I have a really strange problem. I using Nusakan on my Asus ac3200 router with the latest merlin. The VPN connection reconnects after a X couple of days.
20 Minutes ago this happend again. See log of my Router.
Have any of you guys a Idea what the problem is?
Thanks in Advance!
Sep 26 21:37:50 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:37:50 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:40:26 openvpn[31078]: [server] Inactivity timeout (--ping-restart), restarting
Sep 26 21:40:26 openvpn[31078]: SIGUSR1[soft,ping-restart] received, process restarting
Sep 26 21:40:26 openvpn[31078]: Restart pause, 2 second(s)
Sep 26 21:40:28 openvpn[31078]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 26 21:40:28 openvpn[31078]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Sep 26 21:40:28 openvpn[31078]: UDPv4 link local: [undef]
Sep 26 21:40:28 openvpn[31078]: UDPv4 link remote: [AF_INET]213.163.74.22:443
Sep 26 21:40:42 openvpn[31078]: TLS: Initial packet from [AF_INET]213.163.74.22:443, sid=b03e4e8c 8af55fa1
Sep 26 21:40:42 openvpn[31078]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sep 26 21:40:42 openvpn[31078]: Validating certificate key usage
Sep 26 21:40:42 openvpn[31078]: ++ Certificate has key usage  00a0, expects 00a0
Sep 26 21:40:42 openvpn[31078]: VERIFY KU OK
Sep 26 21:40:42 openvpn[31078]: Validating certificate extended key usage
Sep 26 21:40:42 openvpn[31078]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sep 26 21:40:42 openvpn[31078]: VERIFY EKU OK
Sep 26 21:40:42 openvpn[31078]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Sep 26 21:40:44 openvpn[31078]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 26 21:40:44 openvpn[31078]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 26 21:40:44 openvpn[31078]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 26 21:40:44 openvpn[31078]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 26 21:40:44 openvpn[31078]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Sep 26 21:40:44 openvpn[31078]: [server] Peer Connection Initiated with [AF_INET]213.163.74.22:443
Sep 26 21:40:46 openvpn[31078]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sep 26 21:40:46 openvpn[31078]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.2.196 255.255.0.0'
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: timers and/or timeouts modified
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: LZO parms modified
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: --ifconfig/up options modified
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: route options modified
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: route-related options modified
Sep 26 21:40:46 openvpn[31078]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sep 26 21:40:46 openvpn[31078]: Preserving previous TUN/TAP instance: tun11
Sep 26 21:40:46 openvpn[31078]: Initialization Sequence Completed
Sep 26 21:40:48 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 48:5a:3f:13:e0:13
Sep 26 21:40:48 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.71 48:5a:3f:13:e0:13
Sep 26 21:40:48 dnsmasq-dhcp[31067]: DHCPREQUEST(br0) 192.168.1.71 48:5a:3f:13:e0:13
Sep 26 21:40:48 dnsmasq-dhcp[31067]: DHCPACK(br0) 192.168.1.71 48:5a:3f:13:e0:13 android-b640044e232fa394
Sep 26 21:40:54 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:40:54 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:43:58 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:43:58 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:47:02 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:47:02 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:47:04 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:47:04 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:47:07 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:47:07 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:50:12 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:50:12 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:53:17 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:53:17 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:53:55 openvpn[31078]: event_wait : Interrupted system call (code=4)
Sep 26 21:53:55 openvpn[31078]: OpenVPN STATISTICS
Sep 26 21:53:55 openvpn[31078]: Updated,Sat Sep 26 21:53:55 2015
Sep 26 21:53:55 openvpn[31078]: TUN/TAP read bytes,10295408
Sep 26 21:53:55 openvpn[31078]: TUN/TAP write bytes,546281231
Sep 26 21:53:55 openvpn[31078]: TCP/UDP read bytes,567404533
Sep 26 21:53:55 openvpn[31078]: TCP/UDP write bytes,18969872
Sep 26 21:53:55 openvpn[31078]: Auth read bytes,546281231
Sep 26 21:53:55 openvpn[31078]: pre-compress bytes,0
Sep 26 21:53:55 openvpn[31078]: post-compress bytes,0
Sep 26 21:53:55 openvpn[31078]: pre-decompress bytes,0
Sep 26 21:53:55 openvpn[31078]: post-decompress bytes,0
Sep 26 21:53:55 openvpn[31078]: END
Sep 26 21:56:22 dnsmasq-dhcp[31067]: DHCPDISCOVER(br0) 56:fa:3e:29:a6:42
Sep 26 21:56:22 dnsmasq-dhcp[31067]: DHCPOFFER(br0) 192.168.1.58 56:fa:3e:29:a6:42
Sep 26 21:56:29 openvpn[31078]: OpenVPN STATISTICS
Sep 26 21:56:29 openvpn[31078]: Updated,Sat Sep 26 21:56:29 2015
Sep 26 21:56:29 openvpn[31078]: TUN/TAP read bytes,22808851
Sep 26 21:56:29 openvpn[31078]: TUN/TAP write bytes,1185027464
Sep 26 21:56:29 openvpn[31078]: TCP/UDP read bytes,1230593995
Sep 26 21:56:29 openvpn[31078]: TCP/UDP write bytes,42885606
Sep 26 21:56:29 openvpn[31078]: Auth read bytes,1185027464
Sep 26 21:56:29 openvpn[31078]: pre-compress bytes,0
Sep 26 21:56:29 openvpn[31078]: post-compress bytes,0
Sep 26 21:56:29 openvpn[31078]: pre-decompress bytes,0
Sep 26 21:56:29 openvpn[31078]: post-decompress bytes,0
Sep 26 21:56:29 openvpn[31078]: END
