jmeyers
Fatal Error on connection attempt; restart in 3-2-1 etc etc
Hello I am running AirVPN 2.10.3 on Mac OS X Yosemite 10.10.5 and cannot connect. This has been going on for several months, and existed on 2.9.x. I would appreciate any and all help. The problem exists whether or not I check "Check if the tunnel effectively works" and/or "Check if the tunnel uses AirVPN DNS". Thanks very much in advance. Here is the log:
I 2015.09.26 13:57:05 - Session starting.
I 2015.09.26 13:57:05 - IPv6 disabled on network adapter (Bluetooth DUN)
I 2015.09.26 13:57:05 - IPv6 disabled on network adapter (Ethernet)
I 2015.09.26 13:57:05 - IPv6 disabled on network adapter (*FireWire)
I 2015.09.26 13:57:06 - IPv6 disabled on network adapter (Wi-Fi)
I 2015.09.26 13:57:06 - Checking authorization ...
! 2015.09.26 13:57:06 - Connecting to Gacrux (Sweden, Uppsala)
. 2015.09.26 13:57:06 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2015.09.26 13:57:06 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.26 13:57:06 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known
. 2015.09.26 13:57:06 - OpenVPN > Exiting due to fatal error
! 2015.09.26 13:57:06 - Disconnecting
. 2015.09.26 13:57:06 - Connection terminated.
I 2015.09.26 13:57:09 - Checking authorization ...
! 2015.09.26 13:57:09 - Connecting to Gacrux (Sweden, Uppsala)
. 2015.09.26 13:57:09 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2015.09.26 13:57:09 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.26 13:57:09 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known
. 2015.09.26 13:57:09 - OpenVPN > Exiting due to fatal error
! 2015.09.26 13:57:10 - Disconnecting
. 2015.09.26 13:57:10 - Connection terminated.
I 2015.09.26 13:57:13 - Checking authorization ...
! 2015.09.26 13:57:13 - Connecting to Gacrux (Sweden, Uppsala)
. 2015.09.26 13:57:13 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 13 2015
. 2015.09.26 13:57:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.26 13:57:13 - OpenVPN > RESOLVE: Cannot resolve host address: localhost: nodename nor servname provided, or not known
. 2015.09.26 13:57:13 - OpenVPN > Exiting due to fatal error
! 2015.09.26 13:57:13 - Disconnecting
. 2015.09.26 13:57:13 - Connection terminated.
I 2015.09.26 13:57:13 - Cancel requested.
I 2015.09.26 13:57:13 - IPv6 restored on network adapter (Bluetooth DUN)
I 2015.09.26 13:57:13 - IPv6 restored on network adapter (Ethernet)
I 2015.09.26 13:57:13 - IPv6 restored on network adapter (*FireWire)
I 2015.09.26 13:57:13 - IPv6 restored on network adapter (Wi-Fi)
! 2015.09.26 13:57:13 - Session terminated.
Anyone have any good ideas? My OS X firewall is off. My hosts file has the following:
127.0.0.1 localhost
255.255.255.255 broadcasthost
::1 localhost
fe80::1%lo0 localhost
Help is much appreciated. Thanks in advance.
Never mind. I just upgraded to OS X 10.11 and the problem seems to be gone, and I can connect now. I'd have preferred to wait a few months before an upgrade, but I wanted this problem solved.
