FlamingMustard
2 suggestions for the airvpn client
im very statisfied with airvpn but although i have 2 sugesstions for the airvpn client.
1) I'm always logged in so i dont need the 'Overview' tab at start. I miss an option (maybe dropdown menu) to select wich tab should i see when i start the application.
2) I often only using only keyboard to control my computer. When i use arrow keys to select an server in list i want to hit 'enter/return' to connect but that doesn't work. I have to press Menu key and then select 'Connect now' and then enter.
Just small things but would make it more convenient for me. ;-)
Thank you.
Chris
