dssguy11
PFsense AirVPN disconnects and errors
Hey guys, been with Air for about a year.  Have it running on PFsense, get 70mb out of the tunnel, 60mb inside the tunnel.  Love the service.   I started noticing disconnects and flakey internet connection recently.  It ended up being Apinger so i fixed that, but while investigating, reading all the pfsense logs i noticed a ton of WAN IP changes and errors.  If anyone can help it would be much appreciate it..
Here is my PFsense general error log
Nov 1 10:31:14 php-fpm[3124]: /rc.start_packages: Restarting/Starting all
packages.
Nov 1 10:31:13 check_reload_status: Starting packages
Nov 1 10:31:13 php-fpm[3124]: /rc.newwanip: pfSense package system has
detected an IP change or dynamic WAN reconnection - 10.4.5.207 ->
10.4.14.212 - Restarting packages.
Nov 1 10:31:11 php-fpm[3124]: /rc.newwanip: Creating rrd update script
Nov 1 10:31:07 php-fpm[3124]: /rc.newwanip: IP has changed, killing
states on former IP 10.4.5.207.
Nov 1 10:31:07 php-fpm[3124]: /rc.newwanip: rc.newwanip: on (IP address:
10.4.14.212) (interface: AIRVPN_WAN[opt1]) (real interface: ovpnc1).
Nov 1 10:31:07 php-fpm[3124]: /rc.newwanip: rc.newwanip: Info: starting
on ovpnc1.
Nov 1 10:31:06 check_reload_status: rc.newwanip starting ovpnc1
Nov 1 10:31:06 kernel: ovpnc1: link state changed to UP
Nov 1 10:31:05 check_reload_status: Reloading filter
Nov 1 10:31:05 kernel: ovpnc1: link state changed to DOWN
Nov 1 09:33:44 php-fpm[58963]: /rc.start_packages: Restarting/Starting
all packages.
Nov 1 09:33:43 check_reload_status: Starting packages
Nov 1 09:33:43 php-fpm[58963]: /rc.newwanip: pfSense package system has
detected an IP change or dynamic WAN reconnection - 10.4.1.211 ->
10.4.5.207 - Restarting packages.
Nov 1 09:33:41 php-fpm[58963]: /rc.newwanip: Creating rrd update script
Nov 1 09:33:37 php-fpm[58963]: /rc.newwanip: IP has changed, killing
states on former IP 10.4.1.211.
Nov 1 09:33:37 php-fpm[58963]: /rc.newwanip: rc.newwanip: on (IP address:
10.4.5.207) (interface: AIRVPN_WAN[opt1]) (real interface: ovpnc1).
Nov 1 09:33:37 php-fpm[58963]: /rc.newwanip: rc.newwanip: Info: starting
on ovpnc1.
Nov 1 09:33:36 check_reload_status: rc.newwanip starting ovpnc1
Nov 1 09:33:36 kernel: ovpnc1: link state changed to UP
Nov 1 09:33:35 check_reload_status: Reloading filter
Nov 1 09:33:35 kernel: ovpnc1: link state changed to DOWN
Nov 1 09:14:58 php-fpm[24903]: /rc.start_packages: Restarting/Starting
all packages.
Nov 1 09:14:57 check_reload_status: Starting packages
Nov 1 09:14:57 php-fpm[24903]: /rc.newwanip: pfSense package system has
detected an IP change or dynamic WAN reconnection - 10.4.7.147 ->
10.4.1.211 - Restarting packages.
Nov 1 09:14:55 php-fpm[24903]: /rc.newwanip: Creating rrd update script
Nov 1 09:14:51 php-fpm[24903]: /rc.newwanip: IP has changed, killing
states on former IP 10.4.7.147.
Nov 1 09:14:51 php-fpm[24903]: /rc.newwanip: rc.newwanip: on (IP address:
10.4.1.211) (interface: AIRVPN_WAN[opt1]) (real interface: ovpnc1).
Nov 1 09:14:51 php-fpm[24903]: /rc.newwanip: rc.newwanip: Info: starting
on ovpnc1.
Nov 1 09:14:50 check_reload_status: rc.newwanip starting ovpnc1
Nov 1 09:14:50 kernel: ovpnc1: link state changed to UP
Nov 1 09:14:49 check_reload_status: Reloading filter
Nov 1 09:14:49 kernel: ovpnc1: link state changed to DOWN
Nov 1 08:49:53 php-fpm[88638]: /rc.start_packages: Restarting/Starting
all packages.
Nov 1 08:49:52 check_reload_status: Starting packages
Nov 1 08:49:52 php-fpm[88638]: /rc.newwanip: pfSense package system has
detected an IP change or dynamic WAN reconnection - 10.4.21.60 ->
10.4.7.147 - Restarting packages.
Nov 1 08:49:50 php-fpm[88638]: /rc.newwanip: Creating rrd update script
Nov 1 08:49:46 php-fpm[88638]: /rc.newwanip: IP has changed, killing
states on former IP 10.4.21.60.
Nov 1 08:49:46 php-fpm[88638]: /rc.newwanip: rc.newwanip: on (IP address:
10.4.7.147) (interface: AIRVPN_WAN[opt1]) (real interface: ovpnc1).
Nov 1 08:49:46 php-fpm[88638]: /rc.newwanip: rc.newwanip: Info: starting
on ovpnc1.
Nov 1 08:49:45 check_reload_status: rc.newwanip starting ovpnc1
Nov 1 08:49:45 kernel: ovpnc1: link state changed to UP
Nov 1 08:49:44 kernel: ovpnc1: link state changed to DOWN
Nov 1 08:20:24 syslogd: kernel boot file is /boot/kernel/kernel
Here is my OpenVPN logs:
Oct 31 13:20:19 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:20:19 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:20:19 openvpn[53731]: MANAGEMENT: CMD 'state 1'
Oct 31 13:20:19 openvpn[53731]: MANAGEMENT: Client connected from
/var/etc/openvpn/client1.sock
Oct 31 13:17:24 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:17:24 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:17:24 openvpn[53731]: MANAGEMENT: CMD 'state 1'
Oct 31 13:17:24 openvpn[53731]: MANAGEMENT: Client connected from
Oct 31 13:17:23 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:17:23 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:17:23 openvpn[53731]: MANAGEMENT: CMD 'state 1'
Oct 31 13:17:23 openvpn[53731]: MANAGEMENT: Client connected from
Oct 31 13:17:22 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:17:22 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:17:22 openvpn[53731]: MANAGEMENT: CMD 'state 1'
Oct 31 13:17:22 openvpn[53731]: MANAGEMENT: Client connected from
Oct 31 13:17:14 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:17:14 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:17:14 openvpn[53731]: MANAGEMENT: CMD 'state 1'
Oct 31 13:17:14 openvpn[53731]: MANAGEMENT: Client connected from
Oct 31 13:16:43 openvpn[53731]: MANAGEMENT: Client disconnected
Oct 31 13:16:43 openvpn[53731]: MANAGEMENT: CMD 'status 2'
Oct 31 13:16:43 openvpn[53731]: MANAGEMENT: CMD 'state 1'
thanks for the reply Zheng.  I'm pretty sure it isn't my ISP because when the VPN goes down I can switch over to non VPN and it works.  it looks like all of the errors are just on the VPN.
