rog
issue regarding Zaniah and Gacrux server
zaniah and Gacrux
whenever i connect to either of these two servers
they show the correct ip adress to the vpn adress, but
they show my real native country on the map.
are those servers compromised or are theres some glitch
in the config on those servers ?
It's not the servers, depending on your Operating system, if windows highly likely it's leaking saved data you don't know about to give the google API your location that was supplied in the past from your browser, or possibly even windows settings themself giving google API access to it if you haven't blocked it through your browser.
thx for the reply, appreciate your answer.
anyways the issues are gone now :-)
