saxdm45 0 Posted ... Can someone pease help me get Plex setup for remote access? How do the ports need to be configured? I think I've tried everything. TIA Quote Share this post Link to post
SumRndmDude 22 Posted ... Setup a port forward on the AirVPN site. Pick a random port as the remote port and choose 32400 as the local port. You may have to enable both UDP and TCP as I've seen where doing so solved issues and other times it seemed to do nothing. Afterwards, select 'Manually Specify Port' in the Plex server settings and put in the remote port number you chose. Plex should then report your private IP/port and your public IP/port. Assuming you are behind a router that is. 1 Wolf666 reacted to this Quote Share this post Link to post
Wolf666 17 Posted ... Plex use TCP on port 32400, so UDP is not needed. Sent from my iPad using Tapatalk Quote Hide Wolf666's signature Hide all signatures - Router/Firewall pfSense 25.11.1 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz) - Switch Cisco SG350-10 /Zyxel XGS1210-12 - AP Netgear RAX200 (Stock FW) - NAS Synology DS1621+ (5 x 8TB WD Red) - ISP: Fiber 1000/300 (PPPoE) Share this post Link to post
