Hello guys,
Just installed airvpn-bin-2.10.3-1 from yaourt and am trying to conect to a Swedish server but it keeps disconnecting and
restarts itself endlessly.  Locking the network does not help.
I have tried changing DNS switchmode to 'Renaming' to no success.
Any ideas or help would be appreciated. Freindly greetings from Finland
Here is the message from terminal
2015.10.27 16:56:50 - Starting Management Interface
. 2015.10.27 16:56:50 - OpenVPN > Initialization Sequence Completed
I 2015.10.27 16:56:50 - /etc/resolv.conf renamed to /etc/resolv.conf.airvpn as backup
I 2015.10.27 16:56:50 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
I 2015.10.27 16:56:50 - Flushing DNS
I 2015.10.27 16:56:50 - Checking route
W 2015.10.27 16:56:51 - Error: NameResolutionFailure
! 2015.10.27 16:56:51 - Disconnecting
. 2015.10.27 16:56:51 - Management - Send 'signal SIGTERM'
. 2015.10.27 16:56:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.10.27 16:56:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.10.27 16:56:51 - OpenVPN > SIGTERM received, sending exit notification to peer
Hi there,
I had the same issue develop on a prior Arch install, I disabled all DNS settings on the client and added my required DNS nameserver to etc/resolv.conf.
I reinstalled Arch and installed Eddie beta from the AUR and everything works as advertised.
Hi there,
This ^
Or try disabling the Route Checking feature.
Hei,
Thänks for your responses.
@Snaggle may I ask what you mean by "....added my required DNS nameserver to etc/resolv.conf." ?  I checked it and I have two already.  Perhaps you meant you added AirVPN's nameserver as well? Hmm
@RickJames, I have tried disabling RC feature without success.
If possible, I would like a solution that does not require re-installing Arch all togethor since I need my laptop for University's Mathematics.
I have christmas holiday in December when I can re-install.
I have read that this is pretty common problem recently and attempted all the suggestions not involving complete re-install to no success.
 Thänks.
Hei,
 Thänks.
Hi there,
Yes your correct I added Air's nameservers to my etc/resolv.conf.
Hope that helps.
EDIT- Check
https://airvpn.org/topic/15863-firejail-sandbox-your-linux-apps/
this could maybe help also.
Hello all!
UPDATE: fixed the issue.
For future readers of this post with similar problem:
What I did was,
1. Added 10.4.0.1 to etc/resolv.conf.
2. Changed the DNS settings to Resolvconf (Linux only). To do so, go to Preferences, then to Advanced tab, click DNS then change DNS Switch mode: Resolvconf (Linux only).
As a side note.
I do have the box "Check if the tunnel uses AirVPN DNS" ticked.
This thread may be marked as *Solved*
Cheers all!
