JamesDean
Eddie Advanced Features?
What does "Remove Default Gateway Route" do? (Check or Uncheck Box - Default Unchecked) And "Allow Ping" in the Network Lock section? I assume "Allow Pinger and Latency Tests" just allows those features in Eddie to work? Thanks.
