Not connected, Your IP: 216.73.217.73
pretori
NAS behind Asus running Merlin - portforwarding
Hi
For several day now I have tried to get my torrent port on my Synology running the latest build to listen to incoming traffic ports. I have tried both download station an rtorrent. But I never seem to get the port forwarding to work in the router from the tun11 to the local adress.
My setup: NAS - Asus n66u running latest Merlin with Airvpn open VPN tunnel. Remote port forwarding made on Airvpn account.
In my NAS I have opened the ports I got from airvpn. In the router the port forwarding is made in the jffs. From tun11. After reading every post om this forum it still doesn't work. And now I don't now what to do.
Any suggestion?
Skickat från min SM-G900F via Tapatalk
Hi again, the last input leaved out the config as is today.
rTorrent i set up to listen to port 8997-8998.
The firewall in Synology is set upp to have 8997-8998 ports open.
Asus - firewall-start
#!/bin/sh
sleep 4
iptables -I FORWARD -i br0 -o tun12 -j ACCEPT
iptables -I FORWARD -i tun12 -o br0 -j ACCEPT
iptables -I FORWARD ! -o tun12 -s 192.168.1.3 -j DROP
iptables -I INPUT -i tun12 -j REJECT
iptables -t nat -A POSTROUTING -o tun12 -j MASQUERADE
Asus - net-start
#!/bin/sh
iptables -I FORWARD -i tun12 -p udp -d 192.168.1.3 --dport 8997 -j ACCEPT
iptables -I FORWARD -i tun12 -p udp -d 192.168.1.3 --dport 8998 -j ACCEPT
iptables -I FORWARD -i tun12 -p tcp -d 192.168.1.3 --dport 8997 -j ACCEPT
iptables -I FORWARD -i tun12 -p tcp -d 192.168.1.3 --dport 8998 -j ACCEPT
iptables -t nat -I PREROUTING -i tun12 -p tcp --dport 8997 -j DNAT --to-destination 192.168.1.3
iptables -t nat -I PREROUTING -i tun12 -p tcp --dport 8998 -j DNAT --to-destination 192.168.1.3
iptables -t nat -I PREROUTING -i tun12 -p udp --dport 8997 -j DNAT --to-destination 192.168.1.3
iptables -t nat -I PREROUTING -i tun12 -p udp --dport 8998 -j DNAT --to-destination 192.168.1.3
I also have policy rules set in the Open VPN tab on the asus.
In AirVPN the ports 8997-8998 is set as local ports in the remote port forwarding.
I get error 110 on the port forwarding page at AirVPN
My torrents are not able to connect to the tracker.
