Vortice
Port Forwarding issue - please help
Hi guys, sorry, this is probably rockie question but can't seem to figure it out.. I'm bit new to all this:)
So, I've selected port on the website so AirVPN has the port opened for me, I've setted the port in the mule and disabled UPNp.
When I test the ports though.. it says:
Testing IP: 82.145.37.203 (82.145.37.203)
Obfuscation: Disabled
Starting TCP connection test...
result_err.gifTCP test failed! UDP test will not be performed.
Connection test finished.
Results in detail:
  • TCP connection test failed.
    It was not possible, to establish a TCP connection to your eMule.
    Other users will only be able to connect to you with the help of a server, resulting in a low ID for you. While eMule still works, this will give you several disadvantages. Therfore it is highly recommended to solve this problem.
How to resolve port problems... Something is interfering with your network communications. There are two main reasons for this:
  • If you are using a firewall, ensure that your firwall don't block the required ports! You might need to set a rule to allow the ports to be available.
  • If you use a router, make sure that your router forwards the required ports to your local IP!
  • You can find more details and guides here in the online help.
How can I fix this? Thanks!
Same here. I have enabled 8 different ports from 61203 to 61210 and none work with emule or shareaza.
Win 7 64 bit
Airvpn.  Network lock enabled
windows firewall on.   Both emule and shareaza allowed (green check mark) on vpn network
Comodo firewall with both applications set to "allowed"
Ports are not forwarded in router as mentioned in several posts and instructions on port forwarding.
Thank you
okay so I solved it.
When uou forward a port, don't a pick a port number.
This will create a port for you with a number that you did not pick. I took the forwarded port number and placed it in emule and restarted emule. Now it works with a high ID.
hope that helps.
hope that helps.
Is this still working for you??
