 2015 MANAGEMENT: CMD 'hold release'
Sat Nov 14 23:11:56 2015 Control Channel Authentication: tls-auth using INLINE static key file
Sat Nov 14 23:11:56 2015 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 14 23:11:56 2015 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 14 23:11:56 2015 Socket Buffers: R=[8192->8192] S=[8192->8192]
Sat Nov 14 23:11:56 2015 Attempting to establish TCP connection with [AF_INET]127.0.0.1:8080 [nonblock]
Sat Nov 14 23:11:56 2015 MANAGEMENT: >STATE:1447539116,TCP_CONNECT,,,
Sat Nov 14 23:12:06 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:12:11 2015 MANAGEMENT: >STATE:1447539131,TCP_CONNECT,,,
Sat Nov 14 23:12:21 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:12:26 2015 MANAGEMENT: >STATE:1447539146,TCP_CONNECT,,,
Sat Nov 14 23:12:36 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:12:41 2015 MANAGEMENT: >STATE:1447539161,TCP_CONNECT,,,
Sat Nov 14 23:12:51 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:12:56 2015 MANAGEMENT: >STATE:1447539176,TCP_CONNECT,,,
Sat Nov 14 23:13:06 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:13:11 2015 MANAGEMENT: >STATE:1447539191,TCP_CONNECT,,,
Sat Nov 14 23:13:21 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:13:26 2015 MANAGEMENT: >STATE:1447539206,TCP_CONNECT,,,
Sat Nov 14 23:13:36 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:13:41 2015 MANAGEMENT: >STATE:1447539221,TCP_CONNECT,,,
Sat Nov 14 23:13:51 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:13:56 2015 MANAGEMENT: >STATE:1447539236,TCP_CONNECT,,,
Sat Nov 14 23:14:06 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
Sat Nov 14 23:14:11 2015 MANAGEMENT: >STATE:1447539251,TCP_CONNECT,,,
Sat Nov 14 23:14:21 2015 TCP: connect to [AF_INET]127.0.0.1:8080 failed, will try again in 5 seconds: System próbował sprzęgnąć dysk z katalogiem na dysku sprzęgniętym.
And what is this?
  Sun Nov 15 01:57:46 2015 Route: Waiting for TUN/TAP interface to come up...
