motorboatmygoat
Stuck at Checking Route
I am running the latest version of Eddie software on MAC OSX 10.10
When trying to connect, it gets stuck at Checking Route with every server I try.  If I leave it a few hours, it then works ok.  But the next day its back to Checking Route.
I have tried different protocols with no success.
Any tips?
My iOS devices connect fine.
If this keeps up, I will have to leave AIRVPN, which is something I don't want to do.
Try disabling the firewall in OSX or also allowing AirVPN in it.
My firewall is off.
I tried connecting to AirVPN without the network lock and it worked fine.  So it must be something to do with that.
Today I connected fine with the network lock on so the problem is not always there.  Very strange.
I have the same issue. It's very annoying.
My logs:
I 2015.09.30 18:40:12 - Session starting.
I 2015.09.30 18:40:12 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2015.09.30 18:40:13 - IPv6 disabled on network adapter (Wi-Fi)
I 2015.09.30 18:40:13 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2015.09.30 18:40:13 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2015.09.30 18:40:13 - Checking authorization ...
! 2015.09.30 18:40:13 - Connecting to Subra (Netherlands, Alblasserdam)
. 2015.09.30 18:40:13 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2015.09.30 18:40:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.30 18:40:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3102
. 2015.09.30 18:40:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.30 18:40:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.30 18:40:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.30 18:40:13 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2015.09.30 18:40:13 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.30 18:40:13 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.98:443
. 2015.09.30 18:40:13 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.98:443, sid=acaea671 cd737350
. 2015.09.30 18:40:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.09.30 18:40:13 - OpenVPN > Validating certificate key usage
. 2015.09.30 18:40:13 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.09.30 18:40:13 - OpenVPN > VERIFY KU OK
. 2015.09.30 18:40:13 - OpenVPN > Validating certificate extended key usage
. 2015.09.30 18:40:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.09.30 18:40:13 - OpenVPN > VERIFY EKU OK
. 2015.09.30 18:40:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.09.30 18:40:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.30 18:40:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.30 18:40:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.09.30 18:40:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.30 18:40:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.09.30 18:40:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.98:443
. 2015.09.30 18:40:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.09.30 18:40:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.99 255.255.0.0'
. 2015.09.30 18:40:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.09.30 18:40:18 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.09.30 18:40:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.09.30 18:40:18 - OpenVPN > route: writing to routing socket: File exists
. 2015.09.30 18:40:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.09.30 18:40:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.09.30 18:40:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.09.30 18:40:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.09.30 18:40:19 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2015.09.30 18:40:19 - OpenVPN > Opened utun device utun1
. 2015.09.30 18:40:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.09.30 18:40:19 - OpenVPN > /sbin/ifconfig utun1 delete
. 2015.09.30 18:40:19 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.09.30 18:40:19 - OpenVPN > /sbin/ifconfig utun1 10.4.0.99 10.4.0.99 netmask 255.255.0.0 mtu 1500 up
. 2015.09.30 18:40:19 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.0.99 255.255.0.0
. 2015.09.30 18:40:19 - OpenVPN > add net 10.4.0.0: gateway 10.4.0.99: File exists
. 2015.09.30 18:40:19 - OpenVPN > /sbin/route add -net 213.152.162.98 192.168.0.1 255.255.255.255
. 2015.09.30 18:40:19 - OpenVPN > add net 213.152.162.98: gateway 192.168.0.1
. 2015.09.30 18:40:19 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2015.09.30 18:40:19 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2015.09.30 18:40:19 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2015.09.30 18:40:19 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2015.09.30 18:40:19 - Starting Management Interface
. 2015.09.30 18:40:19 - OpenVPN > Initialization Sequence Completed
I 2015.09.30 18:40:19 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.09.30 18:40:19 - DNS of a network adapter forced (Wi-Fi)
I 2015.09.30 18:40:19 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.09.30 18:40:20 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.09.30 18:40:20 - Flushing DNS
I 2015.09.30 18:40:20 - Checking route
W 2015.09.30 18:41:10 - The request timed out
! 2015.09.30 18:41:10 - Disconnecting
